Serial DFU is failing with invalid response
Hi there,
I'm struggling to get a DFU over serial done. I'm using a nRF52840-DK (PCA10056), the nRF-SDK 15.0 and nrfutil 3.5.0.
I
- genereated the key pair,
- built the secure-bootloader (pca10056_uart_debug) example with my generated public_key.c,
- built the ble_app_blinky (pca10056, s140),
- programmed the s140 v 6.0.0 SoftDevice (chiperase),
- programmed the bootloader (sectorerase) and
- generated DFU package from the ble_app_blinky.hex (sd-req 0xA9) with my private key
When I perform the DFU with nrfutil i get the following error message:
pc_ble_driver_py.exceptions.NordicSemiException: Unexpected Executed OP_CODE.
Expected: 0x03 Received: 0x1D
Further analysis reveal that after the first firmware package is transfered, the host sends a CRC request [0x03] and the answer is [0x60, 0x1D, 0x02].
I have no idea why this is failing or what the response code [0x1D] means.
I would appreciate any help on that matter.
Iven Kolterjahn
  • Hi . Iven,
    Can you post the full command you used to generate the DFU package and the full command you used to do the DFU operation? (In case there is no problem there, have you attempted to use a newer nrfutil version?)
  • Hi Einar,
    nrfutil pkg generate --hw-version 52 --application-version 1 --application ble_app_blinky_pca10056_s140_1.hex --sd-req 0xA9 --key-file demo_private.key
    DFU operation:
    nrfutil dfu serial -pkg app_fw1.zip -p /dev/ttyACM0 -b 115200
    The thing is, in the end I'll use an ARM-based processor running Linux and utilizing the UartSecureDFU from Jimmy Wong. It is based upon the nrfutil v3.5.0. I generate the Linux using Yocto and got some trouble including the nrfutil as a python application. So, I found JW's C application.
  • I see.
    Going back at the reply from the CRC request is (first to last byte):
    1. 0x60: NRF_DFU_OP_RESPONSE (0x60)
    2. 0x1D: unknown request code
    3. 0x02. NRF_DFU_RES_CODE_OP_CODE_NOT_SUPPORTED
    So as you pointed out, the request code (0x1D in this case) seems wrong, as it is not part of the supported codes (refer to <SDK>/components/libraries/bootloader/dfu/nrf_dfu_req_handler.h).
    Is this test is done with an unmodified nrfutil 3.5.0 or with some modifications? Could it be that there is a problem with the request from the DFU master? Have you checked on the UART line what is actually being sent?
  • I used the pre-compiled binary (.exe) supplied on GitHub (pc-nrfutil, v3.5.0) to generate the packages on a Windows machine. The reference DFU operation took place on an Ubuntu machine with nrfutil (v3.5.0) installed via the setup.py.
    According to the CLI output from UartSecureDFU it sends 0x03 (NRF_DFU_OP_CRC_GET). The output of nrfutil was as mentioned above "... Expected: 0x03 Received: 0x1D". I haven't checked manually what is sent via USB though. On the other hand, both programs seem to get the same response from the DevKit.
    Here is the CLI output of UartSecureDFU (values are decimal):
    UartSecureDFU ttyACM0 ./app_uart_fw1.zip -v -v -v
    Sending Application image.
    SLIP: --> [9, 1]
    SLIP: <-- [96, 9, 1, 1]
    Set Packet Receipt Notification 0
    SLIP: --> [2, 0, 0]
    SLIP: <-- [96, 2, 1]
    SLIP: --> [7]
    SLIP: <-- [96, 7, 1, 131, 0]
    Sending init packet...
    Selecting Object: type:1
    SLIP: --> [6, 1]
    SLIP: <-- [96, 6, 1, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]
    Object selected:  max_size:256 offset:0 crc:0x00000000
    SLIP: --> [1, 1, 135, 0, 0, 0]
    SLIP: <-- [96, 1, 1]
    Streaming Data: len:135 offset:0 crc:0x00000000
    SLIP: --> [8, 18, 132, 1, 10, 62, 8, 1, 18, 58, 8, 1, 16, 52, 26, 2, 169, 1, 32, 0, 40, 0, 48, 0, 56, 160, 171, 1, 66, 36, 8, 3, 18, 32, 193, 220, 134, 164, 132, 220, 167, 77, 51, 250, 203, 217, 25, 23, 53, 71, 57, 112, 210, 94, 255, 134, 96, 21, 97, 179, 134, 38, 38, 253, 29]
    SLIP: --> [8, 52, 72, 0, 16, 0, 26, 64, 238, 16, 46, 112, 45, 1, 144, 12, 16, 227, 209, 254, 152, 11, 203, 53, 147, 83, 159, 170, 244, 112, 239, 1, 18, 100, 180, 164, 86, 198, 202, 1, 202, 72, 251, 111, 128, 16, 28, 103, 222, 77, 176, 28, 179, 204, 241, 144, 89, 82, 29, 10, 237, 127, 252, 178, 42]
    SLIP: --> [8, 87, 127, 228, 229, 216, 175, 118]
    SLIP: --> [3]
    SLIP: <-- [96, 29, 2]
    Invalid response!
    I see. So everything looks OK until the bootloader complains about the unsupported OP_CODE, which was never transmitted by nrfutil in the first place. I think we need to look at what happens in the bootloader.
    Perhaps the best would be to put a breakpoint in the NRF_DFU_OP_CRC_GET case in nrf_dfu_data_req() in <SDK>components\libraries\bootloader\dfu\nrf_dfu_req_handler.c. Does it get this far? If not, what happens? If the request is correctly received, how is it processed? How does it result in the error response?
