RSSI and RSRP on THINGY.91
Dear,
Im trying to measure the RSSI with THINGY:91, I found on the document  nrf91_at_commands_v1.1.pdf about
1. AT+CSQ
      +CSQ: <rssi>,<ber>
Note: Not detectable, RAT not supported. Use +CESQ and %CESQ for E-UTRA signal quality.
2. AT + CESQ
    +CESQ: <rxlev>,<ber>,<rscp>,<ecno>,<rsrq>,<rsrp>
<rsrp>
0 – RSRP < −140 dBm
1 – When −140 dBm ≤ RSRP < −139 dBm
2 – When −139 dBm ≤ RSRP < −138 dBm
95 – When −46 dBm ≤ RSRP < −45 dBm
96 – When −45 dBm ≤ RSRP < −44 dBm
97 – When −44 dBm ≤ RSRP
255 – Not known or not detectable
I am using AT+CESQ to find RSRP
and, i found some document about RSRP range:
https://wiki.teltonika.lt/view/RSRP_and_RSRQ
But, when I tested to measure it, i got:
I set the devices (3) in my freezer, and got the RSRP < -100dBm,
is it conflict here? On the document, they say: NO signal when RSRP < -100dBm, but, I measured -120dBm, and I still received the data from my THINGY:91 - it means : still signal
I am using Telia NB-IOT( Unit1) Telia LTE-M(Unit2) and Telenor LTE-M(Unit3)
My question is: RSRP vs Signal strength range? RSRP for no signal?
Thanks
BR,
Hoang Nguyen
  • Hi
    I may find a problem with my thingy91.
    In my HTTP POST:
    detail of my HTTP_POST:
    int snprintk_post (char *PostString, char *HTTP_HOST, int HTTP_PORT)
       struct sockaddr_in local_addr;
       struct addrinfo *res;
       printk("Webserver: http://%s:%d \n\r",HTTP_HOST,HTTP_PORT);
       local_addr.sin_family = AF_INET;
       local_addr.sin_port = htons(0);
       local_addr.sin_addr.s_addr = 0;
        int err = getaddrinfo(HTTP_HOST, NULL, NULL, &res);
        printk("get addrinfo\n\r");
        printk("getaddrinfo err: %d\n\r", err);
        if(!err) {
           printk("network is OK: \n\r");
        else {
             printk("network is error: \n\r");
             return CONFIG_LTE_ERR ;
        ((struct sockaddr_in *)res->ai_addr)->sin_port = htons(HTTP_PORT);
        char send_buf[MAXLINE + 1];
        int send_data_len_post  = snprintk(send_buf,
    				         500,
    				         POST_TEMPLATE, HTTP_PATH,
    				         HTTP_HOST, strlen(PostString),
    				         PostString);
         printf("send_buf is: %s \n",send_buf);
         printk("send_data_len_post: %d\n\r", send_data_len_post);
         int client_fd = socket(AF_INET, SOCK_STREAM, 0);
         printk("client_fd: %d\n\r", client_fd);
         err = bind(client_fd, (struct sockaddr *)&local_addr, sizeof(local_addr));
         printk("bind err: %d\n\r", err);
         if(!err )
              printk("bindnetwork is OK \n\r");
         //hng: 17012020 testing bad signal
         //err = blocking_connect(client_fd, (struct sockaddr *)res->ai_addr,sizeof(struct sockaddr_in));
          err = connect(client_fd, (struct sockaddr *)res->ai_addr, sizeof(struct sockaddr_in));
    	if (err > 0) {
    		printk("connect err: %d\n", errno);
    		goto clean_up;
         printk("connect err: %d\n\r", err);
         if(!err )
              printk("blocking_connectnetwork is OK: \n\r");
         int num_bytes = send(client_fd, send_buf, send_data_len_post, 0);
         printk("num_bytes sent: %d\n\r", num_bytes);
         //get the fb from webserver ;
         int tot_num_bytes = 0;
         do {
             num_bytes =blocking_recv(client_fd, recv_buf, RECV_BUF_SIZE, 0);
             tot_num_bytes += num_bytes;
             if (num_bytes <= 0) {
    	// printk("%s \n\r", recv_buf);
    	} while (num_bytes > 0);
         printk("Close socket \n\r");
         err = close(client_fd);
         freeaddrinfo(res);
         printk("============================== DONE SENDING =============================================== \n\r");
         //poststat = true;
         return 0;
    clean_up:
    	freeaddrinfo(res);
    If the bad signal  came  ( < -135 dBm) when http_posting, it may return HTTP_ERR
    i used to get the error from this step)
    then, I tried to reconnect_nw():   lte_lc_init_and_connect()
    And, I may  get the ERROR:
    Exception occurred in Secure State
    ***** HARD FAULT *****
      Fault escalation (see below)
    ***** BUS FAULT *****
      Precise data bus error
      BFAR Address: 0x50008120
    ***** Hardware exception *****
    Current thread ID = 0x2002abec
    Faulting instruction address = 0x74b056ee
    Fatal fault in ISR! Spinning...
    The problem: The network haven't disconnected yet !!! HTTP_POST returned the ERROR, but I dont know exactly why, and what kind of error?
    If I tried:  DISconnect before reconnect_nw(), I wont get any ERROR.
    What kind of error can we meet in HTTP POST?
    ( I m sure, my webserver is OK)
    COuld you help me, I want to know about what kind of error can we meet in http post, and the solution for each of them?
    Thanks so much
    MVH
    Hoang Nguyen
    I'm not sure what you're referring to. Is this "HTTP POST" something in the SDK or something you have written?
  • I might be blind or something, but I really can't find the "http_post" you're referring to. It's not in main.c as far as I can tell.
    Also, I see that there is a ENCR_HTTP_POST() in the diagram you posted. Is that it? Where can I find this?
  • Dear
    My fall, I used app_http_start() from: https://github.com/Rallare/fw-nrfconnect-nrf/blob/nrf9160_samples/samples/nrf9160/https_simple/src/main.c to write: snprintk_post()
    And,  ENCR_HTTP_POST(), I encrypted my data before posting: snprintk_post()
    //char DPost[500]; //encryptedData will be posted to webserver: HTTP_HOST:HTTP_PORT
    int err = snprintk_post(DPost,HTTP_HOST,HTTP_PORT);
