Large delay when using app scheduler in GPIOTE interrupt
I have an external chip in SPI slave mode and connected to 52840 through SPI interface. When data is ready it will notify 52840 through its dedicated IRQ pin (connected to one of GPIO of 52840), and then 52840 will read the data back through SPI bus., using SPIM driver.
the software is composed like this:
1. Setup GPIOTE to sense the GPIO/IRQ pin (low to high)
2. in GPIOTE interrupt handler, use app_scheduler to transfer execution to main context.
3. in main context, use SPIM driver to read data back to 52840's RAM.
the above process can run fine and the data read back are all correct. However, a problem is Step 2. has a large delay about 2ms. that is, after app_sched_event_put is called, the data event handler is executed only after 2ms. My application can not tolerant such big delay.
Is this delay normal? if not, what could be the possible reason why it happen?
Major code snippet:
Main.c
    bool erase_bonds;
    // Initialize.
    log_init();
    NRF_LOG_INFO("Starting nrf52840...");
    timers_init();
    power_management_init();
    //init event scheduler;
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    // Enter main loop.
    for (;;)
        //handle usbd event sperately;
        //app_usbd_event_queue_process();
        app_sched_execute();
			idle_state_handle();
            //power_manage();
GPIOTE init:
    ret_code_t err_code;
    UNUSED_VARIABLE(err_code);
    if(!nrf_drv_gpiote_is_init())
    nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
    //in_config.pull = NRF_GPIO_PIN_PULLUP;
    UNUSED_VARIABLE(in_config);
    err_code = nrf_drv_gpiote_in_init(EXT_DATA_IRQ_PIN, &in_config, gpiote_irq_handler);
    //APP_ERROR_CHECK(err_code);
    nrf_drv_gpiote_in_event_enable(EXT_DATA_IRQ_PIN, true);
GPIO interrupt handler
void gpiote_irq_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    if (pin == EXT_DATA_IRQ_PIN) {
        ex_data_event_t evt;
        //fill in data evt;
        app_sched_event_put(&evt, sizeof(evt), data_event_dispatch);
app scheduler event hander:
void data_event_dispatch(void *p_event_data, uint16_t event_size) {
    ex_data_event_t* p_evt = (ex_data_event_t*)p_event_data;
    switch (p_evt->pa_ops) {
        case DATA_OPS_TYPE_EXT_PA_ON:
            //NRF_LOG_DEBUG("[ext]\tswitch PA on...");
    rolandash said:
    So the question is scheduler event not able to wake up CPU? or it is because the GPIOTE interrupt handler somehow put CPU back to sleep again after completion?
    The schedule is just a queue that you pop in the main loop, so it does not wake the CPU from sleep. However, that is not necessary either. In this case, you call it from an interrupt/event handler, so the CPU is awake. Therefore, it will run until it executes sd_app_evt_wait(). And similarly, after any events/interrupts are processed, the main/thread will run from the last call to sd_app_evt_wait() (or WFE/WFI if called directly).
    Do you call sd_app_evt_wait(), WFE or WFI from anywhere other than a single place in your main loop (via idle_state_handle and possible nrf_pwr_mgmt_run())? If so, that could explain this behaviour.
