https://github.com/NordicPlayground/nrf5-calendar-example
What is lowest power mode where real time clock could run?
How could retain RTC value during reset?
Thanks
Thanks
System ON mode, with LFCLK and RTC running. ~ 2-3 µA.
It will depend on the type of reset. You could try to save the RTC value to a .noinit variable (will not be initialized to zero during startup) that you read at startup, alternatively save the RTC value to flash before the reset, and read it again startup.
Hi Sigurd,
Do you have some example or tutorial about what need to be set for a .noinit variable as I'm receiving linker errors when try
uint32_t test_noinit __attribute__ ((section(".noinit")));
Output/Debug/Exe/ble_app_ss_hid_rtos_pca10040_s112_19.elf section `.noinit' will not fit in region `UNPLACED_SECTIONS'
region `UNPLACED_SECTIONS' overflowed by 4 bytes
Also I'm using FreeRTOS in the app that I'm trying to implement RTC at lowest power mode. Does this affect somehow your previous answer?
Thanks
How does your SES project flash_placement.xml file look like ?
Do you have
<ProgramSection alignment="4" load="No" name=".non_init" />
during reset?
What type of reset are you expecting ?
Hi Sigurd,
yes, I have such line (only attributes order differ): <ProgramSection name=".non_init" load="No" alignment="4"/>
Does it mean I have to use ((section(".non_init"))) ?
About 'Reset' - best if I could handle all types of resets, but for now will be Ok and only for resets which happen when nRF is awakes from seep mode (after button press) and restart which happen when system when some faults happen without user interference?
Thanks
So with ((section(".non_init"))) tested and work Ok so far with soft resets from code or faults, and give random numbers at power up or reset with the 'Reset' button. Didnt find any implications or side effects so far.
Is there a way to find with code how was the nRF booted (power on, reset button, soft reset, ..), so to be able to distinguish is it a random number or number I set before soft reset?
Thanks
