Hi Nordic teams,
I'm trying to integrate the DFU function into light_switch example this days. At the beginning, I used the dfu example to update my evaluation board, and it works fine (My evaluation board is starting blinky).
I encountered some issues when I'd integrated the dfu function. For more reliability, I use two files which are identical framework except the RTT logs and advertising name. At the first updating, device send the correct RTT log and advertising name. At the second updating, device only send the correct RTT log but not to start advertising. I can make sure that the parameter of application version is higher than current one. According to the logs in second update, I can confirm that device is already update. Why dose device is unable to advertise?
My environment as below
SDK: Mesh SDK 3.2
Softdevice: S132.6.1.1
Quantity of source role: 1
Quantity of target role: 2
The scripts on source role:
cd %~dp0 :: Generate a DFU file with nrfutil nrfutil dfu genpkg --application bin/light_switch/APK.hex --application-version 3 --company-id 0x68030000 --application-id 1 --key-file private_key.txt --sd-req 0x00B7 --mesh dfu_test.zip cd tools\dfu\ :: Generate a HEX version of device page python device_page_generator.py -d nrf52832_xxAA -sd "s132_6.1.1" cd ..\..\ :: Erase chip memory and flash SoftDevice on all devices nrfjprog -s 682182419 --program bin/softdevice/s132_nrf52_6.1.1_softdevice.hex --chiperase :: Flash the serial bootloader on all devices nrfjprog -s 682182419 --program bin/bootloader/gccarmemb/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex :: Flash the first application on all devices nrfjprog -s 682182419 --program examples/dfu/build/dfu_nrf52832_xxAA_s132_6.1.1_Debug/dfu_nrf52832_xxAA_s132_6.1.1.hex :: Flash the device page on all devices and reset the device nrfjprog -s 682182419 --program tools/dfu/bin/device_page_nrf52832_xxAA_s132_6.1.1.hex nrfjprog -s 682182419 --reset :: Transferring the DFU archive over serial with nrfutil nrfutil dfu serial -pkg dfu_test.zip -p COM67 -b 115200 -fc --mesh pause
The scripts on target role:
cd %~dp0
nrfutil dfu genpkg --application bin/light_switch/APK.hex --application-version 2 --company-id 0x68030000 --application-id 1 --key-file private_key.txt --sd-req 0x00B7 --mesh dfu_test.zip
cd tools\dfu\
cd ..\..\
nrfjprog -s 682236063 --program bin/softdevice/s132_nrf52_6.1.1_softdevice.hex --chiperase
nrfjprog -s 682236063 --program bin/bootloader/gccarmemb/mesh_bootloader_serial_gccarmemb_nrf52832_xxAA.hex
nrfjprog -s 682236063 --program bin/light_switch/My_test.hex
nrfjprog -s 682236063 --program tools/dfu/bin/device_page_nrf52832_xxAA_s132_6.1.1.hex
nrfjprog -s 682236063 --reset
pause
This issue occurred twice. Dose the DFU overwrite the flash contains application data or unprovisioned state?
