In order to test my custom BLE protocol on my device I am attempting to use the pc-ble-driver-py Python module (either 0.11.4 or latest version) to connect to my BLE peripheral running with a modified version of the app-template from SDK v12.3.0 on nRF52832.
After scanning for, connecting to, and discovering MTU and services I have my Python script do a busy wait.
On both the device and in my Python script I observe a disconnect after ~63 seconds.
If I connect to my device using nRFConnect PC tool, I don't observe this problem and am able to stay connected indefinitely to my device.
One theory is that my BLE peripheral is failing the BLE connection parameter update sequence but I am not setting the "disconnect on failure" flag when I initialize this (see code below). Is there some other way that I might be triggering a disconnect somehow?
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */ #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */ #define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */ /**@brief Function for initializing the Connection Parameters module. */ static void BLE_ConnectionParamsInit(void) { uint32_t err_code; ble_conn_params_init_t cp_init; memset(&cp_init, 0, sizeof(cp_init)); cp_init.p_conn_params = NULL; cp_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY; cp_init.next_conn_params_update_delay = NEXT_CONN_PARAMS_UPDATE_DELAY; cp_init.max_conn_params_update_count = MAX_CONN_PARAMS_UPDATE_COUNT; cp_init.start_on_notify_cccd_handle = BLE_GATT_HANDLE_INVALID; cp_init.disconnect_on_fail = false; cp_init.evt_handler = BLE_OnConnectionParamsEvent; cp_init.error_handler = BLE_OnConnectionParamsError; err_code = ble_conn_params_init(&cp_init); APP_ERROR_CHECK(err_code); } /**@brief Function for handling a Connection Parameters error. * * @param[in] nrf_error Error code containing information about what went wrong. */ static void BLE_OnConnectionParamsError(uint32_t nrf_error) { APP_ERROR_HANDLER(nrf_error); } /**@brief Function for handling the Connection Parameters Module. * * @details This function will be called for all events in the Connection Parameters Module which * are passed to the application. * @note All this function does is to disconnect. This could have been done by simply * setting the disconnect_on_fail config parameter, but instead we use the event * handler mechanism to demonstrate its use. * * @param[in] p_evt Event received from the Connection Parameters Module. */ static void BLE_OnConnectionParamsEvent(ble_conn_params_evt_t * p_evt) { uint32_t err_code; if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED) { DBG_PrintLn(DBG_APPLICATION, "Connection Parameter interval unacceptable"); err_code = sd_ble_gap_disconnect(sConnectionHandle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE); APP_ERROR_CHECK(err_code); } }
