Hardfault
Hi.
I just put this on my main code:
uint32_t pg_size,* addr,pg_num,numero_guardado_memoria=0;
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num = NRF_FICR->CODESIZE - 1;
addr= (uint32_t *)(pg_size * (pg_num+1));
if((uint32_t)*(addr)=='D'){
     addr=(uint32_t *)(pg_size * (pg_num + 2));
     numero_guardado_memoria=(uint32_t)*(addr);
to simply read what is stored in a memory position ... and ones i debug the program, just after the if.. it lauch me a hardfault...
i can't understand.
please i need your help.
    pg_size * (pg_num+1)  will point to a non-existing byte right after your flash memory, it's no wonder that you're catching a hardfault..
  • How can i acces to the first 32bits word after de code ? and the second one.. and so on ?
    I need to storage and read info from sensors to de flash..
    Thanks a lot..
    Nasib said:
    Right?
    Yes.
    Nasib said:
    And the sistem still freezing even in the flash_page_erase or in the flash_word_write (if i comment the erase function)....
    Debugging the code, just besore to erase, this page (firs word) is: 0xffffffff (so i guess the is no code there... )
    Odd. Your code works for me (with some minor cleanup). You can verify by putting this main.c file in  <SDK 12.3>\examples\peripheral\blinky\:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    static void flash_page_erase(uint32_t * page_address)
        // Turn on flash erase enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos);
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
            // Do nothing.
            // Erase page:
        NRF_NVMC->ERASEPAGE = (uint32_t)page_address;
            // Do nothing.
        // Turn off flash erase enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
    static void flash_word_write(uint32_t * address, uint32_t value)
        // Turn on flash write enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
        *address = value;
            // Do nothing.
        // Turn off flash write enable and wait until the NVMC is ready:
            // Do nothing.
        uint32_t pg_size = NRF_FICR->CODEPAGESIZE;
        uint32_t pg_num = NRF_FICR->CODESIZE-2; // Use last page in flash
        uint32_t * addr = (uint32_t *)(pg_size * pg_num);
        flash_page_erase(addr);
        char patwr_32 = 'D';
        flash_word_write(addr, patwr_32);
        nrf_delay_ms(10);
        pg_num = NRF_FICR->CODESIZE-3; // Use last page in flash
        patwr_32 = 'X';
        nrf_delay_ms(10);
        while (true)
            // Do nothing
    Using a debugger (remember to turn off optimization) you can see that the code finishes all flash operations and runs to the main loop. Then I verified that the data had been written by dumping the flash (using "nrfjprog.exe --memrd 0 --n 0x40000 > flash_dump.txt"). As you can see in the attached file (flash_dump.txt), you have the expected data written to 0x0003F800 and 0x0003F400 (using a nRF51 device with 256 kB flash).
  • Ok i discovered what is happening.. but i dont know how to solve it.
    It works for me also, but if before the memory writing and erasing i initialize the BLE, the GPIOTE, and the TIMERS, then is when the system stops...
    Is there any shared resource or something ?
    That is expected. You are not allowed to write to flash directly when the SoftDevice is active. In that case, you need to use the SoftDevice API to write to flash, or alternatively fstorage, which does this for you.
  • Ok i did this after all the initializations:
    pg_num = NRF_FICR->CODESIZE-1; // Use last page in flash
    uint32_t buffer[3]={1,2,3};
    sd_flash_page_erase(pg_num);
    nrf_delay_ms(50);
    sd_flash_write(addr,(uint32_t*)buffer,3);
    erasing the mem works perfect, but writing on it doesn't make anything... just pass over it without write anything
    I do not immediately see anything wrong in this snippet. However,
    • You should always check return values. What does sd_flash_write() return?
    • I do not see how/when you try to read. You should make sure to wait for the write to complete before trying to read. That is signaled by the NRF_EVT_FLASH_OPERATION_SUCCESS or NRF_EVT_FLASH_OPERATION_ERROR event.
