fpu-fft demo on nrf52840
Hi, engineer:
   I need to compute FFT on nrf52840, I used sdk-demo fpu-fft,  I tested the FFT operation time and found that it took 2 ms,That`s a long time,  Did I configure anywhere is wrong. I wonder how long it will take that 52840 to calculate the complex FFT of 256 points.  thanks!
  • Hi
    What are you measuring? The time spend by the fft_process(..) function, or the time spent by the fft_generate_samples(..) function?
    I did a test myself and measured the fft_process(..) function to run in about 128us.
    The fft_generate_samples(..) function spends closer to 2ms, but you can optimize this by replacing the call to the sin() function by sinf(). Most likely the developers made a small mistake and used the double version instead of the float version of the sin function.
    Increasing the output length to 256 points increases the fft_process(..) runtime to 170us in my test.
    Best regards
    Torbjørn
  • Hi, ovrebekk:
    I measured the fft_process(...) function, I modified the Demo to compute the complex number FFT-256
    , fft_process(...) function takes about 2.5ms.
    demo_project: nRF5_SDK_14.2.0_17b948a\examples\peripheral\fpu_fft\  fpu_fft_example_blank_pca10056_irq.uvprojx
    modify point:
    1.
    #define FFT_TEST_COMP_SAMPLES_LEN        512  //128 --> 512
    2.
    nrf_gpio_pin_write(ARDUINO_13_PIN, 1);
    fft_process(m_fft_input_f32,
    &arm_cfft_sR_f32_len256,        //arm_cfft_sR_f32_len64 --> arm_cfft_sR_f32_len256
    m_fft_output_f32,
    FFT_TEST_OUT_SAMPLES_LEN);
    nrf_gpio_pin_write(ARDUINO_13_PIN, 0);
    measured method:
    I use an oscilloscope to check the IO pin status, The duration of pin state high level is about 2.5ms,I think the function takes 2.5ms to execute.
    Is there something I haven't modify corrected, what should I do,  Can you give me a correct example project, thanks very much!
  • Hi
    Using the fpu_fft example  in nRF5 SDK v16.0.0 as a starting point I am getting a quite different result.
    I changed the FFT type to len256 and the FFT_TEST_COMP_SAMPLES_LEN define to 512, and measure about 670us running time.
    Which compiler and IDE are you using to test this?
    You will find my test example attached:
    244796_fpu_fft.zip
    Best regards
    Torbjørn
