We have our SCL line on P0.10 (NFC2) and SDA P0.23
When I try to start a I2C transaction nothing happens, and NRF_TWIM0->TXD.AMOUNT = 0. I have verified that SDA/SCL are pulled high.
However, I can run the same code changing the pins to P0.26, P0.27 as on the 52833-DK and I get an ERROR event with NRF_TWIM0->ERRSRC = 2, which is what you would expect with no devices on the bus.
I then tried the experiment on the 52833-DK, setting up GPIO pullups on SDA/SCL and got exactly the same results based on pin numbers.
We do not use NFC, and I have verified that the NFC module is not enabled in an emulator. Is there a restriction on using the NFC lines for I2C?
Mark
