PC to nRF52832 DK using UART(wired)
Hi
I am using nRF52832 DK, with SES as IDE on Ubuntu-16.04 OS PC. I want to stream some data from PC to DK. The DK is connected to PC for power supply and programming the chip. So I thought of using a USB to UART converter and connect USB to PC and UART pins to DK. I looked at /examples/peripheral/uart example. I want to print the data in debug terminal, to verify that the data received is correct. How do I do that? Does this sound like a good approach to send data from PC to DK? I want to stream data for quite long time(for an hour or so). Can someone help me with this?
Thanks,        Sai Kiran.
    The Segger chip on the nRF52 DK already includes UART to USB serial bridge (Virtual COM port) which you can use. The serial port should show up as ttyACMx (where x = port number) in /dev/ when you connect the DK to your PC.
    Note: the serial port usually requires root permissions by default. You can change that by installing this package: https://github.com/NordicSemiconductor/nrf-udev
    There are no permission issues. I have written a python script to send data through serial port. Here is the Python Code.
    import serial
    ser = serial.Serial('/dev/ttyACM0', 115200)  # open serial port
    print(ser.name)         # check which port was really used
    ser.write(b'Hello')     # write a string
    ser.close()
    On the DK, I am using UART example, found in <SDK_Root>/examples/peripheral/uart/pca10040/blank/ses. I want to see the text "hello" on debug terminal. So, here is the corresponding code for that(am not sure if this is the correct approach).
    main.c file: -
        uint32_t err_code;
        log_init();
        const app_uart_comm_params_t comm_params =
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              UART_HWFC,
              false,
    #if defined (UART_PRESENT)
              NRF_UART_BAUDRATE_115200
    #else
              NRF_UARTE_BAUDRATE_115200
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle,
                             APP_IRQ_PRIORITY_LOWEST,
                             err_code);
    #ifndef ENABLE_LOOPBACK_TEST
        //printf("\r\nUART example started.\r\n");
        NRF_LOG_INFO("UART example started");
        while (true)
            uint8_t cr;
            while (app_uart_get(&cr) != NRF_SUCCESS);
            while (app_uart_put(cr) != NRF_SUCCESS);
            /* Custom code START */
            //uart_init();
            NRF_LOG_INFO("START");
            NRF_LOG_INFO("%s", cr);
            if (cr == 'q' || cr == 'Q')
                printf(" \r\nExit!\r\n");
                while (true)
                    // Do nothing.
    I just added NRF_LOG_INFO(cr) line, to the available example. When I run the code, I do not see any message in Debug terminal. I am able to see hello message in Putty however.
    I don't think it's possible to connect the Debug terminal in SES to a "COM" port. We only use it for RTT logging.
    // Config settings to enable RTT logging
    NRF_LOG_BACKEND_RTT_ENABLED 1
    NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED 0
  • SO does this mean that I will be able to see UART messages only using RTT. I have checked sdk_config.h. NRF_LOG_BACKEND_RTT_ENABLED option is not there. Should I add it to use RTT?
  • Most examples support logging over both UART and RTT, but not all. Maybe the UART/Serial Port Emulation over BLE  example in  \examples\ble_peripheral\ble_app_uart would be a better starting point for you.
