Hi
this is the code I'm trying with my buzzer,
I want it to generate sound but with different frequencies.
".base_clock = NRF_PWM_CLK_1MHz," I can only as low as 125kHz, but I want to make 2kHz, wondering if that's because I should go with some other function?
please correct me if I was totally wrong.
thanks,
Cindy
* Copyright (c) 2015 - 2017, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup pwm_example_main main.c
* @ingroup pwm_example
* @brief PWM Example Application main file.
* This file contains the source code for a sample application using PWM.
#include <stdio.h>
#include <string.h>
#include "nrf_drv_pwm.h"
#include "app_error.h"
#include "boards.h"
#include "bsp.h"
#include "nrf_drv_clock.h"
#include "nrf_delay.h"
#define OUTPUT_PIN LED_1
static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
// Declare variables holding PWM sequence values. In this example only one channel is used
nrf_pwm_values_individual_t seq_values[] = {0, 0, 0, 0};
nrf_pwm_sequence_t const seq =
.values.p_individual = seq_values,
.length = NRF_PWM_VALUES_LENGTH(seq_values),
.repeats = 0,
.end_delay = 0
// Set duty cycle between 0 and 100%
void pwm_update_duty_cycle(uint8_t duty_cycle)
// Check if value is outside of range. If so, set to 100%
if(duty_cycle >= 100)
seq_values->channel_0 = 100;
seq_values->channel_0 = duty_cycle;
nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
static void pwm_init(void)
nrf_drv_pwm_config_t const config0 =
.output_pins =
OUTPUT_PIN, // channel 0
NRF_DRV_PWM_PIN_NOT_USED, // channel 1
NRF_DRV_PWM_PIN_NOT_USED, // channel 2
NRF_DRV_PWM_PIN_NOT_USED, // channel 3
.irq_priority = APP_IRQ_PRIORITY_LOWEST,
.count_mode = NRF_PWM_MODE_UP,
.top_value = 100,
.load_mode = NRF_PWM_LOAD_INDIVIDUAL,
.step_mode = NRF_PWM_STEP_AUTO
// Init PWM without error handler
APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
// Start clock for accurate frequencies
// Wait for clock to start
while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
pwm_init();
for (;;)
for(int i = 0; i <= 100; i++)
nrf_delay_ms(10);
pwm_update_duty_cycle(i);
/** @file
#include <stdio.h>
#include <string.h>
#include "boards.h"
#include "bsp.h"
#define OUTPUT_PIN 8
.repeats = 0,
.end_delay = 0
duty_cycle = 50;
.output_pins =
.top_value = 100,
pwm_init();
for (;;)
nrf_delay_ms(10);
