nRF9160 initial set up
I am new to nRF9160 development board. I have just opened the board and tried to connect following the startup instructions. I was able to see LED 3 and LED 4 blink the first time but was not able to add the device automatically. I tried to add the board manually without a PIN (I couldnt find PIN anywhere)but could not connect to it . Now LED 3 blinks but LED 4 does not blink so I cannot add the board. I have added the SIM card. What should be my next steps?
  • Hi!
    If you're using a development kit the HWID on the back is the PIN you enter to add the device.
    However, if you just bought the board, you have to update the modem firmware before trying to connect, which you can download here.
    If it still does not work, please provide a new log.
    Heidi
  • HI,
    Yes,I just bought the new board.I tried to follow the steps mentioned in getting started video.I think I messed up while adding the device ,I didnt provide the PIN since i couldnt find it on the box(I didnt see that HWID is mentioned under the board) and selected without PIN.Not sure if thats the problem.I did download the latest firmware later but still no luck . LTE shows Disconnected.I have attached the logs yesterday for all the steps I did. Let me know if you want me to try something and provide the log.
  • If you added the device incorrectly you have to delete / reset it, and then reprovision the certificates.
    This tutorial describes how to do this. When it says to make sure your device is running an application fw that supports long AT commands I have attached the firmware at_client_long_at_commands. Flash this before provisioning certificates.
    binaries_firmware_nrf91dk.zip
    nrf91dk_at_client_long_at_commands.hex
  • I followed the procedure mentioned in the tutorial to reprovision the certificates. I See Error messages throughout.
    Attaching the log and also screenshot from LTE link Monitor.
    Need help soon!
    2020-02-06T14:25:10.554Z INFO Application data folder: C:\Users\MALLESA\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2020-02-06T14:25:11.033Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2020-02-06T14:25:11.033Z DEBUG App path: C:\Users\MALLESA\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2020-02-06T14:25:11.033Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.2.0)
    2020-02-06T14:25:11.034Z DEBUG nRFConnect path: C:\Users\MALLESA\AppData\Local\Programs\nrfconnect\resources\app.asar
    2020-02-06T14:25:11.034Z DEBUG HomeDir: C:\Users\MALLESA
    2020-02-06T14:25:11.034Z DEBUG TmpDir: C:\Users\MALLESA\AppData\Local\Temp
    2020-02-06T14:25:38.564Z INFO Modem port is opened
    2020-02-06T14:25:38.570Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-06T14:25:40.730Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-02-06T14:25:41.731Z ERROR Error: 'AT+CGMR
    ' timed out
    2020-02-06T14:26:24.171Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D
    2020-02-06T14:26:25.029Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T14:26:40.151Z DEBUG modem >> AT+CGMR\x0D\x0A
    2020-02-06T14:26:41.152Z ERROR Error: 'AT+CGMR
    ' timed out
    2020-02-06T14:38:24.287Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T14:38:30.472Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D\x0A
    2020-02-06T14:38:31.376Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T14:50:30.636Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T14:50:36.873Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D\x0A
    2020-02-06T14:50:37.875Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T15:04:36.899Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T15:04:43.194Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D\x0A
    2020-02-06T15:04:44.078Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T15:16:43.222Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T15:16:49.589Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D
    2020-02-06T15:16:50.694Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T15:28:49.745Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T15:28:55.940Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_CONNECTED\x0D\x0A
    2020-02-06T15:28:56.884Z DEBUG modem << NRF_CLOUD_EVT_USER_ASSOCIATED\x0D\x0A
    2020-02-06T15:34:12.771Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-02-06T15:34:13.772Z ERROR Error: 'AT+CFUN?
    ' timed out
    2020-02-06T15:34:56.805Z DEBUG modem << NRF_CLOUD_EVT_TRANSPORT_DISCONNECTED\x0D\x0A
    2020-02-06T15:34:56.814Z DEBUG modem << nrf_cloud_connect failed: 51\x0D
    2020-02-06T15:34:56.846Z DEBUG modem << ***** Booting Zephyr OS v1.13.99-ncs1-1823-g715d2df3dd *****\x0D\x0A
    2020-02-06T15:34:56.849Z DEBUG modem << Secure Boot: configure flash\x0D\x0A
    2020-02-06T15:34:56.853Z DEBUG modem << Secure Boot: SPU: set region 0 as Secure\x0D\x0A
    2020-02-06T15:34:56.856Z DEBUG modem << Secure Boot: SPU: set region 1 as Secure\x0D
    2020-02-06T15:34:56.860Z DEBUG modem << Secure Boot: SPU: set region 2 as Secure\x0D\x0A
    2020-02-06T15:34:56.863Z DEBUG modem << Secure Boot: SPU: set region 3 as Secure\x0D
    2020-02-06T15:34:56.867Z DEBUG modem << Secure Boot: SPU: set region 4 as Secure\x0D\x0A
    2020-02-06T15:34:56.871Z DEBUG modem << Secure Boot: SPU: set region 5 as Secure\x0D\x0A
    2020-02-06T15:34:56.874Z DEBUG modem << Secure Boot: SPU: set region 6 as Secure\x0D
    2020-02-06T15:34:56.878Z DEBUG modem << Secure Boot: SPU: set region 7 as Secure\x0D
    2020-02-06T15:34:56.882Z DEBUG modem << Secure Boot: SPU: set Flash region 8 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.887Z DEBUG modem << Secure Boot: SPU: set Flash region 9 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.891Z DEBUG modem << Secure Boot: SPU: set Flash region 10 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.896Z DEBUG modem << Secure Boot: SPU: set Flash region 11 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.901Z DEBUG modem << Secure Boot: SPU: set Flash region 12 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.905Z DEBUG modem << Secure Boot: SPU: set Flash region 13 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.910Z DEBUG modem << Secure Boot: SPU: set Flash region 14 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.915Z DEBUG modem << Secure Boot: SPU: set Flash region 15 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.919Z DEBUG modem << Secure Boot: SPU: set Flash region 16 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.924Z DEBUG modem << Secure Boot: SPU: set Flash region 17 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.928Z DEBUG modem << Secure Boot: SPU: set Flash region 18 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.934Z DEBUG modem << Secure Boot: SPU: set Flash region 19 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.939Z DEBUG modem << Secure Boot: SPU: set Flash region 20 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.942Z DEBUG modem << Secure Boot: SPU: set Flash region 21 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.946Z DEBUG modem << Secure Boot: SPU: set Flash region 22 as Non-Secure\x0D
    2020-02-06T15:34:56.951Z DEBUG modem << Secure Boot: SPU: set Flash region 23 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.956Z DEBUG modem << Secure Boot: SPU: set Flash region 24 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.960Z DEBUG modem << Secure Boot: SPU: set Flash region 25 as Non-Secure\x0D
    2020-02-06T15:34:56.965Z DEBUG modem << Secure Boot: SPU: set Flash region 26 as Non-Secure\x0D
    2020-02-06T15:34:56.969Z DEBUG modem << Secure Boot: SPU: set Flash region 27 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.974Z DEBUG modem << Secure Boot: SPU: set Flash region 28 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.979Z DEBUG modem << Secure Boot: SPU: set Flash region 29 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.983Z DEBUG modem << Secure Boot: SPU: set Flash region 30 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.988Z DEBUG modem << Secure Boot: SPU: set Flash region 31 as Non-Secure\x0D\x0A
    2020-02-06T15:34:56.990Z DEBUG modem << Secure Boot: configure SRAM\x0D
    2020-02-06T15:34:56.994Z DEBUG modem << Secure Boot: SPU: set SRAM region 0 as Secure\x0D\x0A
    2020-02-06T15:34:56.999Z DEBUG modem << Secure Boot: SPU: set SRAM region 1 as Secure\x0D\x0A
    2020-02-06T15:34:57.002Z DEBUG modem << Secure Boot: SPU: set SRAM region 2 as Secure\x0D\x0A
    2020-02-06T15:34:57.006Z DEBUG modem << Secure Boot: SPU: set SRAM region 3 as Secure\x0D\x0A
    2020-02-06T15:34:57.010Z DEBUG modem << Secure Boot: SPU: set SRAM region 4 as Secure\x0D\x0A
    2020-02-06T15:34:57.014Z DEBUG modem << Secure Boot: SPU: set SRAM region 5 as Secure\x0D
    2020-02-06T15:34:57.019Z DEBUG modem << Secure Boot: SPU: set SRAM region 6 as Secure\x0D\x0A
    2020-02-06T15:34:57.023Z DEBUG modem << Secure Boot: SPU: set SRAM region 7 as Secure\x0D\x0A
    2020-02-06T15:34:57.027Z DEBUG modem << Secure Boot: SPU: set SRAM region 8 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.032Z DEBUG modem << Secure Boot: SPU: set SRAM region 9 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.036Z DEBUG modem << Secure Boot: SPU: set SRAM region 10 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.041Z DEBUG modem << Secure Boot: SPU: set SRAM region 11 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.045Z DEBUG modem << Secure Boot: SPU: set SRAM region 12 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.050Z DEBUG modem << Secure Boot: SPU: set SRAM region 13 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.054Z DEBUG modem << Secure Boot: SPU: set SRAM region 14 as Non-Secure\x0D
    2020-02-06T15:34:57.058Z DEBUG modem << Secure Boot: SPU: set SRAM region 15 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.063Z DEBUG modem << Secure Boot: SPU: set SRAM region 16 as Non-Secure\x0D
    2020-02-06T15:34:57.068Z DEBUG modem << Secure Boot: SPU: set SRAM region 17 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.072Z DEBUG modem << Secure Boot: SPU: set SRAM region 18 as Non-Secure\x0D
    2020-02-06T15:34:57.076Z DEBUG modem << Secure Boot: SPU: set SRAM region 19 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.081Z DEBUG modem << Secure Boot: SPU: set SRAM region 20 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.086Z DEBUG modem << Secure Boot: SPU: set SRAM region 21 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.090Z DEBUG modem << Secure Boot: SPU: set SRAM region 22 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.094Z DEBUG modem << Secure Boot: SPU: set SRAM region 23 as Non-Secure\x0D
    2020-02-06T15:34:57.099Z DEBUG modem << Secure Boot: SPU: set SRAM region 24 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.103Z DEBUG modem << Secure Boot: SPU: set SRAM region 25 as Non-Secure\x0D
    2020-02-06T15:34:57.108Z DEBUG modem << Secure Boot: SPU: set SRAM region 26 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.113Z DEBUG modem << Secure Boot: SPU: set SRAM region 27 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.117Z DEBUG modem << Secure Boot: SPU: set SRAM region 28 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.122Z DEBUG modem << Secure Boot: SPU: set SRAM region 29 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.126Z DEBUG modem << Secure Boot: SPU: set SRAM region 30 as Non-Secure\x0D\x0A
    2020-02-06T15:34:57.130Z DEBUG modem << Secure Boot: SPU: set SRAM region 31 as Non-Secure\x0D
    2020-02-06T15:34:57.134Z DEBUG modem << Secure Boot: configure peripherals\x0D\x0A
    2020-02-06T15:34:57.137Z DEBUG modem << Secure Boot: MSP_NS 2002c790\x0D\x0A
    2020-02-06T15:34:57.140Z DEBUG modem << Secure Boot: prepare to jump to Non-Secure image\x0D
    2020-02-06T15:34:57.777Z DEBUG modem << ***** Booting Zephyr OS kitprod_w49 *****\x0D\x0A
    2020-02-06T15:34:57.778Z DEBUG modem << Application started\x0D\x0A
    2020-02-06T15:34:57.787Z DEBUG modem << LTE LC config ...\x0D
    2020-02-06T15:34:58.006Z DEBUG modem << [00:00:00.782,867] \x1B[1;31m<err> net_if.net_if_init: There is no network interface to work with!\x1B[0m\x0D\x0A
    2020-02-06T15:35:29.849Z INFO Updating CA certificate...
    2020-02-06T15:35:29.852Z DEBUG modem >> AT%CMNG=0,16842753,0,"-----BEGIN CERTIFICATE-----\x0D\x0A
    2020-02-06T15:35:29.867Z DEBUG modem >> MIIDQTCCAimgAwIBAgITBmyfz5m/jAo54vB4ikPmljZbyjANBgkqhkiG9w0BAQsF\x0D\x0A
    2020-02-06T15:35:29.880Z DEBUG modem >> ADA5MQswCQYDVQQGEwJVUzEPMA0GA1UEChMGQW1hem9uMRkwFwYDVQQDExBBbWF6\x0D\x0A
    2020-02-06T15:35:29.893Z DEBUG modem >> b24gUm9vdCBDQSAxMB4XDTE1MDUyNjAwMDAwMFoXDTM4MDExNzAwMDAwMFowOTEL\x0D\x0A
    2020-02-06T15:35:29.906Z DEBUG modem >> MAkGA1UEBhMCVVMxDzANBgNVBAoTBkFtYXpvbjEZMBcGA1UEAxMQQW1hem9uIFJv\x0D\x0A
    2020-02-06T15:35:29.918Z DEBUG modem >> b3QgQ0EgMTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBALJ4gHHKeNXj\x0D\x0A
    2020-02-06T15:35:29.931Z DEBUG modem >> ca9HgFB0fW7Y14h29Jlo91ghYPl0hAEvrAIthtOgQ3pOsqTQNroBvo3bSMgHFzZM\x0D\x0A
    2020-02-06T15:35:29.945Z DEBUG modem >> 9O6II8c+6zf1tRn4SWiw3te5djgdYZ6k/oI2peVKVuRF4fn9tBb6dNqcmzU5L/qw\x0D\x0A
    2020-02-06T15:35:29.959Z DEBUG modem >> IFAGbHrQgLKm+a/sRxmPUDgH3KKHOVj4utWp+UhnMJbulHheb4mjUcAwhmahRWa6\x0D\x0A
    2020-02-06T15:35:29.973Z DEBUG modem >> VOujw5H5SNz/0egwLX0tdHA114gk957EWW67c4cX8jJGKLhD+rcdqsq08p8kDi1L\x0D\x0A
    2020-02-06T15:35:29.986Z DEBUG modem >> 93FcXmn/6pUCyziKrlA4b9v7LWIbxcceVOF34GfID5yHI9Y/QCB/IIDEgEw+OyQm\x0D\x0A
    2020-02-06T15:35:29.999Z DEBUG modem >> jgSubJrIqg0CAwEAAaNCMEAwDwYDVR0TAQH/BAUwAwEB/zAOBgNVHQ8BAf8EBAMC\x0D\x0A
    2020-02-06T15:35:30.012Z DEBUG modem >> AYYwHQYDVR0OBBYEFIQYzIU07LwMlJQuCFmcx7IQTgoIMA0GCSqGSIb3DQEBCwUA\x0D\x0A
    2020-02-06T15:35:30.025Z DEBUG modem >> A4IBAQCY8jdaQZChGsV2USggNiMOruYou6r4lK5IpDB/G/wkjUu0yKGX9rbxenDI\x0D\x0A
    2020-02-06T15:35:30.040Z DEBUG modem >> U5PMCCjjmCXPI6T53iHTfIUJrU6adTrCC2qJeHZERxhlbI1Bjjt/msv0tadQ1wUs\x0D\x0A
    2020-02-06T15:35:30.053Z DEBUG modem >> N+gDS63pYaACbvXy8MWy7Vu33PqUXHeeE6V/Uq2V8viTO96LXFvKWlJbYK8U90vv\x0D\x0A
    2020-02-06T15:35:30.066Z DEBUG modem >> o/ufQJVtMVT8QtPHRh8jrdkPSHCa2XV4cdFyQzR1bldZwgJcJmApzyMZFo6IQ6XU\x0D\x0A
    2020-02-06T15:35:30.078Z DEBUG modem >> 5MsI+yMRQ+hDKXJioaldXgjUkK642M4UwtBV8ob2xJNDd2ZhwLnoQdeXeGADbkpy\x0D\x0A
    2020-02-06T15:35:30.092Z DEBUG modem >> rqXRfboQnoZsG4q5WTP468SQvvG5\x0D\x0A
    2020-02-06T15:35:30.105Z DEBUG modem >> -----END CERTIFICATE-----"\x0D\x0A
    2020-02-06T15:35:34.852Z ERROR Error: 'AT%CMNG=0,16842753,0,"-----BEGIN CERTIFICATE-----
    ' timed out
    2020-02-06T15:35:34.852Z INFO Updating client certificate...
    2020-02-06T15:35:34.854Z DEBUG modem >> AT%CMNG=0,16842753,1,"-----BEGIN CERTIFICATE-----\x0D\x0A
    2020-02-06T15:35:34.867Z DEBUG modem >> MIIDmDCCAoACCQCY4OeXLzXmgTANBgkqhkiG9w0BAQsFADCBizELMAkGA1UEBhMC\x0D\x0A
    2020-02-06T15:35:34.881Z DEBUG modem >> Tk8xDzANBgNVBAgMBk5vcndheTESMBAGA1UEBwwJVHJvbmRoZWltMR0wGwYDVQQK\x0D\x0A
    2020-02-06T15:35:34.894Z DEBUG modem >> DBROb3JkaWMgU2VtaWNvbmR1Y3RvcjE4MDYGA1UECwwvZWxpdmFnYXItcHJvZC1w\x0D\x0A
    2020-02-06T15:35:34.907Z DEBUG modem >> Y2ExMDA5MC11cC10by0xOTA5MDItdGhpbmctZ3JvdXAwIBcNMjAwMjA2MTUzMjUz\x0D\x0A
    2020-02-06T15:35:34.920Z DEBUG modem >> WhgPMjA1MDAxMjkxNTMyNTNaMIGNMQswCQYDVQQGEwJOTzESMBAGA1UECAwJVHJv\x0D\x0A
    2020-02-06T15:35:34.935Z DEBUG modem >> bmRlbGFnMRIwEAYDVQQHDAlUcm9uZGhlaW0xITAfBgNVBAoMGE5vcmRpYyBTZW1p\x0D\x0A
    2020-02-06T15:35:34.948Z DEBUG modem >> Y29uZHVjdG9yIEFTQTEcMBoGA1UEAwwTbnJmLTM1MjY1NjEwMDI5ODIyNjEVMBMG\x0D\x0A
    2020-02-06T15:35:34.963Z DEBUG modem >> A1UELhMMRDMwNDQzNDk2QzU0MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKC\x0D\x0A
    2020-02-06T15:35:34.980Z DEBUG modem >> AQEA0zCQvOgSOSlSr6jTle3Y8p3B7QPw0wEZBAChRZyiewiS+1G26XaKyvjF0NBQ\x0D\x0A
    2020-02-06T15:35:34.993Z DEBUG modem >> Vo8CWKO//jNvM0G8d1PYrbZA/LcSuADLaZUHxKZL4Yc+X2rjMj5WvVYkZ03WpBUg\x0D\x0A
    2020-02-06T15:35:35.005Z DEBUG modem >> vXYZs0/VolWErI7gewxWg9inOGUeZ/PC7MtF2cx45amuFQFmx+qLlbBTiC9FDhLE\x0D\x0A
    2020-02-06T15:35:35.018Z DEBUG modem >> gFVhChLZ0AbQpj0puv9nWNH9AjLJ/CEPTk3uK/6SmUWZp1uBVkCMCmG/DRhnDMWQ\x0D\x0A
    2020-02-06T15:35:35.031Z DEBUG modem >> SM0JyXv8HcxXWkGCKYCJT9LdMivNTMrid8z3dWXnyeAwcJEfHM852xiDnHLzgD1h\x0D\x0A
    2020-02-06T15:35:35.044Z DEBUG modem >> tWUvuDjt/AU4TOXjIhgSjD5XJwIDAQABMA0GCSqGSIb3DQEBCwUAA4IBAQBjLOl9\x0D\x0A
    2020-02-06T15:35:35.057Z DEBUG modem >> chNEtrRA0qW1urMA+0AoWd9CMA2h4rJnbgt4bq3NpzCae31Ho3owqMT9Di6SD3bU\x0D\x0A
    2020-02-06T15:35:35.071Z DEBUG modem >> IDGXa4iCWAlPBXWvnfp8ptTsWy4oSLDt7WaUraCAIq1oTK60sHytGdVIonDqgE/i\x0D\x0A
    2020-02-06T15:35:35.083Z DEBUG modem >> UjkHhkJee0BiCsJI+39x/85JZITrbHqKgfGtAp+k8vJ0WZ1lU3qAUkigZ2IAcMSR\x0D\x0A
    2020-02-06T15:35:35.097Z DEBUG modem >> LlG+uwYtDGXvgvU+gdzQTk3TsAHFteMVyeihbtttceDcgqsd1tt07VpBhJrftPfm\x0D\x0A
    2020-02-06T15:35:35.110Z DEBUG modem >> zyrt7XRv51BtszPU3q8zBadyfq8TbAelcXM5oKSOFrNhKnnkmnyWBs9C+kx5gmMl\x0D\x0A
    2020-02-06T15:35:35.123Z DEBUG modem >> 2shpiskZsaDbMUxZ\x0D\x0A
    2020-02-06T15:35:35.135Z DEBUG modem >> -----END CERTIFICATE-----\x0D\x0A
    2020-02-06T15:35:35.149Z DEBUG modem >> -----BEGIN CERTIFICATE-----\x0D\x0A
    2020-02-06T15:35:35.163Z DEBUG modem >> MIID6zCCAtOgAwIBAgIJAOJ1S6aVKTU5MA0GCSqGSIb3DQEBCwUAMIGLMQswCQYD\x0D\x0A
    2020-02-06T15:35:35.176Z DEBUG modem >> VQQGEwJOTzEPMA0GA1UECAwGTm9yd2F5MRIwEAYDVQQHDAlUcm9uZGhlaW0xHTAb\x0D\x0A
    2020-02-06T15:35:35.191Z DEBUG modem >> BgNVBAoMFE5vcmRpYyBTZW1pY29uZHVjdG9yMTgwNgYDVQQLDC9lbGl2YWdhci1w\x0D\x0A
    2020-02-06T15:35:35.205Z DEBUG modem >> cm9kLXBjYTEwMDkwLXVwLXRvLTE5MDkwMi10aGluZy1ncm91cDAeFw0xOTA5MTEy\x0D\x0A
    2020-02-06T15:35:35.218Z DEBUG modem >> MDIyMzJaFw0yMjA3MDEyMDIyMzJaMIGLMQswCQYDVQQGEwJOTzEPMA0GA1UECAwG\x0D\x0A
    2020-02-06T15:35:35.231Z DEBUG modem >> Tm9yd2F5MRIwEAYDVQQHDAlUcm9uZGhlaW0xHTAbBgNVBAoMFE5vcmRpYyBTZW1p\x0D\x0A
    2020-02-06T15:35:35.244Z DEBUG modem >> Y29uZHVjdG9yMTgwNgYDVQQLDC9lbGl2YWdhci1wcm9kLXBjYTEwMDkwLXVwLXRv\x0D\x0A
    2020-02-06T15:35:35.257Z DEBUG modem >> LTE5MDkwMi10aGluZy1ncm91cDCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoC\x0D\x0A
    2020-02-06T15:35:35.270Z DEBUG modem >> ggEBAKVQUxx5Mr5j0o0m5vCT3VTOeJkhMR/n/SnRPw5LEuh+xoj9jmvdvVru+Zex\x0D\x0A
    2020-02-06T15:35:35.283Z DEBUG modem >> O+bNmO2fLwtvY9riHtbRzDqtZLXOK/zh+WegXwag/DWlGoEiLBbTFx381CSYhfC6\x0D\x0A
    2020-02-06T15:35:35.296Z DEBUG modem >> A/zggO23MqG13AhrTAe21NNfeo+txfnIRWcejtpNN9m25OSxkspf6HkF/HM2k0uW\x0D\x0A
    2020-02-06T15:35:35.311Z DEBUG modem >> BQ0gqn+79sTE/nPjGlfPfKuzvBcewq+d3RGD5TI6QScFWROLcIOVvganrzaLcyvH\x0D\x0A
    2020-02-06T15:35:35.324Z DEBUG modem >> aXp5ziZVh1ua4xd8tqP7lEMJ7WYnULOeI4WtmGLang1Jetop5texL10Qf//A21Sd\x0D\x0A
    2020-02-06T15:35:35.337Z DEBUG modem >> EKffY02DScl2Fz1qBIW5hta9kw0CAwEAAaNQME4wHQYDVR0OBBYEFCgV8zFptKka\x0D\x0A
    2020-02-06T15:35:35.351Z DEBUG modem >> +po7vD/vWK0/d45wMB8GA1UdIwQYMBaAFCgV8zFptKka+po7vD/vWK0/d45wMAwG\x0D\x0A
    2020-02-06T15:35:35.363Z DEBUG modem >> A1UdEwQFMAMBAf8wDQYJKoZIhvcNAQELBQADggEBAIyehD2N0DhmA8XqzBEJ5B+i\x0D\x0A
    2020-02-06T15:35:35.377Z DEBUG modem >> QVwET3p1u4o3QPJZD7WfXEjs9lZqqZ+vSVW7LnLm61DEF6CGDTsNMmB/UrvFQyG8\x0D\x0A
    2020-02-06T15:35:35.391Z DEBUG modem >> KTpVzrQXnzpS501dHiK/CXRx2sI0pw6kmp+DGxl2EnQe5OcO4unx5mTHaDO0OfUS\x0D\x0A
    2020-02-06T15:35:35.403Z DEBUG modem >> NEKXyA+1y4Zl83KdGHdLTLjjyVQF37f19l9dJWJOmd26xUeE3rTM9DxFZS4fK8sw\x0D\x0A
    2020-02-06T15:35:35.417Z DEBUG modem >> Ugba5mceth9JPNhWnPCi/bGmhe3FnqI80wGzY37RSri/o4feUOqWT7K70Dq75IVa\x0D\x0A
    2020-02-06T15:35:35.431Z DEBUG modem >> R/655p1KKdN0qxFCutBH155kvYXMMmr9wgX9A98KxtjnaYUQxNyzOGZfG4yuFHE=\x0D\x0A
    2020-02-06T15:35:35.443Z DEBUG modem >> -----END CERTIFICATE-----"\x0D\x0A
    2020-02-06T15:35:39.855Z ERROR Error: 'AT%CMNG=0,16842753,1,"-----BEGIN CERTIFICATE-----
    2shpiskZsaDbMUxZ
    ' timed out
    2020-02-06T15:35:39.855Z INFO Updating private key...
    2020-02-06T15:35:39.861Z DEBUG modem >> AT%CMNG=0,16842753,2,"-----BEGIN RSA PRIVATE KEY-----\x0D\x0A
    2020-02-06T15:35:39.875Z DEBUG modem >> MIIEpQIBAAKCAQEA0zCQvOgSOSlSr6jTle3Y8p3B7QPw0wEZBAChRZyiewiS+1G2\x0D\x0A
    2020-02-06T15:35:39.888Z DEBUG modem >> 6XaKyvjF0NBQVo8CWKO//jNvM0G8d1PYrbZA/LcSuADLaZUHxKZL4Yc+X2rjMj5W\x0D\x0A
    2020-02-06T15:35:39.902Z DEBUG modem >> vVYkZ03WpBUgvXYZs0/VolWErI7gewxWg9inOGUeZ/PC7MtF2cx45amuFQFmx+qL\x0D\x0A
    2020-02-06T15:35:39.915Z DEBUG modem >> lbBTiC9FDhLEgFVhChLZ0AbQpj0puv9nWNH9AjLJ/CEPTk3uK/6SmUWZp1uBVkCM\x0D\x0A
    2020-02-06T15:35:39.929Z DEBUG modem >> CmG/DRhnDMWQSM0JyXv8HcxXWkGCKYCJT9LdMivNTMrid8z3dWXnyeAwcJEfHM85\x0D\x0A
    2020-02-06T15:35:39.943Z DEBUG modem >> 2xiDnHLzgD1htWUvuDjt/AU4TOXjIhgSjD5XJwIDAQABAoIBAQCEcVST48Zp6qxc\x0D\x0A
    2020-02-06T15:35:39.956Z DEBUG modem >> VTg8Mml33c+cYHhLG8kgZXS+Pzj2h64Fxn07dIgeOl10Uu/PGOiTxj3FoWP/dR5I\x0D\x0A
    2020-02-06T15:35:39.969Z DEBUG modem >> h2C/sCiZVAZ9NqJamIfCn7e+vB41oMbS351uJ/O0hXAyfr2Fk+cSOOL1Z0RJI2FM\x0D\x0A
    2020-02-06T15:35:39.982Z DEBUG modem >> SbSIAvr7tw6WipyX+/LWYBEBlqQBrzdLMuYWRwpXPQT1HE8t8m70X0oRHCqRwjsd\x0D\x0A
    2020-02-06T15:35:39.995Z DEBUG modem >> soyY+IOa0SvNXsETq/A5UWO/XdonwV+s6LPqkdKmw0zmM3iBbt1OHJ02V1q5A+/x\x0D\x0A
    2020-02-06T15:35:40.008Z DEBUG modem >> uVkivgGdS4fLSxrC5H8nwH4krg3h/Sj4c7PGzDQlVbSekQfZK/kj46ZYtVoYmgCu\x0D\x0A
    2020-02-06T15:35:40.022Z DEBUG modem >> BxR2cRxhAoGBAPTJDm2B2zV0Ar39bOKzxTm4+QpddsHAY7gyrWWAdms1PuDM7pwe\x0D\x0A
    2020-02-06T15:35:40.036Z DEBUG modem >> /LKkm9mdgNvalT/xPuc9fwAzYe4QKUmqbdkFLYJFZ9AFIXdolf7A3M92Gn1YbK3+\x0D\x0A
    2020-02-06T15:35:40.050Z DEBUG modem >> aAAs6+ikoHFGYCHJeDgQWG9H3tSB+1zBokx6bc1WwA0ebN8JkESHuX/1AoGBANzd\x0D\x0A
    2020-02-06T15:35:40.064Z DEBUG modem >> fDZWUrv5kaF8hXdMimSD3QDAYf4eQGk8fn2mZYHI1kVUGt2Bms6EwnBTu5zzvoKu\x0D\x0A
    2020-02-06T15:35:40.076Z DEBUG modem >> oJ7GhYgPHjhZKrJ4KAlx83dcPQ6RZwsXj9u6/bNF8HFfaLTMUMwN52ks/w1Fxy7F\x0D\x0A
    2020-02-06T15:35:40.090Z DEBUG modem >> ftgrK743EWF23ECI5xMUJ+V+2ndCYQo5hOyNw9UrAoGBAOLqsw4+z8gIiDY5hMPP\x0D\x0A
    2020-02-06T15:35:40.103Z DEBUG modem >> ZKhy2aKLK/jGcWqix+0NHjmZ/XUFZLijXRv5zmP4RykHw02oROi2MFIuT70RjES2\x0D\x0A
    2020-02-06T15:35:40.116Z DEBUG modem >> 0efZjetyjZ7f8rsv38RuYwOK91l1LCJLcXugKPzcB8OaOql3i5NlS6W1GVMkP7En\x0D\x0A
    2020-02-06T15:35:40.130Z DEBUG modem >> 6108LSeqIJTIvKIxymRM8WA1AoGALgMCPnurTrfGTAMZ9ul+J0SFRQPPJlZ9Cq9s\x0D\x0A
    2020-02-06T15:35:40.143Z DEBUG modem >> lpaUrP3/DYBg/GZkrsNfknEPM7pfpO/mTE2FQfwMSqbgyz9W7+jKVMJlgeRuuBPX\x0D\x0A
    2020-02-06T15:35:40.157Z DEBUG modem >> h2okMjXOyn+a25d4+Zmn7PRPyh8QSMEiFLyhp0XnnAtcBSHAKexYB2pu7stoVe33\x0D\x0A
    2020-02-06T15:35:40.169Z DEBUG modem >> sCQ0ePMCgYEA3nHCYdPNUXlKFIxm1XJELtd6ZB5i96jJ3z9aaHUkVUuHFiOeHfuR\x0D\x0A
    2020-02-06T15:35:40.190Z DEBUG modem >> DdyymB0hdkoCssee7luFuxuZ9qz9J4uli++RmvxbqHGs9i/I8CH7zWc1xSq8VqPa\x0D\x0A
    2020-02-06T15:35:40.202Z DEBUG modem >> RUnzKCW/DvNt4Mid3bVHLF5H8WJisQUOsuDMiRhmDxlvGiKgiC4NDUY=\x0D\x0A
    2020-02-06T15:35:40.216Z DEBUG modem >> -----END RSA PRIVATE KEY-----"\x0D\x0A
    2020-02-06T15:35:44.862Z ERROR Error: 'AT%CMNG=0,16842753,2,"-----BEGIN RSA PRIVATE KEY-----
    ' timed out
    2020-02-06T15:35:44.862Z INFO Certificate update completed
