I am trying to perform ADC conversions controlled by Timer with minimal manual interaction. My goal is that every 2 seconds, the ADC takes 10 samples in quick succession. For that I configured 2 timers (timer1 2000ms , timer2 10ms).
Then I configured the PPI channels that timer1 triggers timer2, and timer2 triggers the ADC conversion (ADC is set up to collect 10 samples with nrf_drv_adc_buffer_convert). That works fine so far, but when the conversion is done, I need the PPI to stop timer2, which does not work.
Here is the code of my PPI initialization:
static void ppi_init(void)
uint32_t err_code = NRF_SUCCESS;
// Configure 1st available PPI channel to start TIMER2 on TIMER1 COMPARE[0] match
err_code = nrf_drv_ppi_channel_alloc(&ppi_channel1);
err_code = nrf_drv_ppi_channel_assign(ppi_channel1,
nrf_drv_timer_event_address_get(&timer1, NRF_TIMER_EVENT_COMPARE0),
nrf_drv_timer_task_address_get(&timer2,NRF_TIMER_TASK_START));
// Configure 2nd available PPI channel to start ADC sampling on TIMER2 COMPARE[0] match
err_code = nrf_drv_ppi_channel_alloc(&ppi_channel2);
err_code = nrf_drv_ppi_channel_assign(ppi_channel2,
nrf_drv_timer_event_address_get(&timer2, NRF_TIMER_EVENT_COMPARE0),
nrf_drv_adc_start_task_get());
// Configure 3nd available PPI channel to stop TIMER2 on ADC sampling finished
err_code = nrf_drv_ppi_channel_alloc(&ppi_channel3);
err_code = nrf_drv_ppi_channel_assign(ppi_channel3,
nrf_adc_event_address_get(NRF_DRV_ADC_EVT_DONE),
nrf_drv_timer_task_address_get(&timer2, NRF_TIMER_TASK_STOP));
// Enable all configured PPI channels
err_code = nrf_drv_ppi_channel_enable(ppi_channel1);
err_code = nrf_drv_ppi_channel_enable(ppi_channel2);
err_code = nrf_drv_ppi_channel_enable(ppi_channel3);
I am suspecting that the event "NRF_DRV_ADC_EVT_DONE" is not right. As a workaround I call nrf_drv_timer_pause(&timer2); in my ADC event handler, which does what I need, but It would be nice if the PPI could handle that for me. So how should I configure ppi_channel3 to work with the ADC-Done Event?
I am using SDK12.3 with an NRF51822.
Thanks
