NRFUTIL has issues unpacking a package.
I am trying to flash the firmware on a device with NRFUTIL. When I run NRFUTIL.exe on a my windows 10 machine I get the error
c:\Users\randy.cole\Documents>nrfutil.exe dfu serial -p COM3 -pkg Driver-V0.3.0.zip
  File "nordicsemi\__main__.py", line 1314, in <module>
  File "click\core.py", line 764, in __call__
  File "click\core.py", line 717, in main
  File "click\core.py", line 1137, in invoke
  File "click\core.py", line 956, in invoke
  File "click\core.py", line 555, in invoke
  File "nordicsemi\__main__.py", line 1006, in serial
  File "nordicsemi\__main__.py", line 935, in do_serial
  File "nordicsemi\dfu\dfu.py", line 71, in __init__
  File "nordicsemi\dfu\package.py", line 641, in unpack_package
IOError: [Errno 2] No such file or directory: 'c:\\users\\randy~1.col\\appdata\\local\\temp\\nrf_dfu_mx45km\\unpacked_zip\\manifest.json'
This error occurs with both version 5.0.0 and 6.0.1. The 5.0.0 version I used is a standalone exe file that was in one of our git repositories. The 6.0.1 version in straight from using pip install nrfutil. However when either version is run on mac I do not have the error, and when on windows 7 with 5.0.0 there is no error. (We only have 1 windows 7 machine handy and it only had 5.0.0 at the time of testing)
If I watch the temp folder where it is searching for the unpacked zip and run the command I see a _MEIxxxxx folder get created and disappear quickly but that's it.
  • It seems the path is the problem, in specific the 'randy.cole is turned into 'randy~1.col'. Try to change the path from where you are running nrfutil.exe.
  • First thing I did was get the latest version executable from https://github.com/NordicSemiconductor/pc-nrfutil/releases. I got the same issue. So I took your advice. I moved the files all over the disk and nothing changed. I then changed the windows environment variable for TEMP and TMP to a location without any '.' and got this. I changed the temp location to C:\TEMP\
    C:\>nrfutil.exe -v -v -v -v dfu serial -p COM3 -pkg Driver-v0.3.0.zip
    2020-01-30 11:57:03,343 Using board at serial port: COM3
      File "nordicsemi\__main__.py", line 1455, in <module>
      File "site-packages\click\core.py", line 764, in __call__
      File "site-packages\click\core.py", line 717, in main
      File "site-packages\click\core.py", line 1137, in invoke
      File "site-packages\click\core.py", line 956, in invoke
      File "site-packages\click\core.py", line 555, in invoke
      File "nordicsemi\__main__.py", line 1035, in serial
      File "nordicsemi\__main__.py", line 943, in do_serial
      File "nordicsemi\dfu\dfu.py", line 69, in __init__
      File "nordicsemi\dfu\package.py", line 649, in unpack_package
    FileNotFoundError: [Errno 2] No such file or directory: 'C:\\TEMP\\nrf_dfu_nu166aqg\\unpacked_zip\\manifest.json'
    It's the same error just at a different location. I tried running with an admin command prompt as well, just in case it didn't have permissions to write.
  • I went through the python files and put an input pause just before the error so I could see if a folder is created and what is in it. It turns out the folder was created but instead of having the files I would expect to see it had a subfolder that then had the files in it. It turns out my package zip somehow got a subfolder in it and thus when unzipped didn't look right to the program. I didn't generate the zip so I was unaware that having the subfolder would make a difference. Thanks to those who replied.
