lwm2m_client sample fails with "Compiling the C compiler identification source file "CMakeCCompilerId.c" failed."
I am trying to build the lwm2m_client sample on my ubuntu 16.04 machine.  I tried building for nrf9160_pca10090ns and nrf9160_pca20035ns The build fails with:
ERROR: command exited with status 1: /usr/local/bin/cmake --build /home/pascal/nrf/samples/nrf9160/lwm2m_client/build
When I look at the CMakeError.log file this is what it says:
Compiler: /opt/gnuarmemb/gcc-arm-none-eabi-8-2019-q3-update/bin/arm-none-eabi-gcc
Build flags:
Id flags:
The output was:
1
/opt/gnuarmemb/gcc-arm-none-eabi-8-2019-q3-update/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld: /opt/gnuarmemb/gcc-arm-none-eabi-8-2019-q3-update/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): in function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: /opt/gnuarmemb/gcc-arm-none-eabi-8-2019-q3-update/bin/arm-none-eabi-g++
Build flags:
Id flags:
The output was:
1
I should mention that I only run into this error with this one particular sample, I have successfully built applications with this compiler before.
I am not sure what this due to. I tried using a more recent compiler. I installed gcc-arm-none-eabi-9-2019-q4-major and edited my env variables accordingly but I get the same error with the new compiler as well.
  • Hello Heidi,
    So I found the mcuboot folder in an older installation on my windows machine. I copied it to the ncs folder and ran west update. Now the sample builds fine for nrf9160_pca10090ns, but when I try to build it for nrf9160_20035ns (My actual target hardware). I get these errors:
    ../src/lwm2m/lwm2m_button.c: In function 'handle_button_events':
    ../src/lwm2m/lwm2m_button.c:32:23: error: operator '>' has no left operand
     #if CONFIG_FLIP_INPUT > 0
    ../src/lwm2m/lwm2m_button.c: In function 'lwm2m_init_button':
    ../src/lwm2m/lwm2m_button.c:65:23: error: operator '!=' has no left operand
     #if CONFIG_FLIP_INPUT != UI_BUTTON_1
    ../src/lwm2m/lwm2m_button.c:76:23: error: operator '!=' has no left operand
     #if CONFIG_FLIP_INPUT != UI_BUTTON_2
    ../src/lwm2m/lwm2m_button.c:87:23: error: operator '!=' has no left operand
     #if CONFIG_FLIP_INPUT != UI_SWITCH_1
    ../src/lwm2m/lwm2m_button.c:98:23: error: operator '!=' has no left operand
     #if CONFIG_FLIP_INPUT != UI_SWITCH_2
    At top level:
    ../src/lwm2m/lwm2m_button.c:20:14: warning: 'timestamp' defined but not used [-Wunused-variable]
     static s32_t timestamp[4];
    Are there some configs I need to set or is this sample not compatible with that board.
    Unfortunately, the LwM2M Client sample has not been written for the pca20035 board. In theory, the sample should work on the board, so you could try to port it yourself.
  • Got it.
    I am very new to all this. Which files would I need to edit in order to port it to the pca20035?
