Blinky Application Not Executing in IAR when Secure DFU Bootloader is Present
I am using an nrf52840 MCU, Nordic SDK 16.0.0 and IAR Workbench for ARM v8.40.1.
The MCU has the following configuration:
- MBR installed
- DFU secure bootloader (USB only) installed and functional
- Bootloader settings installed
For the main application, I'm trying to use the example blinky application. The main application is downloaded via the Segger interface using IAR.
Using the above setup, my issue is that the blinky application does not execute at all - even after a power cycle.
If I erase the secure bootloader and its settings, leaving only the MBR, the blinky application then executes correctly, e.g.:
1. Erase the entire flash
nrfjprog.exe --family NRF52 --eraseall
Output:
Erasing user available code and UICR flash areas.
Applying system reset.
2. Program the MBR
nrfjprog --reset --program mbr.hex  --family NRF52 --sectoranduicrerase
Output:
Parsing hex file.
Erasing page at address 0x0.
Checking that the area to write is not protected.
Programming device.
Run.
3. Program Blinky App
nrfjprog --reset --program blinky_pca10056_mbr.hex --family NRF52 --sectoranduicrerase
Output:
Parsing hex file.
Erasing page at address 0x1000.
Programming device.
Run.
The ROM settings for the blinky example is: 0x1000 - 0xfffff
The RAM settings for the blinky example is: 0x20000008 - 0x2003ffff
Any ideas what I'm missing?
Thanks to all in advance.
  • Hi Chibi,
    Sorry, I was not at the office yesterday. Regarding your questions:
    - 0xF4000 is correct address. You can find the start address in linker setting.
    - The main purpose of the bootloader setting is to tell the bootloader that the chip has a valid application (so that the bootloader wouldn't stay in DFU mode but start the application) This requires the CRC verification and this explain why when you change the application the bootloader wouldn't enter the application. I have some explanation in this blog: https://devzone.nordicsemi.com/nordic/nordic-blog/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader#h61sjziauupw1j397q9s9ldr01q4j6d5
    - For development, that you don't need to update bootloader setting each time you edit your app,  you can modify the app_is_valid() to always return true. Make sure to change it back after you done with development.
    - If you want to debug the bootloader, use the _debug version , make sure the optimization level is 0
  • HI Hung Bui,
    Welcome back and thanks very much for your responses.
    Concerning the bootloader start address, I see the following from the SDK 16.0.0 online reference:
    The online documentation suggests the start of the bootloader is located at 0xF8000?
    As for the bootloader settings, your explanation is pretty clear. However, we might end up just regenerating it every time the main application firmware is updated.
    If I perform a DFU over the USB virtual COM port interface, does that mean the application firmware will need to be merged with the bootloader settings first, before creating the DFU package?
  • The documentation was an example of the BLE bootloader, not the USBD bootloader. The USB library causes the size to be increased quite a lot hence the start address moved to 0xF4000
    The bootloader setting as I explained is only to manually "tell" the bootloader that there already a valid application and it doesn't need to enter DFU mode. If the application is programmed to the chip via the DFU process (via the bootloader) the bootloader will write to bootloader setting automatically, you don't need to flash the bootloader setting.
  • Thanks for your time and clear explanations. It has been very helpful and I'm starting to understand what is going on.
    One final question, if I may:
    1. I tried to use the _debug version of the secure DFU bootloader but I didn't see any output on the JLink RTT Viewer or the JLink RTT client. Any ideas how to get the logging to appear?
  • Please check sdk_config.h file to see if NRF_LOG_ENABLED = 1 ?
    Also make sure you erase the chip before testing with the debug bootloader as the address of the debug bootloader is different from the normal one. The chip need to be erased if you want to change bootloader address.
