Disable notification/permission to pair in NRF52
In-app when you scan for device and after it is found you press the connect and then the notification/permission to pair pops out. Our app developers are saying that we must disable this notification in our firmware, but I can't find any similar settings in nRF SDK. If I connect to the device from nRF connect I don't see any notification/permission to pair.
Can we disable notification/permission to pair in firmware or not?
Thanks for help
Blaz
  • Hi Blaz,
    Could you provide the error log on both sides?
    In the segger project, you can enable log in the sdk_cofig.h and compile with the debug mode.
    -Amanda H.
  • Dear Amanda,
    Thank you for your prompt support. Because of big changes in code, which will be very risky at this moment, the customer has decided that we go back to paring and bonding.
    In the next version, we will implement no preparation, no bonding. In our custom characteristic, we have the following properties:
    RLX_VIBRATION_LEVEL_CHAR_UUID     0x456b    notify-read/write
    RLX_MOTOR_CURRENT_CHAR_UUID    0x456c    notify-read
    RLX_CHRG_CURRENT_CHAR_UUID       0x456d    notify-read
    RLX_TEMP_CHAR_UUID                           0x456e    notify-read
    RLX_BAT_VOLTAGE_UUID                        0x456f    notify-read
    RLX_TEST_CHAR_UUID                            0x4570   notify-read/write
    RLX_PRESSURE_LEVEL_CHAR_UUID    0x4571   notify-read
    From which example it will be the best to start if we want to build up the app from scratch wit no paring no bonding. Do you think the blinky example is most appropriate?
    The current application was not built by us we got it from customer and some other developers were developing it. Now we would like to build it again the right way.
    Blaz
  • Hi Blaz,
    We usually suggest starting from the Template Application example which doesn't use encrypted characteristics, so the mobile won't pop up a window to ask pairing or bonding. Users could use service under bond or no-bond. The blinky example does not use the peer manager library and bond/pair. It might be a good example to fit your requirements.
    -Amanda H.
  • Dear Amanda,
    Unfortunately, we have new problems. We have discovered that on apple we have some problems with connections. For example, if we use nRF connect on the android or desktop version we can connect without any problems. Here is the log of connection:
    <debug> peer_manager_handler: Connected, securing connection. conn_handle: 0
    <info> app: Connected
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_PARAMS_REQ
    <debug> peer_manager_handler: Security parameter request
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_START
    <debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Pairing
    <debug> peer_manager_handler: Event PM_EVT_CONN_SEC_SUCCEEDED
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Pairing
    <info> app: PM_EVT_CONN_SEC_SUCCEEDED Event
    <debug> peer_manager_handler: Event PM_EVT_LOCAL_DB_CACHE_APPLIED
    <debug> peer_manager_handler: Previously stored local DB applied: conn_handle: 0, peer_id: 6553
    If we use nRF connect on the apple phone the first time we connect the connection is established then it is disconnecting and after we do reconnect it is connected without any problems.  Here is the log.
    <debug> app: PHY update request.
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    <debug> nrf_ble_gatt: Updating data length to 27 on connection 0x0.
    <debug> nrf_ble_gatt: Data length updated to 27 on connection 0x0.
    <debug> nrf_ble_gatt: max_rx_octets: 27
    <debug> nrf_ble_gatt: max_tx_octets: 27
    <debug> nrf_ble_gatt: max_rx_time: 2120
    <debug> nrf_ble_gatt: max_tx_time: 2120
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 293 bytes.
    <debug> nrf_ble_gatt: Updating ATT MTU to 23 bytes (desired: 23) on connection 0x0.
    <debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Bonding
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
    <debug> peer_manager_handler: Event PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
    <info> app: New Bond, add the peer to the whitelist if possible
    <info> app: 	m_whitelist_peer_cnt 2, MAX_PEERS_WLIST 8
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
    <debug> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
    <debug> app: pm_whitelist_get returns 1 addr in whitelist and 1 irk whitelist
    <info> app: Fast advertising with whitelist.
    <info> app: Disconnected
    @@@@@@@@@@@@@@@@@@@   Reconect    @@@@@@@@@@@@@@@@@@@@@@
    <debug> peer_manager_handler: Event PM_EVT_BONDED_PEER_CONNECTED
    <debug> peer_manager_handler: Previously bonded peer connected: role: Peripheral, conn_handle: 0, peer_id: 0
    <info> app: PM_EVT_BONDED_PEER_CONNECTED Event
    <debug> peer_manager_handler: Previously stored local DB applied: conn_handle: 0, peer_id: 0
    <debug> peer_manager_handler: Connection security procedure started: role: Peripheral, conn_handle: 0, procedure: Encryption
    <info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
    <debug> peer_manager_handler: Already encrypted, skipping security.
    I don't understand why the app disconnects only the first time and only on apple devices?
    Thank you for help,
    Blaz
    Could you print the disconnect reason by adding the following code?
    NRF_LOG_INFO("Disconnected, reason %d.",
    p_ble_evt->evt.gap_evt.params.disconnected.reason);
    -Amanda H.
