Changing the transmission power on ble_app_att_mtu_throughput example
I have searched Devzone for changing the transmission power; even though there were similar issues related to mine but at the end, It did not help me.
I am evaluating the new PHYs of BLE 5 in an indoor environment at the university.
I tried to use the following codes:
ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, BLE_CONN_HANDLE_INVALID, RADIO_TX_POWER); ( inside scan_start function)
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, BLE_CONN_HANDLE_INVALID, RADIO_TX_POWER); ( I used this one inside
ble_evt_handler function under BLE_GAP_EVT_CONNECTED.)
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, RADIO_TX_POWER); (I used this one inside advertising_start function)
I get fatal error!!
I know there is a long range example but I really want to use the throughput example with modified transmission power.
I do not know in which part I am doing wrong!!! Any help will be appreciated.
Br,
Ben
  • Hi Joakim,
    Yes, I have seen that answer. It did not help. It is strange. Perhaps I am doing some silly mistake.
    I have compared the throughput example and the long-range example. I can not figure it out why it throws Fatal error.
    These are the places that I have used "sd_ble_gap_tx_power_set" functtion in the code:
    case BLE_GAP_EVT_CONNECTED:
    on_ble_gap_evt_connected(p_gap_evt);
    sd_ble_gap_rssi_start(p_ble_evt->evt.gap_evt.conn_handle, 1, 1); //added by _OP
    /**@brief Function for starting advertising. */
    NRF_LOG_INFO("Starting advertising.");
    ret_code_t err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_adv_handle, RADIO_TX_POWER);
    bsp_board_led_on(SCAN_ADV_LED);
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    /**@brief Function for starting the scanning. */
    static void scan_start(void)
    NRF_LOG_INFO("Starting scanning.");
    err_code = nrf_ble_scan_start(&m_scan);
    Thanks for the help.
    Br,
    Ben
    I resolved the issue by changing:
    to
    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN, m_conn_handle, RADIO_TX_POWER);
    The problem was in passing the correct connection handle to "sd_ble_gap_tx_power_set" function in connection state.
    Br,
    Ben
  • Thanks for sharing your solution!
    Joakim
