logging in modules with RTT
Hi All,
I wan't to have logging via segger RTT from enabled modules in the MESH SDK.
Tried several config options in sdk_config.h, but without luck.
I made a diff of the config to highlight the relevant changes.
diff --git a/nRF5_MESH/niko/testnode/server/include/sdk_config.h b/nRF5_MESH/niko/testnode/server/include/sdk_config.h
index 82ea9c5..645f4d7 100644
--- a/nRF5_MESH/niko/testnode/server/include/sdk_config.h
+++ b/nRF5_MESH/niko/testnode/server/include/sdk_config.h
@@ -2496,7 +2496,7 @@
 // <e> GPIOTE_ENABLED - nrf_drv_gpiote - GPIOTE peripheral driver - legacy layer
 #ifndef GPIOTE_ENABLED
-#define GPIOTE_ENABLED 0
+#define GPIOTE_ENABLED 1
 // <o> GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
 #ifndef GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
@@ -3026,7 +3026,7 @@
 // <e> NRFX_GPIOTE_ENABLED - nrfx_gpiote - GPIOTE peripheral driver
 #ifndef NRFX_GPIOTE_ENABLED
-#define NRFX_GPIOTE_ENABLED 0
+#define NRFX_GPIOTE_ENABLED 1
 // <o> NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS - Number of lower power input pins
 #ifndef NRFX_GPIOTE_CONFIG_NUM_OF_LOW_POWER_EVENTS
@@ -3051,7 +3051,7 @@
 // <e> NRFX_GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef NRFX_GPIOTE_CONFIG_LOG_ENABLED
-#define NRFX_GPIOTE_CONFIG_LOG_ENABLED 0
+#define NRFX_GPIOTE_CONFIG_LOG_ENABLED 1
 // <o> NRFX_GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
@@ -8513,10 +8513,88 @@
 // <h> nRF_Log
+// <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend
+#ifndef NRF_LOG_BACKEND_RTT_ENABLED
+#define NRF_LOG_BACKEND_RTT_ENABLED 1
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
+// <i> Size of the buffer is a trade-off between RAM usage and processing.
+// <i> if buffer is smaller then strings will often be fragmented.
+// <i> It is recommended to use size which will fit typical log and only the
+// <i> longer one will be fragmented.
+#ifndef NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE
+#define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS - Period before retrying writing to RTT
+#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS
+#define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1
+#endif
+// <o> NRF_LOG_BACKEND_RTT_TX_RETRY_CNT - Writing to RTT retries.
+// <i> If RTT fails to accept any new data after retries
+// <i> module assumes that host is not active and on next
+// <i> request it will perform only one write attempt.
+// <i> On successful writing, module assumes that host is active
+// <i> and scheme with retry is applied again.
+#ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_CNT
+#define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3
+#endif
+// </e>
+// <e> NRF_LOG_BACKEND_UART_ENABLED - nrf_log_backend_uart - Log UART backend
+#ifndef NRF_LOG_BACKEND_UART_ENABLED
+#define NRF_LOG_BACKEND_UART_ENABLED 0
+#endif
+// <o> NRF_LOG_BACKEND_UART_TX_PIN - UART TX pin
+#ifndef NRF_LOG_BACKEND_UART_TX_PIN
+#define NRF_LOG_BACKEND_UART_TX_PIN 6
+#endif
+// <o> NRF_LOG_BACKEND_UART_BAUDRATE  - Default Baudrate
+// <323584=> 1200 baud
+// <643072=> 2400 baud
+// <1290240=> 4800 baud
+// <2576384=> 9600 baud
+// <3862528=> 14400 baud
+// <5152768=> 19200 baud
+// <7716864=> 28800 baud
+// <10289152=> 38400 baud
+// <15400960=> 57600 baud
+// <20615168=> 76800 baud
+// <30801920=> 115200 baud
+// <61865984=> 230400 baud
+// <67108864=> 250000 baud
+// <121634816=> 460800 baud
+// <251658240=> 921600 baud
+// <268435456=> 1000000 baud
+#ifndef NRF_LOG_BACKEND_UART_BAUDRATE
+#define NRF_LOG_BACKEND_UART_BAUDRATE 30801920
+#endif
+// <o> NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings.
+#ifndef NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE
+#define NRF_LOG_BACKEND_UART_TEMP_BUFFER_SIZE 64
+#endif
+// </e>
 // <e> NRF_LOG_ENABLED - nrf_log - Logger
 #ifndef NRF_LOG_ENABLED
-#define NRF_LOG_ENABLED 0
+#define NRF_LOG_ENABLED 1
 // <h> Log message pool - Configuration of log message pool
@@ -8985,7 +9063,7 @@
 // <e> GPIOTE_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef GPIOTE_CONFIG_LOG_ENABLED
-#define GPIOTE_CONFIG_LOG_ENABLED 0
+#define GPIOTE_CONFIG_LOG_ENABLED 1
 // <o> GPIOTE_CONFIG_LOG_LEVEL  - Default Severity level
@@ -9655,7 +9733,7 @@
 // <e> TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef TIMER_CONFIG_LOG_ENABLED
-#define TIMER_CONFIG_LOG_ENABLED 0
+#define TIMER_CONFIG_LOG_ENABLED 1
 // <o> TIMER_CONFIG_LOG_LEVEL  - Default Severity level
@@ -9967,7 +10045,7 @@
 // <e> APP_BUTTON_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef APP_BUTTON_CONFIG_LOG_ENABLED
-#define APP_BUTTON_CONFIG_LOG_ENABLED 0
+#define APP_BUTTON_CONFIG_LOG_ENABLED 1
 // <o> APP_BUTTON_CONFIG_LOG_LEVEL  - Default Severity level
@@ -10034,7 +10112,7 @@
 // <e> APP_TIMER_CONFIG_LOG_ENABLED - Enables logging in the module.
 #ifndef APP_TIMER_CONFIG_LOG_ENABLED
-#define APP_TIMER_CONFIG_LOG_ENABLED 0
+#define APP_TIMER_CONFIG_LOG_ENABLED 1
 // <o> APP_TIMER_CONFIG_LOG_LEVEL  - Default Severity level
@@ -11238,7 +11316,6 @@
 // <6=> Magenta
 // <7=> Cyan
 // <8=> White
 #ifndef NRF_SDH_SOC_DEBUG_COLOR
 #define NRF_SDH_SOC_DEBUG_COLOR 0
Using light-switch examples.
What else I'm missing?
Regards, Wim
