Greetings...
Provisioning w/ Android tool only works when board is connected to debugger.
Provisioning failed to even find the devices when scanning after disconnected from SES.
Any tricks? Thanks!
M
Greetings...
Any tricks? Thanks!
M
Can you give me more details? What doesn't work when you are not connected tot the debugger? Are you using a custom board? Which example are you testing with?
What do you mean by this?
I am using out of box Mesh 4 example below:
Which is the server application from light_switch folder.
I compiled, downloaded the my nRF52840 Dev Board by clicking on debug...Then stopped debug...
Power cycled the board.
Turn on the Android tool to add it to my Mesh network.
No matter what I do, tool fails to find it....
Will this answer your question?
Thanks.
M.
After you downloaded the firmware to your board, did you provision the the board through nRF Mesh app?
Yes, Mttrinh. I always use nRF Mesh app to for provisioning my devices. Always works with earlier Mesh releases.
Im a little bit confused. So you have flashed over the firmware, use nRF Mesh to provision the board. After you have provision the board, you power cycle the board then try to search for the board again via nRF Mesh? Correct me if im wrong.
