RSSI and RSRP on THINGY.91
Dear,
Im trying to measure the RSSI with THINGY:91, I found on the document  nrf91_at_commands_v1.1.pdf about
1. AT+CSQ
      +CSQ: <rssi>,<ber>
Note: Not detectable, RAT not supported. Use +CESQ and %CESQ for E-UTRA signal quality.
2. AT + CESQ
    +CESQ: <rxlev>,<ber>,<rscp>,<ecno>,<rsrq>,<rsrp>
<rsrp>
0 – RSRP < −140 dBm
1 – When −140 dBm ≤ RSRP < −139 dBm
2 – When −139 dBm ≤ RSRP < −138 dBm
95 – When −46 dBm ≤ RSRP < −45 dBm
96 – When −45 dBm ≤ RSRP < −44 dBm
97 – When −44 dBm ≤ RSRP
255 – Not known or not detectable
I am using AT+CESQ to find RSRP
and, i found some document about RSRP range:
https://wiki.teltonika.lt/view/RSRP_and_RSRQ
But, when I tested to measure it, i got:
I set the devices (3) in my freezer, and got the RSRP < -100dBm,
is it conflict here? On the document, they say: NO signal when RSRP < -100dBm, but, I measured -120dBm, and I still received the data from my THINGY:91 - it means : still signal
I am using Telia NB-IOT( Unit1) Telia LTE-M(Unit2) and Telenor LTE-M(Unit3)
My question is: RSRP vs Signal strength range? RSRP for no signal?
Thanks
BR,
Hoang Nguyen
  • if we want the external antenna, which one should we use? do you have any suggestion
  • Hi
    I hope you will have time for me today.
    1. With the external antenna, which one is suitable for THINGY:91 ( NB-IoT Telia)
    2. Go back my problem
    My problem: when the signal is bad (RSRP < -130 dBM), it stopped working and couldnt reconnect at kl.19.24.
    At kl.13.20 , it did NOT send any package (because of bad signal), then, it sent again 14.23.
    when the signal is bad (lost) for a long time, it couldnt reconnect, and just hang there. Have you met this problem before?
            1.  I tried to put the thingy91 in a metal-box ( simulated for bad signal)
            2.  it stopped sending because of bad signal, if:
                       2.1.  10mn, took thingy out, it reconnected automatically and resent the package
                       2.2.  3hrs, took thingy out, I didnt receive any data from my thingy - it could NOT reconnect and resend the data !!!
    Does error_handler() work correct in this case?
    /**@brief nRF Cloud error handler. */
    void error_handler(enum error_type err_type, int err_code)
    	/*if (err_type == ERROR_CLOUD) {
    		if (gps_control_is_enabled()) {
    			printk("Reboot\n");
    			sys_reboot(0);
    #if defined(CONFIG_LTE_LINK_CONTROL)
    		/* Turn off and shutdown modem */
    		printk("LTE link disconnect\n");
    		int err = lte_lc_power_off();
    		if (err) {
    			printk("lte_lc_power_off failed: %d\n", err);
    #if defined(CONFIG_BSD_LIBRARY)
    		printk("Shutdown modem\n");
    		bsdlib_shutdown();
    #if !defined(CONFIG_DEBUG) && defined(CONFIG_REBOOT)
    	LOG_PANIC();
    	sys_reboot(0);
    #else
    	switch (err_type) {
    	case ERROR_CLOUD:
    		/* Blinking all LEDs ON/OFF in pairs (1 and 4, 2 and 3)
    		 * if there is an application error.
    		ui_led_set_pattern(UI_LED_ERROR_CLOUD);
    		printk("Error of type ERROR_CLOUD: %d\n", err_code);
    	case ERROR_BSD_RECOVERABLE:
    		/* Blinking all LEDs ON/OFF in pairs (1 and 3, 2 and 4)
    		 * if there is a recoverable error.
    		ui_led_set_pattern(UI_LED_ERROR_BSD_REC);
    		printk("Error of type ERROR_BSD_RECOVERABLE: %d\n", err_code);
    	case ERROR_BSD_IRRECOVERABLE:
    		/* Blinking all LEDs ON/OFF if there is an
    		 * irrecoverable error.
    		ui_led_set_pattern(UI_LED_ERROR_BSD_IRREC);
    		printk("Error of type ERROR_BSD_IRRECOVERABLE: %d\n", err_code);
    		/* Blinking all LEDs ON/OFF in pairs (1 and 2, 3 and 4)
    		 * undefined error.
    		ui_led_set_pattern(UI_LED_ERROR_UNKNOWN);
    		printk("Unknown error type: %d, code: %d\n",
    			err_type, err_code);
    	while (true) {
    		k_cpu_idle();
    #endif /* CONFIG_DEBUG */
    3. About the power consumption of thingy91: have you ever measured the power consumption on thingy when the signal is bad ( RSRP = -130 dBm -- -110dBm). Do you have any document about this one
    Thanks a lot
    MVH
    Hoang Nguyen
     Which frequency bands are you going to use? The ideal antenna will depend on the frequencies.
  • Which frequency bands are you going to use? The ideal antenna will depend on the frequencie
    1. Telia NB IoT (800 MHz): 801-811 downlink 842-852 uplink
    2. Telia NB IoT (1800 MHz): 1745-1765 downlink 1840-1860 uplink
