mesh_stack_config_clear() changed behaviour with SDK For Mesh v4.0.0
The following change was introduced in v4.0.0
 void mesh_stack_config_clear(void)
-    mesh_config_clear();
+    mesh_opt_clear();
     access_clear();
     dsm_clear();
     net_state_reset();
-    // invoking of the function was moved to the top.
-    // It causes assertion with the flash manager substates
-    // it is known issue MBTLE-1972
-    // TODO Return this string back after flash manager fixing
-    // mesh_config_clear();
Note that mesh_config_clear() was replaced with mesh_opt_clear() which is a rather big change of behavior that wasn't documented in neither RELEASE_NOTES.md nor MIGRATION_GUIDE.md.
The consequence of this change is that any user settings (stored with mesh_config) that was previously erased are now kept. Thus sending a "Config Node Reset" to a node no longer erases all configuration but only those internal to the mesh stack.
