UART and USB MSC not working together
Hello Nordic Support,
I have modified the USB MSC example to use SD card and have also initialized UART port. Basically, what I'm trying to achieve is to write data received over UART in SD card and the SD card contents must show up when plugged via USB.
Without the UART initialized, I can see  the LEDs turn ON and the SD card contents on Windows PC via nrf52840 USB port. However, if I initialize the UART, I no longer see the LEDs ON and the USB port no longer appears on Windows PC.
Can you please provide your inputs on the possible cause for this?
I've attached the program used. To reproduce the issue, just un comment the function "uart_init()" in main().
 * Copyright (c) 2016 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup fatfs_example_main main.c
 * @ingroup fatfs_example
 * @brief FATFS Example Application main file.
 * This file contains the source code for a sample application using FAT filesystem and SD card library.
#include <stdbool.h>
#include <stdint.h>
#include <stddef.h>
#include "nrf.h"
#include "bsp.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
#include "app_uart.h"
#include "nrf_uart.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "nrf_serial.h"
#include "app_timer.h"
#include "app_usbd.h"
#include "app_usbd_core.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_msc.h"
#include "app_error.h"
#include "app_util.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define FILE_NAME   "NORDIC.TXT"
#define TEST_STRING "SD card example."
#define SDC_SCK_PIN     ARDUINO_13_PIN  ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN    ARDUINO_11_PIN  ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN    ARDUINO_12_PIN  ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN      ARDUINO_10_PIN  ///< SDC chip select (CS) pin.
#define OP_QUEUES_SIZE          3
#define APP_TIMER_PRESCALER     NRF_SERIAL_APP_TIMER_PRESCALER
#define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
static void sleep_handler(void)
    __WFE();
    __SEV();
    __WFE();
typedef struct {
    uint8_t * p_data;
    uint32_t length;
} buffer_t;
 * @brief  SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
        m_block_dev_sdc,
        NRF_BLOCK_DEV_SDC_CONFIG(
                SDC_SECTOR_SIZE,
                APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
         NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
#define LED_USB_RESUME   (BSP_BOARD_LED_0)
#define LED_USB_START    (BSP_BOARD_LED_1)
 * @brief Enable power USB detection
 * Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
 * @brief Mass storage class user event handler
static void msc_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                app_usbd_msc_user_event_t     event);
 * @brief Ram block device size
 * @note Windows fails to format volumes smaller than 190KB
#define RAM_BLOCK_DEVICE_SIZE (380 * 512)
#define BLOCKDEV_LIST() (                                   \
    NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev)      \
 * @brief Endpoint list passed to @ref APP_USBD_MSC_GLOBAL_DEF
#define ENDPOINT_LIST() APP_USBD_MSC_ENDPOINT_LIST(1, 1)
 * @brief Mass storage class work buffer size
#define MSC_WORKBUFFER_SIZE (1024)
/*lint -save -e26 -e64 -e123 -e505 -e651*/
 * @brief Mass storage class instance
APP_USBD_MSC_GLOBAL_DEF(m_app_msc,
                        0,
                        msc_user_ev_handler,
                        ENDPOINT_LIST(),
                        BLOCKDEV_LIST(),
                        MSC_WORKBUFFER_SIZE);
 * @brief  USB connection status
static bool m_usb_connected = false;
 * @brief Class specific event handler.
 * @param p_inst    Class instance.
 * @param event     Class specific event.
    UNUSED_PARAMETER(p_inst);
    UNUSED_PARAMETER(event);
 * @brief  RAM block device work buffer
static uint8_t m_block_dev_ram_buff[RAM_BLOCK_DEVICE_SIZE];
static void fatfs_init()
    static FATFS fs;
    static DIR dir;
    static FILINFO fno;
    FRESULT ff_result;
    DSTATUS disk_state = STA_NOINIT;
    // Initialize FATFS disk I/O interface by providing the block device.
    static diskio_blkdev_t drives[] =
            DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
    diskio_blockdev_register(drives, ARRAY_SIZE(drives));
    // Initializing disk 0 (SDC)
    for (uint32_t retries = 3; retries && disk_state; --retries)
        disk_state = disk_initialize(0);
    if (disk_state) // Disk initialization failed
        return;
    uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
    uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb; //Get the SD card capacity
    // Mounting volume
    ff_result = f_mount(&fs, "", 1);
    if (ff_result) // Mount failed
        return;
    // Listing directory
    ff_result = f_opendir(&dir, "/");
    if (ff_result) // Directory listing failed
        return;
    do
        ff_result = f_readdir(&dir, &fno);
        if (ff_result != FR_OK) // Directory read failed
            return;
    while (fno.fname[0]);
static void fatfs_uninit(void)
    NRF_LOG_INFO("Un-initializing disk 0 (SD card)...");
    UNUSED_RETURN_VALUE(disk_uninitialize(0));
 * @brief USBD library specific event handler.
 * @param event     USBD library event.
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
            bsp_board_led_off(LED_USB_RESUME);
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_RESUME);
        case APP_USBD_EVT_STARTED:
            bsp_board_led_on(LED_USB_START);
        case APP_USBD_EVT_STOPPED:
            UNUSED_RETURN_VALUE(fatfs_init());
            app_usbd_disable();
            bsp_board_leds_off();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                fatfs_uninit();
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
            m_usb_connected = true;
static void fatfs_write(const void * buff, const void * fileName, uint32_t len)
  FIL file;
  FRESULT ff_result;
  uint32_t bytes_written = 0;
  ff_result = f_open(&file, fileName, FA_READ | FA_WRITE | FA_OPEN_APPEND);
      return;
  ff_result = f_write(&file, buff, len - 1, (UINT *) &bytes_written);
      return;
  (void) f_close(&file);
  return;
static int32_t fatfs_read(void * buff, const void * fileName, uint32_t len, uint32_t offset)
    FIL file;
    FRESULT ff_result;
    uint32_t bytes_read = 0;
    ff_result = f_open(&file, fileName, FA_READ);
      return -1;
    ff_result = f_lseek(&file, offset);
    return -1;
    ff_result = f_read(&file, buff, len, &bytes_read);
	return -1;
    return (int32_t)bytes_read;
/**@snippet [UART Initialization] */
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
/**@snippet [Handling the data received over UART] */
    static uint8_t data_array[113];
    static uint8_t index = 0;
    uint8_t readData[113];
    uint32_t       err_code;
    static uint32_t offset = 0;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
          index++;
          if (data_array[index-1] == '\n')
           fatfs_write(data_array, "NSData.bin", index);
            index = 0;
        case APP_UART_FIFO_ERROR:
	//case APP_UART_TX_EMPTY:
		//nrf_gpio_pin_clear(17);
		//tx_empty_flag = false;
		//break;
/**@brief  Function for initializing the UART module.
static void uart_init(void)
        .rx_pin_no    = ARDUINO_SDA_PIN,
        .tx_pin_no    = ARDUINO_SCL_PIN,
        .rts_pin_no   = UART_PIN_DISCONNECTED,
        .cts_pin_no   = UART_PIN_DISCONNECTED,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    ret = NRF_LOG_INIT(app_usbd_sof_timestamp_get);
    APP_ERROR_CHECK(ret);
    ret = nrf_drv_clock_init();
     /* Fill whole RAM block device buffer */
    for (size_t i = 0; i < sizeof(m_block_dev_ram_buff); ++i)
        m_block_dev_ram_buff[i] = i;
    ret = nrf_drv_power_init(NULL);
    ret = app_timer_init();
    fatfs_init();
    ret = app_usbd_init(&usbd_config);
    app_usbd_class_inst_t const * class_inst_msc = app_usbd_msc_class_inst_get(&m_app_msc);
    ret = app_usbd_class_append(class_inst_msc);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    //uart_init();
    while (true)
        while (app_usbd_event_queue_process())
            /* Nothing to do */
          __WFE();
  • I got it working. In app_uart_fifo.c in function app_uart_init(), there is a check to turn on receiver if Rx pin is connected.
    // Turn on receiver if RX pin is connected
        if (p_comm_params->rx_pin_no != UART_PIN_DISCONNECTED)
            return nrf_drv_uart_rx(&app_uart_inst, rx_buffer,1);
            return NRF_SUCCESS;
    Once I connected the Rx pin, the SD card contents showed up on the PC.
    Apologies for the false alarm.
