Hardfault
Hi.
I just put this on my main code:
uint32_t pg_size,* addr,pg_num,numero_guardado_memoria=0;
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num = NRF_FICR->CODESIZE - 1;
addr= (uint32_t *)(pg_size * (pg_num+1));
if((uint32_t)*(addr)=='D'){
     addr=(uint32_t *)(pg_size * (pg_num + 2));
     numero_guardado_memoria=(uint32_t)*(addr);
to simply read what is stored in a memory position ... and ones i debug the program, just after the if.. it lauch me a hardfault...
i can't understand.
please i need your help.
  • Hi Dmitry, i try this:
    IROM1: 0x1B000 to 0x3F800 (2048 less than normally)
    And in the code:
    doing this, writing and reading is ok
    pg_num = NRF_FICR->CODESIZE-1; // Use last page in flash
    addr = (uint32_t *)(pg_size * pg_num);
    flash_page_erase(addr);
    patwr_32 = 'D';
    flash_word_write(addr, patwr_32);
    nrf_delay_ms(10);
    doing this reading is ok:
    addr = (uint32_t *)(pg_size * pg_num)+1;
    if((uint32_t)*(addr)=='D'){ //renombro
    Doing this it crashes in flash_page_erase:
    addr = (uint32_t *)(pg_size * pg_num)+1 ;
    patwr_32 = 'D';
    nrf_delay_ms(10);
    And with this in word_write:
    addr = (uint32_t *)(pg_size * (pg_num+1)) ;
    patwr_32 = 'D';
    nrf_delay_ms(10);
    And finally i do this manually:
     addr=(uint32_t *)0x5A801;
    That is 0x1B000 + 0x3F800 +1
    ( I guess it is the next position in memory that the one dedicated for code )
    and ALSO it gives me a hardfault
    This is clearly an invalid address (since it is higher than 256*1024=0x4000, so the hardfault is expected. You cannot use memory that does not exist.
  • Hi..
    The Rom1 conf (in keil) was: from 0x1b000 to 0x40000
    So i guess that memory was just for code. so i reduce it in keil conf to: 01b000 to 0x3f800
    Then i expected that those 2048 bytes were free to be used for other purposes...
    As i understood from your reply, what i configure in keil is going to be the total amount of memory i can use in my device ?? (code + other purposes)
    What about the other problems?
    I think the question is easy.. but i dont know how to solve it:
    With this everything is ok :
    patwr_32 = 'D';
    nrf_delay_ms(10);
    But i dont know how to store other 32bit words without having hardfaults...
    Remembering this:
    pg_size = NRF_FICR->CODEPAGESIZE; // 1024
    pg_num = NRF_FICR->CODESIZE-1; // 256-1=255 (assuming you don't have a device with small flash
    Let's look at your other code snippet (which you write fails):
    patwr_32 = 'D';
    nrf_delay_ms(10);
    Here you provide an address that is not the beginning of the flash page to flash_page_erase(). How does it handle that? How is flash_page_erase() implemented? Most likely you must provide the address to the first byte of the flash page. If so, you should remove the "+1" when calculating addr.
  • Hi Einar!
    These are the functions:
    static void flash_page_erase(uint32_t * page_address){
    // Turn on flash erase enable and wait until the NVMC is ready:
    NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos);
    while (NRF_NVMC->READY == NVMC_READY_READY_Busy)
    // Do nothing.
    // Erase page:
    NRF_NVMC->ERASEPAGE = (uint32_t)page_address;
    // Do nothing.
    // Turn off flash erase enable and wait until the NVMC is ready:
    NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos);
    // Do nothing.
    and
    static void flash_word_write(uint32_t * address, uint32_t value){
    // Turn on flash write enable and wait until the NVMC is ready:
    NRF_NVMC->CONFIG = (NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos);
    // Do nothing.
    *address = value;
    // Do nothing.
    // Turn off flash write enable and wait until the NVMC is ready:
    // Do nothing.
    how would you write just 4 words (32bits) in memory ??
    I just need to do this.
    Which are the steps?
    Thanks
    __________________________________________________________
    Another aproach::
    i do this in the main fuinction AND EVERYTHING WORKS OK:
    //addr=(uint32_t *)0x5A801;
    //------GUARDO D-------------------
    flash_page_erase(addr); //borramos memoria
    patwr_32 = 'D';
    flash_word_write(addr, patwr_32); //guardamos D en la primera posición después de la D
    nrf_delay_ms(10);
    patwr_32 = 'D';
    nrf_delay_ms(10);
    BUT when i try to repeat this paragraph in another function , it crashes in erasing the memory
    patwr_32 = 'D';
    nrf_delay_ms(10);
