Why is saadc reading taking more than expected time and why do i have to put delay between readings
Hi
i am trying to reduce the adc read times to a minimum we currently have it setup for 3us acq and 32 samples so expecting something close to 160us
Its getting around 250us.
Below is how I set it up and do the adc reads
You will see for each read I need to change gain and input pin
Q1 Am I doing the correct thing below (it works) or am i doing something unnecessary
and making the read cycles longer than necessary.
If my code is good any suggestions on how we can reduce the time
Q2 I am finding I have to put large delays in order of milliseconds to get good readings every time
if I dont some readings come back all FS IE 4095
FIRST TIME THROUGH
void saadc_adc_init(void) {
ret_code_t err_code;
nrf_drv_saadc_config_t adc_config;
adc_config.resolution = (nrf_saadc_resolution_t)NRF_SAADC_RESOLUTION_12BIT;
adc_config.oversample = (nrf_saadc_oversample_t)NRF_SAADC_OVERSAMPLE_DISABLED;
adc_config.interrupt_priority = NRFX_SAADC_CONFIG_IRQ_PRIORITY;
adc_config.low_power_mode = NRFX_SAADC_CONFIG_LP_MODE;
err_code = nrf_drv_saadc_init(&adc_config, saadc_callback);
CALL following function
to setup for the provided pin and gain
void saadc_channel_init(saadc_adc_input_t adc_input, saadc_adc_input_gain_t adc_ip_gain) {
nrf_saadc_channel_config_t channel_config;
channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;
channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
channel_config.gain = adc_ip_gain;
channel_config.reference = NRF_SAADC_REFERENCE_INTERNAL;
channel_config.acq_time = NRF_SAADC_ACQTIME_3US; // Note this was 3us on the prototype
channel_config.mode = NRF_SAADC_MODE_SINGLE_ENDED;
channel_config.burst = NRF_SAADC_BURST_DISABLED;
channel_config.pin_p = (nrf_saadc_input_t)(adc_input);
channel_config.pin_n = NRF_SAADC_INPUT_DISABLED;
// Channel number can be 0 -7 We may wish to use same channel for each ADC we read
err_code = nrf_drv_saadc_channel_init(0, &channel_config);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], ADC_SAMPLES_BUFFER_LEN);
err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], ADC_SAMPLES_BUFFER_LEN);
Call the following to start ADC
THEN ON SUBSEQUENT adc reads I do this
nrf_drv_saadc_uninit();
Call my function above
saadc_adc_init(..)
Call my function above to init with new pin and gain
saadc_channel_init(...
Then enable it
  • Do you only take one sample before you change the SAADC settings?
    Do you disable the ppi channel after you've taken one sample?
    What do you use to trigger m_ppi_channel?
    Why do you not want to use more than one channel?
             Its set up to take 32 samples controlled by the PPI, so we kick it off and when its done we have 32 samples in the buffer. We would then change the input and gain and run again on the new input.
               No , see the event handler at the bottom of this reply, you now have all the code involved,
                NOTE I commented out all my logging when I was measuring the time
              As per my code above I call   nrf_drv_ppi_channel_enable(m_ppi_channel);
                I didnt think of that or was aware I could, I am relatively new to this.
                So are you suggesting I can pre-configure 3 channels for the 3 inputs I have and then just switch the channel for each read cycle. If so can you point me to an example ?
    I assume I would be able to keep the remaining code the same using the one timer and ppi channel ?
    In our application we have 3 gpios connected to 3 different analog sources, apart from the input pin being different the gain is different for all 3.  We need this to be as fast as possible. We dont scan all 3 sequentially in the same order, sometimes its 2 sometimes all 3 and in different order.
    Thanks Robin
  • "As per my code above I call   nrf_drv_ppi_channel_enable(m_ppi_channel);"
    Yes, but what event triggers this channel? Are you using a TIMER?
    "I didnt think of that or was aware I could, I am relatively new to this. "
    From the SAADC specification:
    When multiple channels are enabled, they are sampled successively in a sequence starting with the lowest channel number. The time it takes to sample all enabled channels is given as follows:
    Total time < Sum(CH[x].tACQ+tCONV), x is the number of enabled channels
    A DONE event is generated for every single completed conversion, and an END event is generated when multiple samples, as specified in RESULT.MAXCNT, have been written to memory.
    You can enable three channels with different gain settings, increase the buffer to 96, trigger the sample task 32 times to fill the buffer.
    See Scan mode.
    "We need this to be as fast as possible. "
    This will take 32samples x 3channels x (3µs+2µs) = 480µs if the sample task is triggered as fast as possible, f.ex every 5µs, or 80 ticks of a 16MHz TIMER.
     "We dont scan all 3 sequentially in the same order, sometimes its 2 sometimes all 3 and in different order. "
    You can't change the order the channels are sampled in when using scan mode, but you can enable/disable a channel during between samples.
    Can you specify exactly what it is you're trying to achieve with the SAADC?
  • Hi
    I will explain it again hopefully it will be clearer. (The code is at the bottom with some I missed)
    We have 3 ADC inputs that require different gain settings, we use PPI/TIMER/SAADC to read the ADC as required. We DONT want to ever scan all 3 sequentially, it will vary between scanning individually and some times scan a combination of any 2.
    We need to keep scan time and current to minimum possible.
    I know theoretically the scan time for one ADC is going to be 5us x 32 = 160us , the only over head is the code to set it up and then collect the result. That is why I wanted to check that I am not doing any unnecessary work, and from what you have said it seems I could pre-configure 3 channels at start up and then just enable the ones I need on each scan call.
    Please the code/functions at the bottom here are the calls I make to those functions, how can this be improved and changed so I can use less code ?
    1) POWER UP: I call
        saadc_sampling_event_init();
        saadc_adc_init();
    2) VERY FIRST ADC READ: I call
        saadc_channel_init( <the adc input I want IE AIN0....AINx>, <gain required> );
    3) SUBSEQUENT ADC READS: I call
         saadc_setup_next_adc_read(<the adc input I want IE AIN0....AINx>);   # Gain is determined in function
    1) POWER UP
    This is where our timer is setup
    void saadc_sampling_event_init(void) {
    /* setup m_timer for compare event every 5us 200Khz */
    uint32_t ticks = nrf_drv_timer_us_to_ticks(&m_timer, 5); // Note same as prototype
    NRF_TIMER_CC_CHANNEL0,
    ticks,
    NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
    false);
    uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
    NRF_TIMER_CC_CHANNEL0);
    uint32_t saadc_sample_task_addr = nrf_drv_saadc_sample_task_get();
    timer_compare_event_addr,
    saadc_sample_task_addr);
    In here we setup the channel to use, I assume we could do this for all 3 inputs using different channels on power up, but will this enable them ?  We want to enable the one or two we want at the time and then read
    This is called for subsequent reads which in turn calls functions above. Could this be simplified I just want to change the ADC input and then read again.
    void saadc_setup_next_adc_read(saadc_adc_input_t adc_input) {
    saadc_adc_uninit();
     saadc_ctrl_channel_uninit(last_adc_read_state);
    saadc_adc_init();
    if (adc_input == SAADC_ADC_INPUT_VREF)
    saadc_channel_init(adc_input, SAADC_ADC_INPUT_GAIN_1_2);
    else if (adc_input == SAADC_ADC_INPUT_OPAMP_OUT)
    saadc_channel_init(adc_input, SAADC_ADC_INPUT_GAIN_1_4);
    else if (adc_input == SAADC_ADC_INPUT_BATTERY)
    saadc_channel_init(adc_input,SAADC_ADC_INPUT_GAIN_1_6);
    NRF_LOG_ERROR("saadc_setup_next_adc_read() Invalid ADC input\n");
  • There's is something that you can do that will lower the overhead by quite a bit. When you initialize the SAADC you should also initialize all three channels with their proper settings, then call:
    //Disable all three channels
    NRF_SAADC->CH[0].PSELP = 0;
    NRF_SAADC->CH[1].PSELP = 0;
    NRF_SAADC->CH[2].PSELP = 0;
    For each time you want to sample a channel:
    // Disable last channel used
    NRF_SAADC->CH[<previous channel>].PSELP = 0;
    // Enable the next channel
    NRF_SAADC->CH[<next channel>].PSELP = <pin number>;
    // Prepare the data buffer
    The channel settings will be stored even though they are disabled, you do not need to un-initialize the SAADC driver.
