MQTT-SN won't connect as SED while "THREAD_RADIO_MODE_RX_OFF_WHEN_IDLE"
I'm struggling to connect to an MQTT-SN Gateway when the device is configured for low power.  Currently using MAC-OS Catalina 10.15.3, SES version 4.42 and have tried Nordic + Thread SDK's version 3.2 and version 4.
I can't register an MQTT-SN device when the thread_instance_init is called with ".radio_mode" set to "THREAD_RADIO_MODE_RX_OFF_WHEN_IDLE"  If I build the project with this configuration, the gateway configuration fails and returns "app: MQTT-SN event: Gateway discovery result: 0x3"
I can change the radio mode to "THREAD_RADIO_MODE_RX_ON_WHEN_IDLE" and it all works as expected, but the current consumption is unacceptably high for my proposed application.  I have looked at the gateway configuration on my MQTT-SN gateway and I don't see anything obvious that could change here to solve this issue.
Ultimately, I guess I'm asking"
  A: Can other people successfully register/publish/subscribe to MQTT using the "thread_mqtt_sn_sleepy_publisher_pcba10056" example project?
  B: If not, is there a workaround for this to be able to use MQTT-SN as a SED?
Thanks and Best Regards,
Roger
    Have you seen the test guidelines for the sleepy subscriber and publisher projects on the infocenter? Are you using our thread border router as the MQTT-SN gateway or a third party's? Are you struggling to connect the example out of the box or have you made any modifications?
    Marjeris
  • Hi Marjeris,
    I have reviewed the test guidelines and I don't think there's anything I'm missing there (I could always be wrong on that).  I am using a Raspberry Pi with the Nordic Thread Border Router image and using an NRF52840 Dongle as the NCP.  I am pretty much using the SDK examples out of the box, the only modification I've made is to the sdk_config.h file to clear the NRF_FPRINTF_FLAG_AUTOMATIC_CR_ON_LF_ENABLED  flag for debugging within SES.  I've also set the channel and PANID over the CLI to connect to my network.  Those are the only changes.
    The mqttsn_client_publisher example works as described in the test guidelines.  The mqttsn_sleepy_publisher works as described if I change the thread configuration radio mode to RX_ON_WHILE_IDLE, but out of the box it isn't able to connect to the gateway.
    I tested this on my setup. Initially, I got an error when changing the radio mode to :
    <info> app: MQTT-SN event: Gateway discovery result: 0x3.
    I then set the poll_period and child_timeout parameters, similar to the MQTT-SN Sleepy Subscriber example:
    thread_configuration_t thread_configuration =
        .radio_mode        = THREAD_RADIO_MODE_RX_OFF_WHEN_IDLE,
        .autocommissioning = true,
        .poll_period           = DEFAULT_POLL_PERIOD,
        .default_child_timeout = DEFAULT_CHILD_TIMEOUT,
    I was then able to find and connect the gateway as normal:
    <info> app: Thread version   : OPENTHREAD/20180926-01143-g8a1992e2; NRF52840; Dec 10 2019 22:48:00
    <info> app: Network name     : NordicOpenThread
    <info> app: Thread interface has been enabled.
    <info> app: 802.15.4 Channel : 11
    <info> app: 802.15.4 PAN ID  : 0xABCD
    <info> app: Radio mode       : rx-off-when-idle
    <warning> app_timer: RTC instance already initialized.
    <info> app: State changed! Flags: 0x011FD33D Current role: 1
    <info> app: State change<info> app: MQTT-SN event: Client has found an active gateway.
    <info> app: MQTT-SN event: Client connected.
    <info> app: MQTT-SN event: Client registered topic.
    <info> app: MQTT-SN event: Topic has been registered with ID: 1.
    <info> app: MQTT-SN event: Gateway discovery procedure has finished.
    <info> app: MQTT-SN event: Gateway discovery result: 0x0.
    <info> app: MQTT-SN event: Client has successfully published content.
    Jørgen
  • Thank you for the assistance Jørgen and Marjeris!
    Roger
