Disconnection evet error 0x3E when extra services is added
Hi Nordic,
I had an initial project with a multilink central connecting to several peripherals through a NUS service, the system is working OK but then I added another connection to a peripheraö (smartwatch) having the Heart Rate service.
After that is done, I get issues in the initial connection to the NUS peripherals (the smartwatch is NOT advertising): if I start the central and 2 NUS-peripherals are simultaneously advertising, the central will connect OK to on of them and to the second one, it will have connection and reconnections indicating an 0x3E error. If I turn on the NUS peripheral one by one, the connection to each of them is OK in all cases.
If i remove the part of the code where the hrs is initialized, both connections occur properly without the previously described issue.
The timeout is 5s, it was working properly without adding the hrs in the services_init(). Any idea how can I fix this issue?
The central and NUS peripherals are nordic devices with the nRF52840 using the sdk_15.3 and s140.
