logging in modules with RTT
Hi All,
I wan't to have logging via segger RTT from enabled modules in the MESH SDK.
Tried several config options in sdk_config.h, but without luck.
I made a diff of the config to highlight the relevant changes.
diff --git a/nRF5_MESH/niko/testnode/server/include/sdk_config.h b/nRF5_MESH/niko/testnode/server/include/sdk_config.h
index 82ea9c5..645f4d7 100644
--- a/nRF5_MESH/niko/testnode/server/include/sdk_config.h
+++ b/nRF5_MESH/niko/testnode/server/include/sdk_config.h
@@ -2496,7 +2496,7 @@
 // <e> GPIOTE_ENABLED - nrf_drv_gpiote - GPIOTE peripheral driver - legacy layer
 #ifndef GPIOTE_ENABLED
-#define GPIOTE_ENABLED 0
+#define GPIOTE_ENABLED 1
 // <o> GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
 #ifndef GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
@@ -3026,7 +3026,7 @@
 // <e> NRFX_GPIOTE_ENABLED - nrfx_gpiote - GPIOTE peripheral driver
 #ifndef NRFX_GPIOTE_ENABLED
-#define NRFX_GPIOTE_ENABLED 0
+#define NRFX_GPIOTE_ENABLED 1
 // <o> NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
 #ifndef NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
@@ -3051,7 +3051,7 @@
 // <e> NRFX_GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef NRFX_GPIOTE_CONFIG_LOG_ENABLED
-#define NRFX_GPIOTE_CONFIG_LOG_ENABLED 0
+#define NRFX_GPIOTE_CONFIG_LOG_ENABLED 1
 // <o> NRFX_GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
@@ -8513,10 +8513,88 @@
 // <h> nRF_Log
+// <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
+#ifndef NRF_LOG_BACKEND_RTT_ENABLED
+#define NRF_LOG_BACKEND_RTT_ENABLED 1
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
+// <i> Size of the buffer is a trade-off between RAM usage and processing.
+// <i> if buffer is smaller then strings will often be fragmented.
+// <i> It is recommended to use size which will fit typical log and only the
+// <i> longer one will be fragmented.
+#ifndef NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE
+#define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS - Period before retrying writing to RTT
+#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS
+#define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TX_RETRY_CNT - Writing to RTT retries.
+// <i> If RTT fails to accept any new data after retries
+// <i> module assumes that host is not active and on next
+// <i> request it will perform only one write attempt.
+// <i> On successful writing, module assumes that host is active
+// <i> and scheme with retry is applied again.
+#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_CNT
+#define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
+#endif
+// </e>
+// <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
+#ifndef NRF_LOG_BACKEND_UART_ENABLED
+#define NRF_LOG_BACKEND_UART_ENABLED 0
+#endif
+// <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
+#ifndef NRF_LOG_BACKEND_UART_TX_PIN
+#define NRF_LOG_BACKEND_UART_TX_PIN 6
+#endif
+// <o> NRF_LOG_BACKEND_UART_BAUDRATE  - Default Baudrate
+// <323584=> 1200 baud
+// <643072=> 2400 baud
+// <1290240=> 4800 baud
+// <2576384=> 9600 baud
+// <3862528=> 14400 baud
+// <5152768=> 19200 baud
+// <7716864=> 28800 baud
+// <10289152=> 38400 baud
+// <15400960=> 57600 baud
+// <20615168=> 76800 baud
+// <30801920=> 115200 baud
+// <61865984=> 230400 baud
+// <67108864=> 250000 baud
+// <121634816=> 460800 baud
+// <251658240=> 921600 baud
+// <268435456=> 1000000 baud
+#ifndef NRF_LOG_BACKEND_UART_BAUDRATE
+#define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
+#endif
+// <o> NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
+#ifndef NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE
+#define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
+#endif
+// </e>
 // <e> NRF_LOG_ENABLED - nrf_log - Logger
 #ifndef NRF_LOG_ENABLED
-#define NRF_LOG_ENABLED 0
+#define NRF_LOG_ENABLED 1
 // <h> Log message pool - Configuration of log message pool
@@ -8985,7 +9063,7 @@
 // <e> GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef GPIOTE_CONFIG_LOG_ENABLED
-#define GPIOTE_CONFIG_LOG_ENABLED 0
+#define GPIOTE_CONFIG_LOG_ENABLED 1
 // <o> GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
@@ -9655,7 +9733,7 @@
 // <e> TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef TIMER_CONFIG_LOG_ENABLED
-#define TIMER_CONFIG_LOG_ENABLED 0
+#define TIMER_CONFIG_LOG_ENABLED 1
 // <o> TIMER_CONFIG_LOG_LEVEL  - Default Severity level
@@ -9967,7 +10045,7 @@
 // <e> APP_BUTTON_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef APP_BUTTON_CONFIG_LOG_ENABLED
-#define APP_BUTTON_CONFIG_LOG_ENABLED 0
+#define APP_BUTTON_CONFIG_LOG_ENABLED 1
 // <o> APP_BUTTON_CONFIG_LOG_LEVEL  - Default Severity level
@@ -10034,7 +10112,7 @@
 // <e> APP_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef APP_TIMER_CONFIG_LOG_ENABLED
-#define APP_TIMER_CONFIG_LOG_ENABLED 0
+#define APP_TIMER_CONFIG_LOG_ENABLED 1
 // <o> APP_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
@@ -11238,7 +11316,6 @@
 // <6=> Magenta
 // <7=> Cyan
 // <8=> White
 #ifndef NRF_SDH_SOC_DEBUG_COLOR
 #define NRF_SDH_SOC_DEBUG_COLOR 0
Using light-switch examples.
What else I'm missing?
Regards, Wim
  • No not working.
    The logging infrastructure is extremely complicated and in my opinion overengineered. Probably it is all very flexible, but not without a manual.
    Many defines are preprocessor symbols, dozens of other options can be set in sdk_config.h.
    I try to understand the logic behind it.
    For example, I found following defines in the sources:  NRF_LOG_LEVEL, NRF_LOG_DEFAULT_LEVEL, NRF_LOG_FILTER, NRF_LOG_ENABLED, NRF_LOG_BACKEND_RTT_ENABLED, ....
    I tried also several preprocessor defines:
    -DNRF_MESH_LOG_ENABLE=NRF_LOG_USES_RTT
    -DNRF_LOG_USES_RTT=1
    -DLOG_ENABLE_RTT=1
    -DLOG_LEVEL_DEFAULT=4
    -DLOG_ENABLE_RTT=1
    -DNRF52_SERIES
    -DPROV_DEBUG_MODE
    -DLOG_SRC_PROV=1
    and this goes on and on ...
    Several options has relations with each other, some of them mutually exclusive, ...
    Without a descent description of all of this, it is very hard to understand.
    An example project where all logging is enabled via RTT, could also help.
    Have a look at __LOG_INIT() function in the example's main.c file. List each module as from where the logging needs to be printed as a first argument to this function(See in log.h under LOG_SOURCES). Second argument controls the verbosity of the logs. All the messages to be printed must be logged using __LOG()  API.
    ​Also, which modules and drivers are you talking about here? Modules of the Mesh SDK? If it is modules of the mesh SDK, then you should update __LOG_INIT as I mentioned above.
