ble_app_uart & peripheral/timer example ends in assert_nrf_callback -->app_error_handler
Hey guys,
I'm working with a Laird BL652-DVK (nrF 52832 - chip), Nordic SDK v.14.2.0 and SES (Segger Embedded Studio v.4.30). I'm working with the ble_peripheral example ble_app_uart and everything is fine and working. Now I want to use a timer event like peripheral/example "timer". This peripheral example is working separatly. But when put the timer code into ble_app_uart code I'm ending up in function "assert_nrf_callback" through followed assert in  nrf_drv_timer.c:
#ifdef SOFTDEVICE_PRESENT
    ASSERT(p_instance->p_reg != NRF_TIMER0);
timer code:
 * @brief Handler for timer events.
void timer_led_event_handler(nrf_timer_event_t event_type, void* p_context)
    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE0:
            nrf_gpio_pin_toggle(LED1);
            //Do nothing.
static void timer_event_init(void)
    uint32_t time_ms = 200; //Time(in miliseconds) between consecutive compare events.
    uint32_t time_ticks;
    uint32_t err_code = NRF_SUCCESS;
    nrf_gpio_cfg_output(LED1);
    //Configure TIMER_SEND_DATA for generating simple light effect - leds on board will invert his state one after the other.
    err_code = nrf_drv_timer_init(&TIMER_SEND_DATA, &timer_cfg, timer_led_event_handler);
    time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_SEND_DATA, time_ms);
    nrf_drv_timer_extended_compare(
         &TIMER_SEND_DATA, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
    ...  //inits
    timer_event_init();
Assert nrf callback:
/**@brief Function for assert macro callback.
 * @warning This handler is an example only and does not fit a final product. You need to analyse
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
I hope, someone can help.
Thanks in advance,
Christoph
