app_uart_get more than 1 byte
I'm using app_uart for communication between different mcu. I can send more than 1 byte like "0x3917015623"  through  changing tx_buffer[0] to tx_buffer[5]. Unfortunately i couldn't recieve the slave devicess message "0x2917013607". I can only get the first byte "0x07". My configuration are the same as uart example. How can i recieve all the message ?. I tried to use serial library but i couldn't initialize. (It gave ERROR 6 NRF_ERROR_NOT_SUPPORTED).
Slave device is sending me a message every second. And i'm calling app_uart_get function every 500 miliseconds.
Here is my uart init;
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
void uart_init(void)
    uint32_t err_code;
    const app_uart_comm_params_t comm_params =
            RX_PIN_NUMBER,
            TX_PIN_NUMBER,
            RTS_PIN_NUMBER,
            CTS_PIN_NUMBER,
            UART_HWFC,
            false,
  #if defined (UART_PRESENT)
            NRF_UART_BAUDRATE_115200
  #else
            NRF_UARTE_BAUDRATE_9600
//    const app_uart_buffers_t m_buffers =
//        &rx_buffer_s,
//        sizeof(rx_buffer_s),
//        &tx_buffer_s,
//        sizeof(tx_buffer_s)
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_error_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
//      err_code = app_uart_init(&comm_params, &m_buffers, uart_error_handle, APP_IRQ_PRIORITY_LOW);
//      APP_ERROR_CHECK(err_code);
  • I tried to use serial library but i couldn't initialize. (It gave ERROR 6 NRF_ERROR_NOT_SUPPORTED).
     Which function returned NRF_ERROR_NOT_SUPPORTED?
  • nrf_serial_init function was returning NRF_ERROR_NOT_SUPPORTED. I fixed that error yesterday. I did a lot of things. I couldn't remember exactly but i remember that i changed some code in nrf_serial.c . Now, i can send 5 byte data on TX_PIN  but i received wrong data from slave. Also i am using MAX485 IC for communication. I need to set RTS_PIN before sending operation and clear it before receive operation. But nrf_gpio_pin_set or nrf_gpio_pin_clear command doesn't effect the RTS_PIN. When i deactive UART module then these command are starting to work. When UART module enabled, RTS_PIN goes high at wrong time and out of my control. Time between sending operation and RTS_PIN high is about 95 ms. It should be at the same time. So how can i control RTS pin while UART Module enabled.(I can control other gpio when uart enabled.)
    here is my serial init code:
    NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
                          RX_PIN_NUMBER, TX_PIN_NUMBER,
                          RTS_PIN_NUMBER, CTS_PIN_NUMBER,
                          NRF_UART_HWFC_ENABLED, NRF_UART_PARITY_EXCLUDED,
                          NRF_UART_BAUDRATE_9600,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY);
    #define SERIAL_FIFO_TX_SIZE 32
    #define SERIAL_FIFO_RX_SIZE 32
    NRF_SERIAL_QUEUES_DEF(serial_queues, SERIAL_FIFO_TX_SIZE, SERIAL_FIFO_RX_SIZE);
    #define SERIAL_BUFF_TX_SIZE 5
    #define SERIAL_BUFF_RX_SIZE 5
    NRF_SERIAL_BUFFERS_DEF(serial_buffs, SERIAL_BUFF_TX_SIZE, SERIAL_BUFF_RX_SIZE);
    NRF_SERIAL_CONFIG_DEF(serial_config, NRF_SERIAL_MODE_IRQ,
                          &serial_queues, &serial_buffs, NULL, NULL);
    NRF_SERIAL_UART_DEF(serial_uart, 0);
        ret_code_t ret;
    //    ret = nrf_drv_clock_init();
    //    APP_ERROR_CHECK(ret);
    //    ret = nrf_drv_power_init(NULL);
        ret = app_timer_init();
        ret = nrf_serial_init(&serial_uart, &m_uart0_drv_config, &serial_config);
  • Which nRF52 IC are you using?
     You have enabled HWFC so this should be managed automatically by the UART/UARTE peripheral. Note that CTS (Clear To Send) and  RTS (Request To Send) are both active low.
  • I am using nrf52810. I disabled HWFC and now i can send and recieve the message. But i got some mistakes on receiving part. The message i should take is "0xAAAA011729"
    Message is 5 bytes, "AAAA" is changing always.
    What i received :
    <info> app: Received data : 1172978
    <info> app: Received data : 17297748
    <info> app: Received data : 29764901
    <info> app: Received data : 754A0117
    <info> app: Received data : 4B011729
    <info> app: Received data : 1172974
    <info> app: Received data : 1729734C
    <info> app: Received data : 17724D01
    The message is true but not in same order. I am using uint32_t variable for recieve operation. I used uint64_t but nothing changed it still got wrong order. I think i must clear rx_buffer after receiving.
  • Do you have the possibility to capture the data on the UART lines using a logic analyzer? That would help us identify if the data is sent correctly on the data lines but received incorrectly by the nRF52810.
