DFU settings HEX-file generated by nrfutil not word-aligned
When using nrfutil to generate a DFU settings page (with backup page) of settings version 2, the .hex-file generated by nrfutil is not word-aligned, i.e. the number of bytes in both the settings page and the backup page is uneven. This results in e.g. the LOAD command in Keil uVision to fail with the following error message:
LOAD $LBootloaderSettings.hex
Erase Done.
Programming Failed!
Error: Flash Download failed  -  "Cortex-M4"
The settings page is generated using the following command-line
nrfutil settings generate --family NRF52 --application <path_to_application.hex> --application-version <app_version> --bootloader-version <bl_version> --bl-settings-version 2 BootloaderSettings.hex
This results in the following .hex file:
As you can see, lines 52...:
:03E32000000000FA
...and 103...:
:03F32000000000EA
both represent the end of the respective settings areas but both contain an uneven amount of bytes.
Changing these lines to
:04E32000000000FFFA
and
:04F32000000000FFEA
makes the files work seamlessly with Keil uVision's LOAD command again without modifying the contents of the settings page.
It would be much appreciated if you could make nrfutil generate a word-aligned HEX-file.
EDIT: I actually created a pull-request in pc-nrfutil:
https://github.com/NordicSemiconductor/pc-nrfutil/pull/301
