I don't know if I'm dealing with a hardware or software problem at this point. I have a custom NRF52810 board with chip antenna and no LF clock, in SES. In SDK 16 I modified the ble_app_hids_keyboard_pca10040e_s112 in the following ways....
Build
memory Segments
FLASH RX 0x0 0x2ffff;RAM RWX 0x20000000 0x5fff
Code Generation
ARM FP ABI Type = Soft
ARM FPU Type = None
Link
Section Placement Macros
FLASH_PH_START=0x0
FLASH_PH_SIZE=0x2ffff
RAM_PH_START=0x20000000
RAM_PH_SIZE=0x5fff
FLASH_START=0x19000
FLASH_SIZE=0x0x2ffff
RAM_START=0x20001a40
RAM_SIZE=0x5fff
Preprocessor
Preprocessor Definitions
APP_TIMER_V2
APP_TIMER_V2_RTC1_ENABLED
BOARD_CUSTOM
FLOAT_ABI_SOFT
INITIALIZE_USER_SECTIONS
NO_VTOR_CONFIG
NRF52810_XXAA
NRF52_PAN_74
NRF_SD_BLE_API_VERSION=7
S112
SOFTDEVICE_PRESENT
Runtime Memory Area
Heap Size
2048
Main Stack Size
2048
Debug
Target Device
nrf25810_xxaa
Loader
Additional Load File[0]
../../../../../../components/softdevice/s112/hex/s112_nrf52_7.0.1_softdevice.hex
Created custom_board.h (from pca10040.h)
Replace project files:
ses_startup_nrf52.s -> ses_startup_nrf52810.s
system_nrf52.c-> system_nrf52810.c
Remove
uart source files...
nrf_drv_uart.c
Edit sdk_config.h
disable UART, UARTE, LOG_BACKUP_UART
set LF_SRC==0 in multiple places
NRF_SDH_CLOCK_LF_RC_CTIV 16
NRF_SDH_CLOCK_LF_RC_TEMP_CTIV 2
NRF_LOG_BACKEND_RTT_ENABLED 1
disable BSP (No buttons on my board)
enable RTT logging backend
I will attach the project and sdk_config files. RTT logging only seems to work when selecting "Build and Run" rather than "Build and Debug". SES doesn't output any RTT logging in the built-in terminal. Here is the RTT output I'm getting...
00> <info> app_timer: RTC: initialized.
00>
00> <info> app: HID Keyboard example started.
00>
00> <info> app: m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
00>
00> <info> app: Fast advertising.
00>
00> <info> app: Slow advertising.
00>
00> <error> app: Fatal error
00>
The Fast advertising runs for a couple minutes, Slow advertising for several more minutes, and then finally the Fatal error. During this advertising process I am searching for new Bluetooth devices in Windows. I've tried the builtin Bluetooth adapter (4.0) and a USB Bluetooth adapter (4.2) and neither can find the adversiting signal. My laptop is within a half meter of the board. Can you help me diagnose this problem?
<!DOCTYPE Linker_Placement_File>
<Root name="Flash Section Placement">
<MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
<ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
<ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
<ProgramSection alignment="4" load="Yes" name=".init" />
<ProgramSection alignment="4" load="Yes" name=".init_rodata" />
<ProgramSection alignment="4" load="Yes" name=".text" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs" inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data" inputsections="*(.fs_data*)" runin=".fs_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data" inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
<ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data" inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
<ProgramSection alignment="4" load="Yes" name=".dtors" />
<ProgramSection alignment="4" load="Yes" name=".ctors" />
<ProgramSection alignment="4" load="Yes" name=".rodata" />
<ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
<ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
<ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
<ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
</MemorySegment>
<MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
<ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
<ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
<ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
<ProgramSection alignment="4" load="No" name=".fast_run" />
<ProgramSection alignment="4" load="No" name=".data_run" />
<ProgramSection alignment="4" load="No" name=".tdata_run" />
<ProgramSection alignment="4" load="No" name=".bss" />
<ProgramSection alignment="4" load="No" name=".tbss" />
<ProgramSection alignment="4" load="No" name=".non_init" />
<ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
<ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/>
<ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
</MemorySegment>
</Root>
<!DOCTYPE CrossStudio_Project_File>
<solution
Name="ble_app_hids_keyboard_pca10040e_s112"
target="8"
version="2">
<project Name="ble_app_hids_keyboard_pca10040e_s112">
<configuration
Name="Common"
arm_architecture="v7EM"
arm_core_type="Cortex-M4"
arm_endian="Little"
arm_fp_abi="Soft"
arm_fpu_type="Soft"
arm_linker_heap_size="2048"
arm_linker_process_stack_size="0"
arm_linker_stack_size="2048"
arm_linker_treat_warnings_as_errors="No"
arm_simulator_memory_simulation_parameter="RWX 00000000,00100000,FFFFFFFF;RWX 20000000,00010000,CDCDCDCD"
arm_target_device_name="nRF52810_xxAA"
arm_target_interface_type="SWD"
c_preprocessor_definitions="APP_TIMER_V2;APP_TIMER_V2_RTC1_ENABLED;BOARD_CUSTOM;FLOAT_ABI_SOFT;INITIALIZE_USER_SECTIONS;NO_VTOR_CONFIG;NRF52810_XXAA;NRF52_PAN_74;NRF_SD_BLE_API_VERSION=7;S112;SOFTDEVICE_PRESENT"
c_user_include_directories="../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_link_ctx_manager;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/nrf_ble_gatt;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/libraries/atomic;../../../../../../components/libraries/atomic_fifo;../../../../../../components/libraries/atomic_flags;../../../../../../components/libraries/balloc;../../../../../../components/libraries/bootloader/ble_dfu;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/cli;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/crypto;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/delay;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/experimental_task_manager;../../../../../../components/libraries/fds;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/gfx;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/memobj;../../../../../../components/libraries/mpu;../../../../../../components/libraries/mutex;../../../../../../components/libraries/pwm;../../../../../../components/libraries/pwr_mgmt;../../../../../../components/libraries/queue;../../../../../../components/libraries/ringbuf;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/sdcard;../../../../../../components/libraries/sensorsim;../../../../../../components/libraries/slip;../../../../../../components/libraries/sortlist;../../../../../../components/libraries/spi_mngr;../../../../../../components/libraries/stack_guard;../../../../../../components/libraries/strerror;../../../../../../components/libraries/svc;../../../../../../components/libraries/timer;../../../../../../components/libraries/twi_mngr;../../../../../../components/libraries/twi_sensor;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/util;../../../../../../components/softdevice/common;../../../../../../components/softdevice/s112/headers;../../../../../../components/softdevice/s112/headers/nrf52;../../../../../../components/toolchain/cmsis/include;../../../../../../external/fprintf;../../../../../../external/segger_rtt;../../../../../../external/utf_converter;../../../../../../integration/nrfx;../../../../../../integration/nrfx/legacy;../../../../../../modules/nrfx;../../../../../../modules/nrfx/drivers/include;../../../../../../modules/nrfx/hal;../../../../../../modules/nrfx/mdk;../config;"
debug_additional_load_file="../../../../../../components/softdevice/s112/hex/s112_nrf52_7.0.1_softdevice.hex"
debug_register_definition_file="../../../../../../modules/nrfx/mdk/nrf52810.svd"
debug_start_from_entry_point_symbol="No"
debug_target_connection="J-Link"
gcc_debugging_level="Level 3"
gcc_entry_point="Reset_Handler"
linker_output_format="hex"
linker_printf_fmt_level="long"
linker_printf_width_precision_supported="Yes"
linker_scanf_fmt_level="long"
linker_section_placement_file="flash_placement.xml"
linker_section_placement_macros="FLASH_PH_START=0x0;FLASH_PH_SIZE=0x2ffff;RAM_PH_START=0x20000000;RAM_PH_SIZE=0x5fff;FLASH_START=0x19000;FLASH_SIZE=0x0x2ffff;RAM_START=0x20001a40;RAM_SIZE=0x5fff"
linker_section_placements_segments="FLASH RX 0x0 0x2ffff;RAM RWX 0x20000000 0x5fff"
macros="CMSIS_CONFIG_TOOL=../../../../../../external_tools/cmsisconfig/CMSIS_Configuration_Wizard.jar"
project_directory=""
project_type="Executable" />
<folder Name="Segger Startup Files">
<file file_name="$(StudioDir)/source/thumb_crt0.s" />
</folder>
<folder Name="nRF_Log">
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_rtt.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_serial.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_backend_uart.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_default_backends.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_frontend.c" />
<file file_name="../../../../../../components/libraries/log/src/nrf_log_str_formatter.c" />
</folder>
<folder Name="nRF_Libraries">
<file file_name="../../../../../../components/libraries/button/app_button.c" />
<file file_name="../../../../../../components/libraries/util/app_error.c" />
<file file_name="../../../../../../components/libraries/util/app_error_handler_gcc.c" />
<file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
<file file_name="../../../../../../components/libraries/scheduler/app_scheduler.c" />
<file file_name="../../../../../../components/libraries/timer/app_timer2.c" />
<file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
<file file_name="../../../../../../components/libraries/crc16/crc16.c" />
<file file_name="../../../../../../components/libraries/timer/drv_rtc.c" />
<file file_name="../../../../../../components/libraries/fds/fds.c" />
<file file_name="../../../../../../components/libraries/hardfault/hardfault_implementation.c" />
<file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
<file file_name="../../../../../../components/libraries/atomic_fifo/nrf_atfifo.c" />
<file file_name="../../../../../../components/libraries/atomic_flags/nrf_atflags.c" />
<file file_name="../../../../../../components/libraries/atomic/nrf_atomic.c" />
<file file_name="../../../../../../components/libraries/balloc/nrf_balloc.c" />
<file file_name="../../../../../../external/fprintf/nrf_fprintf.c" />
<file file_name="../../../../../../external/fprintf/nrf_fprintf_format.c" />
<file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage.c" />
<file file_name="../../../../../../components/libraries/fstorage/nrf_fstorage_sd.c" />
<file file_name="../../../../../../components/libraries/memobj/nrf_memobj.c" />
<file file_name="../../../../../../components/libraries/pwr_mgmt/nrf_pwr_mgmt.c" />
<file file_name="../../../../../../components/libraries/ringbuf/nrf_ringbuf.c" />
<file file_name="../../../../../../components/libraries/experimental_section_vars/nrf_section_iter.c" />
<file file_name="../../../../../../components/libraries/sortlist/nrf_sortlist.c" />
<file file_name="../../../../../../components/libraries/strerror/nrf_strerror.c" />
<file file_name="../../../../../../components/libraries/sensorsim/sensorsim.c" />
</folder>
<folder Name="None">
<file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf52810.s" />
<file file_name="../../../../../../modules/nrfx/mdk/ses_startup_nrf_common.s" />
<file file_name="../../../../../../modules/nrfx/mdk/system_nrf52810.c" />
</folder>
<folder Name="Board Definition">
<file file_name="../../../../../../components/boards/boards.c" />
</folder>
<folder Name="nRF_Drivers">
<file file_name="../../../../../../integration/nrfx/legacy/nrf_drv_clock.c" />
<file file_name="../../../../../../modules/nrfx/soc/nrfx_atomic.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_clock.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/nrfx_gpiote.c" />
<file file_name="../../../../../../modules/nrfx/drivers/src/prs/nrfx_prs.c" />
</folder>
<folder Name="Board Support" />
<folder Name="Application">
<file file_name="../../../main.c" />
<file file_name="../config/sdk_config.h" />
</folder>
<folder Name="nRF_Segger_RTT">
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_Syscalls_SES.c" />
<file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
</folder>
<folder Name="nRF_BLE">
<file file_name="../../../../../../components/ble/peer_manager/auth_status_tracker.c" />
<file file_name="../../../../../../components/ble/common/ble_advdata.c" />
<file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
<file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
<file file_name="../../../../../../components/ble/common/ble_conn_state.c" />
<file file_name="../../../../../../components/ble/ble_link_ctx_manager/ble_link_ctx_manager.c" />
<file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
<file file_name="../../../../../../components/ble/peer_manager/gatt_cache_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/gatts_cache_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/id_manager.c" />
<file file_name="../../../../../../components/ble/nrf_ble_gatt/nrf_ble_gatt.c" />
<file file_name="../../../../../../components/ble/nrf_ble_qwr/nrf_ble_qwr.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_data_storage.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_database.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_id.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_manager.c" />
<file file_name="../../../../../../components/ble/peer_manager/peer_manager_handler.c" />
<file file_name="../../../../../../components/ble/peer_manager/pm_buffer.c" />
<file file_name="../../../../../../components/ble/peer_manager/security_dispatcher.c" />
<file file_name="../../../../../../components/ble/peer_manager/security_manager.c" />
</folder>
<folder Name="UTF8/UTF16 converter">
<file file_name="../../../../../../external/utf_converter/utf.c" />
</folder>
<folder Name="nRF_BLE_Services">
<file file_name="../../../../../../components/ble/ble_services/ble_bas/ble_bas.c" />
<file file_name="../../../../../../components/ble/ble_services/ble_dis/ble_dis.c" />
<file file_name="../../../../../../components/ble/ble_services/ble_hids/ble_hids.c" />
</folder>
<folder Name="nRF_SoftDevice">
<file file_name="../../../../../../components/softdevice/common/nrf_sdh.c" />
<file file_name="../../../../../../components/softdevice/common/nrf_sdh_ble.c" />
<file file_name="../../../../../../components/softdevice/common/nrf_sdh_soc.c" />
</folder>
</project>
<configuration
Name="Release"
c_preprocessor_definitions="NDEBUG"
gcc_optimization_level="Optimize For Size" />
</solution>
