nrf5340-PDK , potentially dead?
To start, this was a functional unit and I had been installing test firmware into it.
As of a couple of days ago while attempting to read and write to my nrf5340-PDK module, I am receiving the following :
2020-02-10T13:11:21.483Z INFO Application data folder: C:\Users\\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2020-02-10T13:11:21.608Z DEBUG App pc-nrfconnect-programmer v1.3.1 official
2020-02-10T13:11:21.609Z DEBUG App path: C:\Users\\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2020-02-10T13:11:21.609Z DEBUG nRFConnect 3.3.0 is supported by the app (^3.3.0)
2020-02-10T13:11:21.609Z DEBUG nRFConnect path: C:\Users\\AppData\Local\Programs\nrfconnect\resources\app.asar
2020-02-10T13:11:21.609Z DEBUG HomeDir: C:
2020-02-10T13:11:21.609Z DEBUG TmpDir: C:\\Temp
2020-02-10T13:11:21.626Z INFO Using nrfjprog library 10.5.0, pc-nrfjprog-js 1.6.0
2020-02-10T13:11:28.034Z INFO Using nrfjprog to communicate with target
2020-02-10T13:11:28.640Z INFO Using J-Link Software version 6.63
2020-02-10T13:11:29.647Z INFO Segger serial:  960173787
2020-02-10T13:11:29.647Z INFO Segger speed:  2000  kHz
2020-02-10T13:11:29.648Z INFO Segger version:  J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01
2020-02-10T13:11:29.656Z INFO Core probed: 960173787.
2020-02-10T13:11:29.656Z INFO Core RAM: 512KiB.
2020-02-10T13:11:29.656Z INFO Core ROM: 1024KiB in pages of 4KiB.
2020-02-10T13:11:30.668Z ERROR Error when closing nrfjprog: Error: Error occured when close opened device. Errorcode: CouldNotResetDevice (0x5)
Lowlevel error: CANNOT_CONNECT (fffffff5)
2020-02-10T13:11:30.669Z INFO Model: NRF5340_xxAA_ENGA.
2020-02-10T13:11:30.672Z ERROR Error when getting device info: Error: Error: Error occured when open device long term. Errorcode: CouldNotOpenDevice (0x4)
Lowlevel error: INVALID_OPERATION (fffffffe)
2020-02-10T13:11:30.677Z ERROR Error when closing nrfjprog: Error: Error occured when close opened device. Errorcode: CouldNotOpenDevice (0x4)
I have tried several times to bring the unit back online, but it just seems to be dead.
The following is a list of my potential diagnosis points.
1. The chip is dead and there is nothing I can do.
2. I moved a jumper or switch that has rendered the chip unable to communicate
3. I moved firmware onto the chip that is locking the CPU into a state that can't be managed externally.
4. I have somehow bricked the chip by not using its security features correctly.
Assuming it is diagnosis point 3 or 4 , are there any "wake up" points in the PCB that can allow you to bring the nrf5340 to a known default state ready for programming?
Assuming it is diagnosis point 2, are you aware of any jumpers (besides the obvous power switches) that my have accidently been removed?
I suppose I should examine the board under the microscope to make sure i didn't knock of any components as well.
Tony
