Connecting to device using pc-ble-driver-py causes disconnect after 60 seconds
In order to test my custom BLE protocol on my device I am attempting to use the pc-ble-driver-py Python module (either 0.11.4 or latest version) to connect to my BLE peripheral running with a modified version of the app-template from SDK v12.3.0 on nRF52832.
After scanning for, connecting to, and discovering MTU and services I have my Python script do a busy wait.
On both the device and in my Python script I observe a disconnect after ~63 seconds.
If I connect to my device using nRFConnect PC tool, I don't observe this problem and am able to stay connected indefinitely to my device.
One theory is that my BLE peripheral is failing the BLE connection parameter update sequence but I am not setting the "disconnect on failure" flag when I initialize this (see code below). Is there some other way that I might be triggering a disconnect somehow?
#define FIRST_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY    APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT     3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
static void BLE_ConnectionParamsInit(void)
    cp_init.evt_handler                    = BLE_OnConnectionParamsEvent;
    cp_init.error_handler                  = BLE_OnConnectionParamsError;
/**@brief Function for handling a Connection Parameters error.
static void BLE_OnConnectionParamsError(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
static void BLE_OnConnectionParamsEvent(ble_conn_params_evt_t * p_evt)
    uint32_t err_code;
        DBG_PrintLn(DBG_APPLICATION, "Connection Parameter interval unacceptable");
        err_code = sd_ble_gap_disconnect(sConnectionHandle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
  • nrfConnect-no-disconnect.pcapngpc-ble-driver-py-disconnect.pcapng
    Attached are two wireshark captures showing the difference. I will analyze them myself tomorrow but hopefully something in the capture might be helpful.
  • import re
    import time
    try:
        import Queue
    except ImportError:
        import queue as Queue
    import logging
    logger = logging.getLogger(__name__)
    from pc_ble_driver_py import config
    config.__conn_ic_id__ = "NRF52"
    nrf_sd_ble_api_ver = config.sd_api_ver_get()
    # These imports must come after config import and assigning of __conn_ic_id__
    from pc_ble_driver_py.ble_driver import (
        BLEDriver,
        BLEAdvData,
        BLEEvtID,
        BLEEnableParams,
        BLEGapTimeoutSrc,
        BLEGattStatusCode,
        BLEUUID,
        BLEUUIDBase)
    if nrf_sd_ble_api_ver >= 5:
            BLEConfig,
            BLEConfigConnGatt)
        CFG_TAG = 1
    from pc_ble_driver_py.ble_adapter import BLEAdapter
    from pc_ble_driver_py.exceptions import NordicSemiException
    from pc_ble_driver_py.observers  import BLEAdapterObserver, BLEDriverObserver, get_addr_str
    CONNECTIONS = 1
    def get_input_as_list(data):
        if isinstance(data, str):
            return map(ord, data)
        else:
            return list(data)
    class Central(BLEDriverObserver):
        def __init__(self, serial_port):
            super(Central, self).__init__()
            self.adapter = BLEAdapter(BLEDriver(serial_port=serial_port,
                                                auto_flash=True))
            self.connect_filter = None
            self.conn_q = Queue.Queue()
            self.disc_q = Queue.Queue()
            self.scan_q = Queue.Queue()
            self.debug = False
            self.peripherals = dict()
            self.dev_name_to_address = dict()
            self.scan_data = dict()
            self.scan_filter = None
            self.adapter.driver.observer_register(self)
        def open(self, vs_uuid_count=1):
            self.adapter.driver.open()
                self.adapter.default_mtu = 250
                gatt_cfg = BLEConfigConnGatt()
                gatt_cfg.att_mtu = self.adapter.default_mtu
                gatt_cfg.tag = CFG_TAG
                self.adapter.driver.ble_cfg_set(BLEConfig.conn_gatt, gatt_cfg)
                self.adapter.driver.ble_enable()
            elif nrf_sd_ble_api_ver >= 3:
                ble_enable_params = BLEEnableParams(vs_uuid_count      = vs_uuid_count,
                                                    service_changed    = False,
                                                    periph_conn_count  = 0,
                                                    central_conn_count = CONNECTIONS,
                                                    central_sec_count  = CONNECTIONS)
                ble_enable_params.att_mtu = 50
                self.adapter.driver.ble_enable(ble_enable_params)
        def close(self):
            self.adapter.driver.close()
        def add_custom_uuid(self, custom_uuid):
            # Add big-endian reversed version of custom_uuid
            uuid_base = BLEUUIDBase(custom_uuid[::-1])
            self.adapter.driver.ble_vs_uuid_add(uuid_base)
            return uuid_base
        def connect(self, dev_name_or_address, timeout=20):
            if self.scan_filter is None:
                short_scan = True
                self.scan_start(dev_name_or_address)
            else:
                short_scan = False
            self.connect_filter = dev_name_or_address
            try:
                peer_addr = self.scan_q.get(timeout=timeout)
            except Queue.Empty:
                peer_addr = None
            if short_scan:
                self.scan_stop()
            if peer_addr:
                conn_handle = self.__connect_and_verify(peer_addr, conn_timeout=timeout)
                if conn_handle is not None:
                    start_time = time.time()
                    logger.info('Discovering services and MTU')
                    # Perform MTU exchange if applicable
                        att_mtu = self.adapter.att_mtu_exchange(conn_handle, mtu=self.adapter.default_mtu)
                        att_mtu = self.adapter.att_mtu_exchange(conn_handle)
                    else:
                        att_mtu = 23
                    self.adapter.service_discovery(conn_handle)
                    self.peripherals[conn_handle] = Peripheral(self, conn_handle, att_mtu, peer_addr, start_time)
                    logger.info('Connection complete for "{}"'.format(dev_name_or_address))
                    return self.peripherals[conn_handle]
            else:
                logger.error('Peripheral name or address "{}" not found'.format(dev_name_or_address))
            return None
        def get_scan_data(self, dev_name_or_address, timeout=10):
            if dev_name_or_address in self.dev_name_to_address:
                address = self.dev_name_to_address[dev_name_or_address]
            else:
                address = dev_name_or_address
            # FIXME: Replace this if with a busy wait loop up to timeout?
            if address not in self.scan_data:
                return None
            try:
                return self.scan_data[address].get(timeout=timeout)
            except Queue.Empty:
                pass
            return None
        def scan_start(self, scan_filter=None):
            if scan_filter:
                logger.info('Scanning for names or addresses that match {!r}'.format(scan_filter))
            else:
                logger.info('Scanning for all peripherals')
            if scan_filter != self.scan_filter:
                self.dev_name_to_address.clear()
            self.scan_filter = scan_filter
            self.adapter.driver.ble_gap_scan_start()
        def scan_stop(self):
            try:
                self.adapter.driver.ble_gap_scan_stop()
            except NordicSemiException:
                pass
        def on_gap_evt_connected(self, ble_driver, conn_handle, peer_addr, role, conn_params):
            super(Central, self).on_gap_evt_connected(ble_driver, conn_handle, peer_addr, role, conn_params)
            self.conn_q.put(conn_handle)
        def on_gap_evt_disconnected(self, ble_driver, conn_handle, reason):
            super(Central, self).on_gap_evt_disconnected(ble_driver, conn_handle, reason)
            if conn_handle in self.peripherals:
                self.peripherals[conn_handle].remote_close(reason)
            else:
                logger.info('Connection closed: {}'.format(reason))
            self.disc_q.put(conn_handle)
        def on_gap_evt_timeout(self, ble_driver, conn_handle, src):
            super(Central, self).on_gap_evt_timeout(ble_driver, conn_handle, src)
            if src == BLEGapTimeoutSrc.scan:
                if self.debug:
                    logger.debug('Restarting scan')
                ble_driver.ble_gap_scan_start()
        def on_gap_evt_adv_report(self, ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data):
            super(Central, self).on_gap_evt_adv_report(ble_driver, conn_handle, peer_addr, rssi, adv_type, adv_data)
            dev_name_list = None
            address  = get_addr_str(peer_addr)
            if BLEAdvData.Types.complete_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.complete_local_name]
            elif BLEAdvData.Types.short_local_name in adv_data.records:
                dev_name_list = adv_data.records[BLEAdvData.Types.short_local_name]
            elif BLEAdvData.Types.manufacturer_specific_data in adv_data.records:
                if address in self.scan_data:
                    data = adv_data.records[BLEAdvData.Types.manufacturer_specific_data]
                    if self.debug:
                        logger.debug("SCN: {} {}".format(address, "".join("{:02x}".format(c) for c in data)))
                    self.scan_data[address].put(bytearray(data))
                return
            else:
                return
            dev_name = "".join(chr(e) for e in dev_name_list)
            if self.scan_filter is None or re.search(self.scan_filter, dev_name) or re.search(self.scan_filter, address):
                # Allow collecting scan data from this address
                    # Add device name to address lookup
                    if len(dev_name) > 1:
                        self.dev_name_to_address[dev_name] = address
                    self.scan_data[address] = Queue.Queue()
                if self.debug:
                    logger.debug('Adv: address: 0x{}, rssi: {}, device_name: {}'.format(address,
        rssi,
        dev_name))
            # Are we waiting to connect to this peripheral? Then return peer_addr
            if self.connect_filter and (re.search(self.connect_filter, dev_name) or
                                        re.search(self.connect_filter, address)):
                self.scan_q.put(peer_addr)
        def __connect_and_verify(self, peer_addr, conn_timeout=20, disc_timeout=1):
            retries = 1
            while retries <= 5:
                # Attempt connection
                logger.info('Connecting to "{}" (attempt {})'.format(address, retries))
                    self.adapter.connect(peer_addr, tag=CFG_TAG)
                else:
                    self.adapter.connect(peer_addr)
                try:
                    conn_handle = self.conn_q.get(timeout=conn_timeout)
                except Queue.Empty:
                    logger.error('Unable to connect to "{}" in {}s'.format(address, conn_timeout))
                    retries += 1
                    continue
                # Verify connection (monitor for disconnects)
                disc_handle = None
                while conn_handle != disc_handle:
                    try:
                        disc_handle = self.disc_q.get(timeout=disc_timeout)
                    except Queue.Empty:
                        # Connection is stable if no disconnect events occurred within timeout
                        break
                if conn_handle == disc_handle:
                    retries += 1
                    # Wait 1 second between attempts
                    time.sleep(1)
                    continue
                else:
                    break
            else:
                raise RuntimeError('Unable to establish stable connection to "{}"'.format(address))
            return conn_handle
    class Peripheral(BLEAdapterObserver):
        def __init__(self, central, conn_handle, att_mtu, peer_addr, start_time):
            self.central = central
            self.conn_handle = conn_handle
            self.att_mtu = att_mtu
            self.peer_addr = peer_addr
            self.disconnect_reason = None
            self.notifications = dict()
            self.start_time = start_time
            self.central.adapter.observer_register(self)
        def is_connected(self):
            return self.conn_handle is not None
        def disconnect(self):
            if self.conn_handle is not None:
                logger.info('Requesting disconnect...')
                self.central.adapter.disconnect(self.conn_handle)
        def remote_close(self, disconnect_reason):
            elapsed_time = time.time() - self.start_time
            logger.info('Connection closed after {} seconds with reason {}'.format(elapsed_time, disconnect_reason))
            self.central.adapter.observer_unregister(self)
            self.conn_handle = None
        def enable_notification(self, uuid, base=None):
            self.notifications[uuid] = Queue.Queue()
            self.central.adapter.enable_notification(self.conn_handle, BLEUUID(uuid, base=base))
        def disable_notification(self, uuid, base=None):
            self.central.adapter.disable_notification(self.conn_handle, BLEUUID(uuid, base=base))
            del self.notifications[uuid.value]
        def get_notification(self, uuid, timeout=10):
            if uuid not in self.notifications:
                raise RuntimeError("Notification {:02X} is not enabled".format(uuid))
            try:
                return self.notifications[uuid].get(timeout=timeout)
            except Queue.Empty:
                pass
            return None
        def read(self, uuid, base=None):
            # Use read_req to get first few bytes (offset=0)
            status, data = self._read_req(uuid, base=base)
            if not status:
                return None
            # If data filled maximum size allowed there might be more data
            elif len(data) == (self.att_mtu - 1):
                # Read more while status is OK and length is not 0
                message = []
                while status and len(data):
                    if data:
                        message.extend(data)
                    status, data = self._read_req(uuid, len(message), base=base)
            # Otherwise, just return the short data received
            else:
                return bytearray(data)
            return bytearray(message)
        def write(self, uuid, data, base=None, no_response=False):
            # Use write command if data is within att_mtu - 3 bytes of overhead
            if len(data) <= (self.att_mtu - 3):
                if no_response:
                    self._write_req(uuid, data, base=base)
                else:
                    self._write_cmd(uuid, data, base=base)
            else:
                # Due to overhead, delayed writes are 5 bytes less than att_mtu
                step = self.att_mtu - 5
                for i in range(0, len(data), step):
                    self._write_prep(uuid, data[i:i+step], i, base=base)
                self._write_exec()
        def print_db(self):
            for s in self.central.adapter.db_conns[self.conn_handle].services:
                print(s)
                for ch in s.chars:
                    print(ch)
                    for d in ch.descs:
                        print(d)
                print("================================================================================")
        def on_indication(self, ble_adapter, conn_handle, uuid, data):
            if self.central.debug:
                logger.debug('Indication: {}, {} = {}'.format(conn_handle, uuid, "".join("{:02x}".format(c) for c in data)))
        def on_notification(self, ble_adapter, conn_handle, uuid, data):
                logger.debug('Notification: {}, {} = {}'.format(conn_handle, uuid, "".join("{:02x}".format(c) for c in data)))
            if uuid.value not in self.notifications:
                self.notifications[uuid.value] = Queue.Queue()
            self.notifications[uuid.value].put(bytearray(data))
        def on_conn_param_update_request(self, ble_adapter, conn_handle, conn_params):
                logger.debug('Connection parameters updated at {} seconds'.format(elapsed_time))
        def _read_req(self, uuid, offset=0, base=None):
            status, data = self.central.adapter.read_req(self.conn_handle, BLEUUID(uuid, base=base), offset=offset)
            return status == BLEGattStatusCode.success, data
        def _write_cmd(self, uuid, data, base=None):
            self.central.adapter.write_cmd(self.conn_handle, BLEUUID(uuid, base=base), get_input_as_list(data))
        def _write_req(self, uuid, data, base=None):
            self.central.adapter.write_req(self.conn_handle, BLEUUID(uuid, base=base), get_input_as_list(data))
        def _write_prep(self, uuid, data, offset, base=None):
            self.central.adapter.write_prep(self.conn_handle, BLEUUID(uuid, base=base), get_input_as_list(data), offset)
        def _write_exec(self):
            self.central.adapter.write_exec(self.conn_handle)
    import sys
    import time
    import logging
    logging.basicConfig(filename="debug.log",
                        level=logging.DEBUG,
                        format='%(asctime)s.%(msecs)03d %(levelname)s %(module)s - %(funcName)s: %(message)s',
                        datefmt='%Y-%m-%d %H:%M:%S')
    # Local imports
    import controller
    TARGET_ADDRESS = "E8:FB:13:55:02:24"
    def main(serial_port):
        logger.debug('Serial port used: {}'.format(serial_port))
        central = controller.Central(serial_port)
        central.open()
        peripheral = central.connect(TARGET_ADDRESS)
        if peripheral:
            time.sleep(10)
            while peripheral.is_connected():
                time.sleep(10)
            peripheral.disconnect()
            time.sleep(3)
        logger.info('Closing central')
        central.close()
    if __name__ == "__main__":
        if len(sys.argv) != 2:
            print("{} <serial_port>".format(sys.argv[0]))
            sys.exit(1)
        main(sys.argv[1])
        quit()
    Attached is the Python script which demonstrates the issue. Review the debug.log file produced.
    python nrftester.py COM4
    Using a nrf52832 development board as the central and probably peripheral. You will likely see what I see which is this line in the debug.log file:
    2020-02-14 12:58:11.706 INFO controller - remote_close: Connection closed after 64.07205009460449 seconds with reason BLEHci.remote_user_terminated_connection
    I believe that the Peripheral is initiating the close, but am unsure why. I have all of my sd_gap_disconnect code paths printing debug statements and I am not hitting any of them.
  • Sorry for the late reply.
    When you say ~63 seconds, could it be that it is 65 seconds? It sounds like that would be FIRST_CONN_PARAMS_UPDATE_DELAY + 2 x NEXT_CONN_PARAMS_UPDATE_DELAY. However, I can't see any parameter update requests in the sniffer trace. There should have been one approximately 5 seconds after the connection, and one after 30 seconds.
    However, I see that it is the peripheral that decides to disconnect. Does the peripheral log say anything?
    BR,
    Edvin
  • The Wireshark capture didn't catch the Connection Parameter request being made by the Peripheral. But upon further review on Friday I discovered the Peripheral is making the request but my Python Central code is not sending an appropriate reply. I'm attempting to rework my Central code to fix this and will post my final results. I believe this is the source of the disconnect. One challenge is that this tends to come in during service discovery which prevents the Central from receiving the reply from the Peripheral. Does Nordic plan to fix the EvtSync method to address these timing issues in the driver?
  • The fact that it comes during the discovery procedure shouldn't be a problem, but it is still something you need to handle.
    Please look at some of the ble_central examples from our "normal" SDK.
    E.g. in the ble_app_uart_c example, you can see the event in ble_evt_handler()
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
    Where it replies to the connection update request.
    The answer to the request depends on the parameter preferences in the central projects sdk_config.h file.
    NRF_BLE_SCAN_MIN_CONNECTION_INTERVAL and NRF_BLE_SCAN_MAX_CONNECTION_INTERVAL
    This needs to fit the same parameters for your peripheral (they need to overlap).
    An alternative, if you do not really care about the connection interval is to change something in your peripheral (if you have access to the source code for the peripheral).
    Looking at the ble_app_uart (peripheral) example, in conn_params_init() in main.c, there is a parameter called cp_init which is used in ble_conn_params_init(&cp_init);
    Make sure that cp_init.disconnet_on_fail = false; if you don't want the peripheral to disconnect if the connection parameters aren't satisfied (according to the min and max connection interval settings).
    Edvin
