we have developed a custom board using the nrf9160 SICA chip and are now modifying the bifravst cat tracker example to suite our needs.
Basicaly, it samples from ADC and sends the collected data every so often. Between the sampling periods, we would like for the device to consume as little power as possible. Using the low power psm example we get a consumption of around 4.5 μA. I would now like to achieve a similar result in our application.
What I already do is disconnect from lte using:
lte_lc_offline();
And also disable both uart lines in use (as seen here):
void uart_0_disable(void)
NRF_UARTE0->TASKS_STOPTX = 1;
NRF_UARTE0->TASKS_STOPRX = 1;
void uart_1_disable(void)
NRF_UARTE1->TASKS_STOPTX = 1;
NRF_UARTE1->TASKS_STOPRX = 1;
With this I managed to get around 28 μA during idle period (with k_sleep()).
I am now looking for ways to further be able to turn on/off parts of the chip during runtime. Looking at prj.conf (whole file attached) I see that networking, GPS, accelerometer, adc0, and watchdog are enabled:
# General config
CONFIG_NEWLIB_LIBC=y
CONFIG_ASSERT=y
CONFIG_REBOOT=y
CONFIG_LOG=y
CONFIG_LOG_IMMEDIATE=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
CONFIG_LTE_LINK_CONTROL_LOG_LEVEL_DBG=n
CONFIG_POWER_OPTIMIZATION_ENABLE=y
# enables nb-iot and gps networks
CONFIG_LTE_NETWORK_MODE_NBIOT_GPS=y
CONFIG_LTE_LEGACY_PCO_MODE=y
CONFIG_LTE_PSM_REQ_RPTAU="00000110"
CONFIG_LTE_PSM_REQ_RAT="00000000"
# LTE connection timeout in seconds
CONFIG_LTE_NETWORK_TIMEOUT=60
# if nb-iot doesn't connect, try to connect to lte_m (with same timeout)
CONFIG_LTE_NETWORK_USE_FALLBACK=y
# Modem info
CONFIG_MODEM_INFO=y
# BSD library
CONFIG_BSD_LIBRARY=y
CONFIG_BSD_LIBRARY_TRACE_ENABLED=n
# Bifravst Cloud
CONFIG_CLOUD_API=y
CONFIG_BIFRAVST_CLOUD=y
CONFIG_BIFRAVST_CLOUD_LOG_LEVEL_DBG=y
CONFIG_AWS_IOT_BROKER_HOST_NAME="XXXXXXXXXXXXXXXXXXXXXXXXXXX"
# GPS
CONFIG_NRF9160_GPS=y
CONFIG_GPS_SIM=n
CONFIG_NRF9160_GPS_LOG_LEVEL_DBG=y
CONFIG_GPS_USE_EXTERNAL=y
CONFIG_GPS_DEV_NAME="NRF9160_GPS"
CONFIG_GPS_CONTROL=y
CONFIG_GPS_CONTROL_FIRST_FIX_CHECK_DELAY=10
CONFIG_GPS_CONTROL_FIX_CHECK_INTERVAL=30
CONFIG_GPS_CONTROL_FIX_TRY_TIME=360
CONFIG_GPS_CONTROL_PSM_ENABLE_ON_START=y
CONFIG_GPS_CONTROL_PSM_DISABLE_ON_STOP=n
# ADXL362
CONFIG_ADXL362=y
CONFIG_SPI=y
CONFIG_SENSOR=y
CONFIG_ADXL362_TRIGGER_GLOBAL_THREAD=y
CONFIG_ADXL362_INTERRUPT_MODE=1
CONFIG_ADXL362_ABS_REF_MODE=1
CONFIG_ADXL362_ACTIVITY_THRESHOLD=400
CONFIG_ADXL362_INACTIVITY_THRESHOLD=300
# Console
CONFIG_CONSOLE_SUBSYS=y
CONFIG_CONSOLE_HANDLER=y
CONFIG_CONSOLE_GETCHAR=y
# Main thread
CONFIG_MAIN_THREAD_PRIORITY=7
# Heap and stacks
CONFIG_HEAP_MEM_POOL_SIZE=16384
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_HW_STACK_PROTECTION=y
# Disable native network stack to save some memory
CONFIG_NET_IPV4=n
CONFIG_NET_IPV6=n
CONFIG_NET_UDP=n
CONFIG_NET_TCP=n
# Settings
CONFIG_FLASH=y
CONFIG_FLASH_PAGE_LAYOUT=y
CONFIG_FLASH_MAP=y
CONFIG_FCB=y
CONFIG_SETTINGS=y
CONFIG_SETTINGS_FCB=y
CONFIG_MPU_ALLOW_FLASH_WRITE=y
# App Version
CONFIG_CAT_TRACKER_APP_VERSION="0.0.2"
# MCUBOOT
CONFIG_BOOTLOADER_MCUBOOT=y
CONFIG_IMG_MANAGER=y
CONFIG_MCUBOOT_IMG_MANAGER=y
CONFIG_IMG_ERASE_PROGRESSIVELY=y
# AWS FOTA
CONFIG_AWS_FOTA=y
CONFIG_AWS_FOTA_LOG_LEVEL_DBG=y
CONFIG_AWS_JOBS_LOG_LEVEL_DBG=y
CONFIG_AWS_FOTA_VERSION_STRING_MAX_LEN=128
CONFIG_DFU_TARGET=y
# Download client (needed by AWS FOTA)
CONFIG_DOWNLOAD_CLIENT=y
CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
# Time managing
CONFIG_NRF9160_TIMESTAMP=y
CONFIG_NRF9160_TIMESTAMP_LOG_LEVEL_DBG=y
# ADC
CONFIG_GPIO=y
CONFIG_SERIAL=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_TEST_RANDOM_GENERATOR=y
CONFIG_NET_BUF_USER_DATA_SIZE=1
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_RAW_MODE=y
CONFIG_TRUSTED_EXECUTION_NONSECURE=y
CONFIG_LOG_DEFAULT_LEVEL=4
CONFIG_ADC=y
CONFIG_ADC_0=y
CONFIG_ADC_NRFX_SAADC=y
# enable c++ support
CONFIG_CPLUSPLUS=y
# base64 encode/decode
CONFIG_BASE64=y
# Watchdog configuration
CONFIG_WATCHDOG=y
CONFIG_WDT_LOG_LEVEL_DBG=y
# optimize program for speed
CONFIG_SPEED_OPTIMIZATIONS=y
# config uart 1
CONFIG_UART_1_NRF_UARTE=y
CONFIG_UART_1_NRF_FLOW_CONTROL=n
I am mainly looking for pointers on how I can programmatically check whether something is enabled and then to be able to turn it on and off at will. Any help is greatly appreciated.
