Hi All:
Applyed the under timeslot :
causes some peripherals(eg:static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(2)) no access interrupt,
what 's the matter?
Hi All:
what 's the matter?
What do you mean by "no access interrupt" ? Please elaborate
Hi:
But called the above timeslot ,timer cannot enter callback properly.There's no print on it.
1) Are you doing anything with TIMER2 in radio_callback() ?
2) Does it start to print again when you exit radio_callback()/ the timeslot ?
3) Any difference in behavior if you set NRF_LOG_DEFERRED to 0 in sdk_config.h ?
Hi:
1, radio_callback() unused TIMER2,It is not only TIMER2 cannot enter callback, And PPI doesn't start.
the follow code snippet:
2. Yes! when exit radio_callback(),It can start to print.
3.Try to set NRF_LOG_DEFERRED to 0 in sdk_config.h, The result is the same. Has nothing to do with it.
While you are inside the radio_callback() / signal handler, you won't be able to process any interrupt before you exit the signal handler, since the signal handler runs at the highest priority. See this link
