Hardfault
Hi.
I just put this on my main code:
uint32_t pg_size,* addr,pg_num,numero_guardado_memoria=0;
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num = NRF_FICR->CODESIZE - 1;
addr= (uint32_t *)(pg_size * (pg_num+1));
if((uint32_t)*(addr)=='D'){
     addr=(uint32_t *)(pg_size * (pg_num + 2));
     numero_guardado_memoria=(uint32_t)*(addr);
to simply read what is stored in a memory position ... and ones i debug the program, just after the if.. it lauch me a hardfault...
i can't understand.
please i need your help.
    The flash_page_erase() you have implemented does not support non-page aligned addresses, which is what you provide as mentioned before. See register documentation for ERASEPAGE:
    Register for starting erase of a page in code area.
    The value is the address to the page to be erased (addresses of first word in page). Note that the erase must be enabled using CONFIG.WEN before the page can be erased. Attempts to erase pages that are outside the code area may result in undesirable behavior, e.g. the wrong page may be erased.
    You need to have control over your addresses. I suggest you consider using fstorage instead, as that will handle the low-level complexities for you. Moreover, if you make mistakes like passing invalid addresses, you will get a sensible error code returned. In this case, you would have gotten a NRF_ERROR_INVALID_ADDR returned from nrf_fstorage_erase().
  • Ok , i am going to implement the code with fstorage. But before to start i need to solve 2 concepts:
    1) should i erase the existing word before to write a new one?
    2) if the code ends in the X position , where can i storage data ? should i configure the keil to end short the code memory reservation?
    Yes and no. Due to the nature of flash, writing can only change '1' to '0'. So you cannot overwrite existing data unless that is already erased, or just just want to turn more bits from '1' to zero. Also due to the nature of flash, you cannot erase single words, but only full pages. Erasing a flash page means making all words in that flash page all '1's (0xFFFFFFFF).
    You can store application data in any available flash that is not occupied by the application. If you do not have a bootloader and do not use FDS or similar (used by the peer manager if you use BLE bonding), then any space above the application end address is available. But make sure to stare with a page offset, so that you are able to erase it without erasing parts of the application.
  • So for saving (ie) two words, i have to :
    0) look for the last code position
    1) erase the next whole page after that possition
    2) write a word in the first position of that page
    3) jump a whole page
    4) erase that page
    5) write a word in the first possition of that page.
    Right?
    I DO THIS :
    pg_num = NRF_FICR->CODESIZE-2; // Use last page in flash
    addr = (uint32_t *)(pg_size * pg_num);
    flash_page_erase(addr);
    patwr_32 = 'D';
    flash_word_write(addr, patwr_32);
    nrf_delay_ms(10);
    pg_num = NRF_FICR->CODESIZE-3; // Use last page in flash
    patwr_32 = 'X';
    nrf_delay_ms(10);
    And the sistem still freezing even in the flash_page_erase or in the flash_word_write (if i comment the erase function)....
    Debugging the code, just besore to erase, this page (firs word) is: 0xffffffff (so i guess the is no code there... )
    Nasib said:
    Right?
    Yes.
    Odd. Your code works for me (with some minor cleanup). You can verify by putting this main.c file in  <SDK 12.3>\examples\peripheral\blinky\:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup blinky_example_main main.c
     * @ingroup blinky_example
     * @brief Blinky Example Application main file.
     * This file contains the source code for a sample application to blink LEDs.
    #include <stdbool.h>
    #include <stdint.h>
    #include "nrf_delay.h"
    #include "boards.h"
    static void flash_page_erase(uint32_t * page_address)
        // Turn on flash erase enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos);
        while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
            // Do nothing.
            // Erase page:
        NRF_NVMC->ERASEPAGE = (uint32_t)page_address;
            // Do nothing.
        // Turn off flash erase enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
    static void flash_word_write(uint32_t * address, uint32_t value)
        // Turn on flash write enable and wait until the NVMC is ready:
        NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
            // Do nothing.
        *address = value;
            // Do nothing.
        // Turn off flash write enable and wait until the NVMC is ready:
            // Do nothing.
        uint32_t pg_size = NRF_FICR->CODEPAGESIZE;
        uint32_t pg_num = NRF_FICR->CODESIZE-2; // Use last page in flash
        uint32_t * addr = (uint32_t *)(pg_size * pg_num);
        char patwr_32 = 'D';
        nrf_delay_ms(10);
        patwr_32 = 'X';
        nrf_delay_ms(10);
        while (true)
            // Do nothing
    Using a debugger (remember to turn off optimization) you can see that the code finishes all flash operations and runs to the main loop. Then I verified that the data had been written by dumping the flash (using "nrfjprog.exe --memrd 0 --n 0x40000 > flash_dump.txt"). As you can see in the attached file (flash_dump.txt), you have the expected data written to 0x0003F800 and 0x0003F400 (using a nRF51 device with 256 kB flash).
