Modem open after ended transmission
Dear Devzone
I have an NB-IoT application running on a Thingy:91, that wakes up every two minutes and sends a small package over TCP to a remote server.
I'm using a Keithley DMM6500 to measure the current consumption, and from that it is clearly visible that the modem doesn't not power down after sending the data. The current consumption is high (~30+mA) for at least 20 seconds after transmission has been completed. This of course ruins the average current consumption.
I have tried using different Power Saving Modes (PSM) with an active time as low as possible (a couple of seconds). The PSM mode is accepted by the network, but does not change the described behaviour. I have also tried different network vendors but without success.
I see similar behaviour when using the Asset Tracker example project.
Is this intended behaviour?
Modem firmware: 1.1.0
Best Regards, Andreas (Thireo)
  • Hi Andreas,
    thireo said:
    Could you give me some pointers as to how I'm supposed to send data via AT commands. I have yet to find any information regarding this, in the datasheets for NRF9160.
    You cannot trigger sending or receiving IP data using the AT commands that the modem exposes.
    I wanted to see if this happens due to the application triggers sending of data, or if this is a returned active time in PSM that differs.
    You mention that you have two SIM cards from different vendors (Telia and Telenor). Do both of these behave similar?
    Håkon
  • Hi Håkon
    I double checked if GPS is being enabled, by polling the system mode. I can confirm, that it is not being enabled.
    Oh okay, I misunderstood you then. I'm still unsure how I should test with the AT_client application.
    I have just tested with both SIM-cards and they show similar results.
    Andreas
  • Hi Andreas,
    In the telenor network here in norway, I cannot get such a low active time as you currently have. It is therefore very important that you check the PSM intervals that are set by the network (not just requested by the nRF).
    By setting AT+CFUN=1, then inputting your PSM settings via AT+CPSMS=1,,,"TAU","ACTIVE-time", you should soon get a PSM from the network.
    Using AT+CEREG=5 to enable reporting the PSM intervals, and check with "AT+CEREG?"
    Håkon
  • I have just done the following with a Telenor IoT SIM-card and using the AT client sample application.
    AT+CFUN=1 - Power on modem
    AT+CPSMS=1,,,"00100001","00000001" - request 2 seconds active time and 1 hour Tau.
    AT+CEREG=5 - Enabling reporting
    AT+CEREG? - Poll for report.
    See the attached image for the response.
  • Hi Andreas,
    Thank you for being this patient. I dug deeper into this, and soon figured out that I needed to consult experts.
    I have asked the developers and designers internally, and there is a RRC idle + release happening after the tracking area update performed after the T3412 (sleep timer) expires and before the T3324 (active timer) starts. The time you're in this RRC Idle, ie before the RRC release is issued, is a value set by the eNB (network). Any active time will be executed after this. Judging from the plots, it looks like approx. 30 seconds is the specific period in the network you're connected to.
    Håkon
