How to program flash with the output HEX file and SoftDevice file using NRF52-DK.
When programming with the output HEX file the device does not work, I need also HEX - SoftDevice.
Hi!
You can use the Programmer application in nRF Connect for Desktop to flash a HEX-file to your DK. If your application uses BLE you will need to add the SoftDevice first and then the application HEX file on top of that and select Erase & write.
Heidi
But i need flash extern device connected to the NRF52-DK.
Okay? Why is that a problem?
nRF Connect write program to the NRF52-DK and not to the external device.
Programming and Debug in Segger IDE works with NRF52-DK but I need seperate tool for flashing.
If you're using the nRF52 DK as the external debugger for your own device, how are you connecting them?
