Problems with Flashing and GPIO enabling | nRF52840
Dear All,
    I am using  (nRF52840) in one of my design.
     Application program we have taken examples\peripheral\usbd_ble_uart\pca10056\s140\arm5_no_packs code as base code.
    - Flashing a NEW CHIP first time Booting never happens
           Made a new board and flashing the chip first time it never gets booted.  Couple of boards i flashed some random program from example and then if i flash the actual application programs it will run.  Currently the random flashing also not giving solution.
          Kindly provide an example program or steps to flash the new chip.
    - GPIO program kindly verify if below initialisation is enough.
          problem here is other than P0.06 every other GPIO is working fine.  Pls guide if any issue from our initialisation.
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
#define S32_SPIS_CS_PIN · · · · ·· NRF_GPIO_PIN_MAP(0,6)·
#define S32_SPIS_MISO_PIN NRF_GPIO_PIN_MAP(0,8)
#define S32_SPIS_MOSI_PIN NRF_GPIO_PIN_MAP(0,4)
#define S32_SPIS_SCK_PIN NRF_GPIO_PIN_MAP(0,12)
#define S32_BT_INT_PIN NRF_GPIO_PIN_MAP(1,9)
nrf_gpio_cfg_output (S32_SPIS_CS_PIN);
nrf_gpio_cfg_output (S32_SPIS_MISO_PIN);
nrf_gpio_cfg_output (S32_SPIS_MOSI_PIN);
nrf_gpio_cfg_output (S32_SPIS_SCK_PIN);
nrf_gpio_cfg_output (S32_BT_INT_PIN);
while(1){
#if 1
nrf_gpio_pin_set (S32_SPIS_CS_PIN);
nrf_delay_ms(5);
nrf_gpio_pin_set (S32_SPIS_MISO_PIN);
nrf_delay_ms(5);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
