Unable to load Asset Tracker as nRF Connect SDK Project in Segger Embedded Studio
Hi!
I have recently setup the development environment for my Thingy 91 on Windows 10 environment using nRF Connect Getting Started Assistant. But I am having some trouble importing this application in the Segger Embedded Studio as a nRF Connect SDK project. The output from the execution of loading commands is shown below:
Loading solution asset_tracker.emProject
Executing load commands
cmake -GNinja -DBOARD=nrf9160_pca20035ns -DBOARD_DIR=C:/Users/Haris/OneDrive - TalTech/Autumn 2019/Master's Thesis/Nordic Semi/nrf9160dk/ncs/nrf/boards/arm/nrf9160_pca20035 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/Program Files (x86)/GNU Tools ARM Embedded/8 2019-q3-update -BC:/Users/Haris/OneDrive - TalTech/Autumn 2019/Master's Thesis/Nordic Semi/nrf9160dk/ncs/nrf/applications/asset_tracker/build_nrf9160_pca20035ns -HC:/Users/Haris/OneDrive - TalTech/Autumn 2019/Master's Thesis/Nordic Semi/nrf9160dk/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Program Files/arm_segger_embedded_studio_v430c_win_x64_nordic/html/configure_nordic_project_menuconfig.py
-- Zephyr version: 2.1.99
-- Selected BOARD nrf9160_pca20035ns
-- Found west: C:/Python38/Scripts/west.exe (found suitable version "0.6.3", minimum required is "0.6.0")
CMake Error at C:/Users/Haris/OneDrive - TalTech/Autumn 2019/Master's Thesis/Nordic Semi/nrf9160dk/ncs/zephyr/cmake/kconfig.cmake:160 (message):
  File not found: C:/Users/Haris/OneDrive/nrf9160_pca20035ns_defconfig
  C:/Users/Haris/OneDrive - TalTech/Autumn 2019/Master's Thesis/Nordic Semi/nrf9160dk/ncs/zephyr/cmake/app/boilerplate.cmake:461 (include)
  CMakeLists.txt:12 (include)
Project load failed
Reported error: solution load command failed (1)
Can someone help me with this issue?
Thanks.
Haris Ahmed
  • Hi.
    Can you send me a picture of the "Open nRF Connect SDK Project..." window, showing the paths you have entered?
    Other than that, I can see two other potential problems:
    1. There are spaces in your path. Not all tools are able to handle that.
    2. Your path is long. Windows has a limit on the length of the file path, which can cause "file not found" errors. Try to move the ncs folder closer to the file system root ("C:").
    Didrik
  • Thank you for your response.
    Following your feedback I moved ncs folder to C: and then tried to import the project with the following parameters:
    Now I am getting following errors:
    cmake -GNinja -DBOARD=nrf9160_pca20035 -DBOARD_DIR=C:/ncs/nrf/boards/arm/nrf9160_pca20035 -DZEPHYR_TOOLCHAIN_VARIANT=gnuarmemb -DGNUARMEMB_TOOLCHAIN_PATH=C:/Program Files (x86)/GNU Tools ARM Embedded/8 2019-q3-update -BC:/ncs/nrf/applications/asset_tracker/build_nrf9160_pca20035ns -HC:/ncs/nrf/applications/asset_tracker -DEXTRA_KCONFIG_TARGETS=menuconfig_ses -DEXTRA_KCONFIG_TARGET_COMMAND_FOR_menuconfig_ses=C:/Program Files/arm_segger_embedded_studio_v430c_win_x64_nordic/html/configure_nordic_project_menuconfig.py
    -- Loading C:/ncs/nrf/boards/arm/nrf9160_pca20035/nrf9160_pca20035.dts as base
    Devicetree configuration written to C:/ncs/nrf/applications/asset_tracker/build_nrf9160_pca20035ns/zephyr/include/generated/devicetree.conf
    warning: BSD_LIBRARY (defined at C:/ncs/nrf\lib\bsdlib/Kconfig:8) has direct dependencies TRUSTED_EXECUTION_NONSECURE with value n, but is currently being y-selected by the following symbols:
     - MODEM_INFO (defined at C:/ncs/nrf\lib\modem_info/Kconfig:7), with value y, direct dependencies y (value: y)
    Parsing C:/ncs/nrf/applications/asset_tracker/Kconfig
    C:/ncs/nrf\lib\fprotect/Kconfig:20: WARNING: dt_int_val is deprecated.
    C:/ncs/bootloader/mcuboot/zephyr/Kconfig:37: WARNING: dt_int_val is deprecated.
    error: Aborting due to Kconfig warnings
    Loaded configuration 'C:/ncs/nrf/boards/arm/nrf9160_pca20035/nrf9160_pca20035_defconfig'
    Merged configuration 'C:/ncs/nrf/applications/asset_tracker/prj.conf'
    CMake Error at C:/ncs/zephyr/cmake/kconfig.cmake:216 (message):
      command failed with return code: 1
      C:/ncs/zephyr/cmake/app/boilerplate.cmake:461 (include)
    Project load failed
    Can you tell what is the issue now?
    Thanks.
  • It does not look like the log and the picture matches.
    In the picture, you select the board nrf9160_pca20035ns, while the log uses nrf9160_pca20035 (not "ns").
    Were the picture and the log taken at the same attempt?
    Could you try to import the project again, making sure that you use the non-secure version of the board (nrf9160_pca20035ns)?
  • You are correct. There was a mismatch between the log and the picture. After selecting the (nrf9160_pca20035ns), I am able to load the project successfully.
    Thank you very much for your help.
    Haris Ahmed
