Disable notification/permission to pair in NRF52
In-app when you scan for device and after it is found you press the connect and then the notification/permission to pair pops out. Our app developers are saying that we must disable this notification in our firmware, but I can't find any similar settings in nRF SDK. If I connect to the device from nRF connect I don't see any notification/permission to pair.
Can we disable notification/permission to pair in firmware or not?
Thanks for help
Blaz
    From log TX report I see that problem is in pm_conn_secure():
    <debug> peer_manager_handler: Connected, securing connection. conn_handle: 0
    <info> app: Connected
    <error> peer_manager_handler: Asserting. pm_conn_secure() returned NRF_ERROR_NOT_FOUND on conn_handle 0.
    <error> app: Fatal error
    <warning> app: System reset
    <info> app: Device turned on
    <info> app: m_whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
    <debug> app: pm_whitelist_get returns 0 addr in whitelist and 0 irk whitelist
    <info> app: Fast advertising.
    I don't know how to disable   Peer Manager event handler. Even if the function is empty the _conn_secure function starts in the background.
    But if I don't initialize the peer_manager_init() then device won't start:
    I see in Blinky example that the  peer_manager_init()  is not used and no paring no bonding is working fine. I don't understand why the device has: <error> app: Fatal error if the  peer_manager_init() is not initialized.
    This request to change come from the customer yesterday and we must start the mass production on Monday.  We are under enormous time pressure so please help me out.
    Thank you for help,
    Blaz
  • If you don't use bond and pair, you do not need to use peer_manager. Blinky example is a good example without that. If you want to modify a bond example to no-bond, HRS example might help you know that.
    What is your development purpose?
    -Amanda H
  • The problem is that the whole project was build form the beginning for bonding and pairing. Now the customer has changed his requirements to no pairing no bonding. I don't have time to build the project from scratch this is why I am searching for a solution on how to disable peering and bonding in the existing projects.
    Do you maybe now why this happens if I don't use peer_manager:
    The device is in reset all the time.
    If I disable the peer manager in sdk_config.h I get a lot of errors because of the functions used in a project were built-in.
    #ifndef PEER_MANAGER_ENABLED
    #define PEER_MANAGER_ENABLED 0
    The device is a massage gun with custom characteristics that can be controlled with mobile app.
    Blaz
  • You don't need to remove or disable PEER_MANAGER.
    I tried to comment on peer_manager_init(); or  pm_sec_params_set() for no bonding in the HRS example, and it still can work.
    -Amanda H.
    I have copied the following functions from HRS to our APP:
    - on_adv_evt(ble_adv_evt_t ble_adv_evt)
    - ble_evt_handler(ble_evt_t const * p_ble_evt, void * p_context)
    -  pm_evt_handler(pm_evt_t const * p_evt)
    I delited the our delete_bonds() and whitelist_set() form the code. Now the app is working with no paring and no bondig the peer_manager_init(); is commented.
    Now I have a problem that our custom characteristics are not reacting to any commands.
    I check in the code and I didn't find any connection between parring and custom characteristic.
    Do you have any advice, where should be the problem :)
    Blaz
