HTTP send errno -1163019603
Dear Community;
I am using this code provided by a Nordic engineer to make some HTTP request in order to use Telegram Bot API. It works fine but after 1-2 days working I am getting an error at this part of the code:
int num_bytes = send(client_fd, send_buf, send_data_len, 0);
if (num_bytes < 0) {
	printk("send errno: %d\n", errno);
	goto clean_up;
This is the error: "send errno: -1163019603"
The problem is that after first time this happens never recovers its normal functionality.
What is causing this error? How can be solved?
Any idea or suggestion is welcomed. Thanks.
     * Copyright (c) 2019 Nordic Semiconductor ASA
     * SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
    #include <zephyr.h>
    #include <net/socket.h>
    #include <stdio.h>
    #include <drivers/uart.h>
    #include <string.h>
    #include <lte_lc.h>
    /*#define HTTP_HOST "google.com"*/
    #define HTTP_HOST "api.telegram.org"
    #define HTTP_PORT 443
    #define RECV_BUF_SIZE 8192
    char recv_buf[RECV_BUF_SIZE + 1];
    void app_http_start(void)
    	struct sockaddr_in local_addr;
    	struct addrinfo *res;
    	struct addrinfo hints;
    	hints.ai_flags = 0;
    	hints.ai_family = AF_INET;
    	hints.ai_socktype = SOCK_STREAM;
    	hints.ai_protocol = 0;
    	local_addr.sin_family = AF_INET;
    	local_addr.sin_port = htons(HTTP_PORT);
    	local_addr.sin_addr.s_addr = 0;
    	printk("HTTP example\n\r");
    	int err = getaddrinfo(HTTP_HOST, NULL, &hints, &res);
    	if (err) {
    		printk("getaddrinfo errno %d\n", errno);
    		/* No clean up needed, just return */
    		return;
    	((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
    	char send_buf[] =
    		"GET /bot669648316:AAEFvydDWp1fSMbUrx00bBv-9dZptEfu3gU/sendMessage?chat_id=418166911&text=Test HTTP/1.1\r\n"
    		"Host: api.telegram.org\r\n"
    		"Connection: close\r\n\r\n";
    	/*char send_buf[] =
    		"GET / HTTP/1.1\r\n"
    		"Host: www.google.com:443\r\n"
    		"Connection: close\r\n\r\n";*/
    	int send_data_len = strlen(send_buf);
    	int client_fd = socket(AF_INET, SOCK_STREAM, IPPROTO_TLS_1_2);
    	enum {
    		NONE = 0,
    		OPTIONAL = 1,
    		REQUIRED = 2,
    	int verify = OPTIONAL;
    	err = setsockopt(client_fd, SOL_TLS, TLS_PEER_VERIFY, &verify,
    			 sizeof(verify));
    	if (err) {
    		printk("setsockopt err: %d\n", errno);
    	err = connect(client_fd, (struct sockaddr *)res->ai_addr,
    		      sizeof(struct sockaddr_in));
    	if (err > 0) {
    		printk("connect err: %d\n", errno);
    		goto clean_up;
    		goto clean_up;
    	int tot_num_bytes = 0;
    	do {
    		/* TODO: make a proper timeout *
    		 * Current solution will just hang
    		 * until remote side closes connection */
    		num_bytes = recv(client_fd, recv_buf, RECV_BUF_SIZE, 0);
    		tot_num_bytes += num_bytes;
    		if (num_bytes <= 0) {
    			printk("\nrecv errno: %d\n", errno);
    		printk("%s", recv_buf);
    	} while (num_bytes > 0);
    	printk("\n\rFinished. Closing socket");
    clean_up:
    	freeaddrinfo(res);
    	err = close(client_fd);
    static void modem_configure(void)
    	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
    		/* Do nothing, modem is already turned on and connected. */
    	} else {
    		int err;
    		printk("Establishing LTE link (this may take some time) ...\n");
    		err = lte_lc_init_and_connect();
    		__ASSERT(err == 0, "LTE link could not be established.");
    		printk("LTE connection established.\n");
    	int err1;
    	while (1){
    	    printf("\nStarting HTTPS test.\n");
    	    modem_configure();
                k_sleep(1000);
    	    app_http_start();
    	    if ( (err1 = lte_lc_offline() ) ){
    	      printk( "Failure turning off Modem: %d\n", err1 );
    	    else{
    	      printk("Modem turned off.\n");
    	    k_sleep(1000);
    Hello;
    I have made some test with the NRF9160 DK:
    I have updated to v2.1.99-ncs1-rc1 from v1.4.99 I think. After that "-1163019603" Errno disappeared and now I get "22" errno. The only change I have needed to make is to comment "#CONFIG_NET_RAW_MODE=y" line in prj.conf.
    Do we know what does errno "22" mean?
    I will attach here my code to send a Telegram message. Can anyone try to run it? It is not necessary to make any change. If so, the code should send a message to my telegram account.
    Thanks for your support.
  • Some error codes are in the file errno.h,   errno = 22 is EINVAL, or Invalid argument.
    After editing prj.conf you have to close the project in Segger, then delete the build directory, then import the project again.  The reason is that when a project is imported prj.conf is read in order to generate other files.  If  deleting the build directory and re-importing the project is not done then changes to prj.conf  will not take affect, This is a bug in the build procedure.
  • I always close the project and the Segger Studio before applying any change to prj.conf and clean build directory.
    Concerning to Errno 22, that means Invalid Argument, I can't understand why it fails because it worked fine for 1-2 days.
    I will wait for a Nordic Engineer answer or to someone that tests my code.
    Thank you.
  • You can't turn the modem on and off more than once every other minute. Try a longer k_sleep() interval.
