System event handler SDK16, S212
I'm trying to register a handler to determine when a system event occurs?
Previously on older design kits, I used softdevice_sys_evt_handler_set(......) to register the handler and trying to do the same using SDK16.
I tried using NRF_SDH_STATE_OBSERVER and NRF_SDH_STACK_OBSERVER  but it prevents my application from running.
For example if I include it after
NRF_SDH_ANT_OBSERVER(m_ant_observer, XXX_OBSERVER_PRIO,
XXX_sens_evt_handler, &m_ant_XXX);
 the application ceases to run.
Is there an example on how to register an event to get notified when a system event occurs? I  am not expert on interrupts and can't seem to find any examples on how to do it.
I was able to use SD_EVT_IRQHandler but now it gives an error that it is multiply defined as more utilities are added.
Thank you
