I have a BLE board with a nRF52832 and some peripherals. It came with a preinstalled bootloader and firmware (the bootloader supports DFU via BLE to upgrade the bootloader and the firmware).
In the past I wrote my own firmware for the board based on a example from the nRF SDK. I erased the whole board using nRFgo Studio and used the debug link of a nRF51 devkit to flash a softdevice and my own firmware. All that worked flawlessly.
Now I want to reinstall the bootloader and firmware that came with the board (I just need to install the bootloader, the firmware is then easily installed via BLE DFU). My problem is that I don't have the hex file of that bootloader, I only have the .zip files for DFU and I do not know how to install them without a bootloader already running.
I have two zip files, one that only contains the bootloader and one that contains bootloader and softdevice. Both contain 3 files: *.bin, *.dat and manifest.json.
What is the easiest way to install that firmware on the board?
The manifest.json files look like this:
only bootloader:
"manifest": {
"bootloader": {
"bin_file": "ebootloader.bin",
"dat_file": "ebootloader.dat",
"init_packet_data": {
"application_version": 4294967295,
"device_revision": 2,
"device_type": 5,
"firmware_crc16": 52615,
"softdevice_req": [
168
"dfu_version": 0.5
bootloader with softdevice:
"manifest": {
"dfu_version": 0.5,
"softdevice_bootloader": {
"bin_file": "sd_bl.bin",
"bl_size": 16384,
"dat_file": "sd_bl.dat",
"device_type": 5,
"firmware_crc16": 61420,
"softdevice_req": [
65534
"sd_size": 146000
