Timer for time measurement
Hallo devzone,
i have a real time task, where i have a trigger, different calculations and then the corresponding action.
Now i need to calculate the time from the trigger as close as possible to the corresponding action.
I started with the app timer which was quite easy.
app_timer_init();
app_timer_create();
app_timer_start();
trigger();
var1.start = app_timer_cnt_get();
calc();
var1.stop = app_timer_cnt_get();
var1.diff  = app_timer_cnt_diff_compute(stop,start)
GPIO_set();
But 32kHz / 30µs is quite large, idealy we could count with sysclk and maybe a low prescaler.
So im looking for something like:
nrf_drv_timer_init();
nrf_drv_timer_create();
triger();
"nrf_drv_timer_start()"; // from 0
calc():
"nrf_drv_timer_stop();"
var2.diff = "nrf_drv_timer_get()"
"nrf_drv_timer_set(0)"
I managed to add timer, interrupts, Blink LED, count interrupts, but i cant find the right Start Stop and Read functions i need.
With the count interrupts i could build something. But the interrupt is unnecessary and to complex.
I simply want to start a timer from zero, stop the timer, read the time, set him to zero again.
  • Hi, you can use nrfx_timer API:
    nrfx_timer_enable - start a timer from zero
    nrfx_timer_disable  - stop the timer
    nrfx_timer_capture - read the time
    nrfx_timer_clear - set him to zero again
  • I found a solution that works with the registers directly.
        // Register Approach
        // Init
        NRF_TIMER3->MODE = TIMER_MODE_MODE_Timer;           // Count up
        NRF_TIMER3->BITMODE = TIMER_BITMODE_BITMODE_32Bit;  // no restiction needed
        NRF_TIMER3->PRESCALER = 0;    // Set CLK Speed to 16 MHz
        NRF_TIMER3->INTENCLR;         // NO interrupts
        // RUN
        NRF_TIMER3->TASKS_CLEAR = 1;
        NRF_TIMER3->TASKS_START = 1;
        nrf_delay_ms(3);
        NRF_TIMER3->TASKS_CAPTURE[1] = 1;
        captured_value = NRF_TIMER3->CC[1];
        NRF_TIMER3->TASKS_STOP = 1;
        NRF_LOG_RAW_INFO("Cycles = %u", captured_value);
        NRF_LOG_RAW_INFO("\r\n");
        // RUN again
        nrf_delay_ms(1);
