I have an ADXL362 eval board connected to a nRF52840-DK. When I try to read the device ID from the ADXL362 instead of returning 0xAD it most often returns 0x21 and at other times the ADXL362 returns other hex values that are also not correct.
I have attached the ADXL362 eval board to a Particle Photon board and when I run the same series of commands I do receive the correct 0xAD command I expect for the device id.
I have attached my code that I run on the nRF52840-DK and the Logic analyzer results from both the successful run on the Photon and the 0x21 response on the nRF52840-DK.
What settings do I need to change to get the 0xAD response on the nRF52840-DK?
Main.c
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define ADXL362_CS_PIN 7 //P0.07
#define ADXL362_MOSI_PIN 12 //P0.12
#define ADXL362_MISO_PIN 8 //P0.08
#define ADXL362_SCK_PIN 11 //P0.11
#define READ 0x0B
#define WRITE 0x0A
#define ID 0x00
#define SPI_INSTANCE 0 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
uint8_t m_tx_buf[3]; /**< TX buffer. */
uint8_t m_rx_buf[3]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event, void * p_context)
spi_xfer_done = true;
printf("Transfer completed.\n");
uint8_t out0 = m_rx_buf[0];
uint8_t out1 = m_rx_buf[1];
uint8_t out2 = m_rx_buf[2];
printf("Out=0x%x, 0x%x, 0x%x \n", out0, out1, out2);
if (m_rx_buf[2] != 0)
printf("Received:");
printf(m_rx_buf);
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
void device_id(nrf_drv_spi_config_t *spi_config){
printf("Device_id");
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
m_tx_buf[0] = 0x0B;
m_tx_buf[1] = 0x00;
m_tx_buf[2] = 0x00;
nrf_gpio_pin_clear(spi_config->ss_pin);
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, m_length, m_rx_buf, m_length));
while (!spi_xfer_done)
__WFE();
nrf_gpio_pin_set(spi_config->ss_pin);
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_ms(1000);
void soft_reset(nrf_drv_spi_config_t *spi_config){
printf("soft_reset\n");
m_tx_buf[0] = 0x0A;
m_tx_buf[1] = 0x1F;
m_tx_buf[2] = 0x52;
__WFE();
NRF_LOG_FLUSH();
nrf_delay_ms(10000);
void start_measurement(nrf_drv_spi_config_t *spi_config){
printf("start_measurement\n");
m_tx_buf[0] = 0x0A;
m_tx_buf[1] = 0x2D; //Power Control
m_tx_buf[2] = 0x02;
__WFE();
NRF_LOG_FLUSH();
nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.frequency = NRF_DRV_SPI_FREQ_125K;
// spi_config.frequency = NRF_DRV_SPI_FREQ_250K;
// spi_config.frequency = NRF_DRV_SPI_FREQ_1M;
spi_config.mode = NRF_DRV_SPI_MODE_0;
spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
// spi_config.ss_pin = SPI_SS_PIN;
// spi_config.miso_pin = SPI_MISO_PIN;
// spi_config.mosi_pin = SPI_MOSI_PIN;
// spi_config.sck_pin = SPI_SCK_PIN;
spi_config.ss_pin = ADXL362_CS_PIN;
spi_config.miso_pin = ADXL362_MISO_PIN;
spi_config.mosi_pin = ADXL362_MOSI_PIN;
spi_config.sck_pin = ADXL362_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
// NRF_GPIO_Type * reg = nrf_gpio_pin_port_decode(ADXL362_SCK_PIN);
// reg->PIN_CNF[ADXL362_SCK_PIN] |= (NRF_GPIO_PIN_H0H1 << GPIO_PIN_CNF_DRIVE_Pos);
// NRF_GPIO_Type * reg2 = nrf_gpio_pin_port_decode(ADXL362_MISO_PIN);
// reg2->PIN_CNF[ADXL362_MISO_PIN] |= (NRF_GPIO_PIN_H0H1 << GPIO_PIN_CNF_DRIVE_Pos);
NRF_LOG_INFO("SPI example started.");
// soft_reset(&spi_config);
while (1)
device_id(&spi_config);
Good device ID from photon
Bad Device ID from nRF52840-DK
