Serial DFU is failing with invalid response
Hi there,
I'm struggling to get a DFU over serial done. I'm using a nRF52840-DK (PCA10056), the nRF-SDK 15.0 and nrfutil 3.5.0.
I
- genereated the key pair,
- built the secure-bootloader (pca10056_uart_debug) example with my generated public_key.c,
- built the ble_app_blinky (pca10056, s140),
- programmed the s140 v 6.0.0 SoftDevice (chiperase),
- programmed the bootloader (sectorerase) and
- generated DFU package from the ble_app_blinky.hex (sd-req 0xA9) with my private key
When I perform the DFU with nrfutil i get the following error message:
pc_ble_driver_py.exceptions.NordicSemiException: Unexpected Executed OP_CODE.
Expected: 0x03 Received: 0x1D
Further analysis reveal that after the first firmware package is transfered, the host sends a CRC request [0x03] and the answer is [0x60, 0x1D, 0x02].
I have no idea why this is failing or what the response code [0x1D] means.
I would appreciate any help on that matter.
Iven Kolterjahn
  • Hi Einar,
    debugging doesn't seem to work here. When I try to debug the code in SES the whole DFU process just hangs. I see some communication in the debug console, but then it just stops (SES seems to freeze also). SES starts responding after I unplugged the nRF-Board.
    This is the output of the SES debug console:
    <info> app: Inside main
    <debug> app: In nrf_bootloader_init
    <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
    <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
    <debug> app: Enter nrf_bootloader_fw_activate
    <info> app: No firmware to activate.
    <debug> app: Enter nrf_dfu_app_is_valid
    <debug> app: Return false in valid app check
    <debug> app: DFU mode because app is not valid.
    <info> nrf_bootloader_wdt: WDT is not enabled
    <debug> app: in weak nrf_dfu_init_user
    <info> app_timer: RTC: initialized.
    <info> app: Entering DFU mode.
    <debug> app: Initializing transports (found: 1)
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init()
    <debug> nrf_dfu_serial_uart: serial_dfu_transport_init() completed
    <debug> app: Enter main loop
    <debug> app: Shutting down transports (found: 1)
    <debug> nrf_dfu_serial: Received ping 1
    <info> nrf_dfu_serial_uart: Allocated buffer 200033AC
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_PING
    <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
    <debug> nrf_dfu_serial: Sending Response: [0x9, 0x1]
    <debug> nrf_dfu_serial: Set receipt notif target: 0
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
    <debug> nrf_dfu_serial: Sending Response: [0x2, 0x1]
    <debug> nrf_dfu_serial: Received serial mtu
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_MTU_GET
    <debug> nrf_dfu_serial: Sending Response: [0x7, 0x1]
    *** HERE IT FREEZES. THE LINES BELOW APPEAR AFTER THE DISCONNECT ***
    <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
    <debug> nrf_dfu_serial: Sending Response: [0x6, 0x1]
    I tried using the SDK 16.0.0 with nrfutil v6.0.1, but this also does not work. Strangely here I get 0xB3 as response (instead of 0x1D) to the CRC request.
    This is odd. I have never seen a similar issue before, and do not see a good explanation. It would be good to narrow down this problem a bit.
    • Do you see this issue if you use a precompiled bootloader example and example .zip file?
    • What if you test with nrfutil 5.2.0?
    • If it still fails with precompiled bootloader and example .zip files, can you get a trace of the actual UART signal and see what happens. Where does the invalid request code come from?
    Also, you should be aware that there are problems with J-Link on Linux, as described here. That may or may not be related (probably not since you write you see the same behavior when Windows is the DFU master).
    I'm not sure, if I might be doing something basic the wrong way. I tried the example located at "SDK_16.0\examples\dfu\secure_dfu_test_images\uart\nrf52840".
    The following commands were used to flash the chip:
    nrfjprog -f NRF52 --program softdevice_s140.hex --chiperase
    nrfjprog -f NRF52 --program hrs_application_s140.hex --sectorerase
    nrfjprog -f NRF52 --program mbr.hex --sectorerase
    nrfjprog -f NRF52 --program bootloader_secure_uart_debug_without_bonds_mbr.hex --sectoranduicrerase
    nrfjprog -f NRF52 --program blinky_mbr.hex --reset --sectoranduicrerase
    After it's all done LEDs 1 and 4 are on and nothing more can be seen - no blinking, no reaction on button presses.
    Performing the DFU with nrfutil v6.0.1 now fails with response 0xF5 on the CRC request. The same is with v5.2.0.
    All this is performed on a Windows 7 x64 machine.
  • Alright, it was the JLink issue posted in your link. I did the 'MSDDisable' command in "JLink Commander". After that i could perform a DFU.
