NRF52832 Serial Bootloader(without SD) fails to boot app
I am using NRF52832 in a custom board with SDK 15.3 and trying to implement the secure uart bootloader. I am able to download applications via uart bootloader however the application is not started after that. I verified that the application works separately without a bootloader.
My doubt is if there is no softdevice do I need to take of anything additional in the bootloader. Because in the code I can see that the bootloader tries to start the application by jumping to the end of MBR 0x1000, is this address same in this case also without a SD.
/** @brief The size that must be reserved for the MBR when a SoftDevice is written to flash.
This is the offset where the first byte of the SoftDevice hex file is written. */
#define MBR_SIZE (0x1000)
