Error with pc-ble-driver in Visual Studio
I am trying to build a project using the includes/libraries in pc-ble-driver in Visual Studio 19. I have been having linker problems, and I found a support ticket with a similar issue. I followed the instructions in the answer exactly:
  1. New project -> Visual C++ -> Windows Console Application -> OK
  2. In ConesoleApplication.cpp, I replaced the content with this one -> https://github.com/NordicSemiconductor/pc-ble-driver/blob/master/examples/heart_rate_collector/main.c
  3. In the Solution Explorer, right click on ConsoleApplication -> Properties -> VC++ Directories -> “Include Directories” -> Edit ->  New line, find the pc-ble-driver include folder , (e.g. C:\Nordic\nrf-ble-driver-4.1.1-win_x86_32 \include\sd_api_v6) -> OK.
  4. In the Solution Explorer, right click on ConsoleApplication -> Properties -> C/C++ -> Preprocessor -> Preprocessor Definitions -> Edit-> By default there are “WIN32, _DEBUG and _CONSOLE. Add:
    PC_BLE_DRIVER_STATIC
     _CRT_SECURE_NO_WARNINGS
    NRF_SD_BLE_API=6
  5. In the Solution Explorer, right click on ConsoleApplication -> Properties -> C/C++ -> Precompiled Headers -> Precompiled Header -> Set to “Not using precompiled Headers”.
  6. In the Solution Explorer, right click on Header Files -> Add -> Existing Item.. -> Mark all the .h files in folder “nrf-ble-driver-4.1.1-win_x86_32\include\sd_api_v6”, there should be 18 files -> OK.
  7. In the Solution Explorer, right click on “Source Files”, Add -> Existing Item.. -> Find the lib folder, and add nrf-ble-driver-sd_api_v6-mt-static-4_1_1.lib -> OK
  8. Build -> Build Solution
However, I am still getting errors. The errors are as follows:
Error    LNK1120    17 unresolved externals
Warning    LNK4272    library machine type 'x64' conflicts with target machine type 'x86'
Error    LNK2019    unresolved external symbol _sd_ble_cfg_set referenced in function _ble_cfg_set
Error    LNK2019    unresolved external symbol _sd_ble_enable referenced in function _ble_stack_init
Error    LNK2019    unresolved external symbol _sd_ble_gap_connect referenced in function _on_adv_report
Error    LNK2019    unresolved external symbol _sd_ble_gap_conn_param_update referenced in function _on_conn_params_update_request
Error    LNK2019    unresolved external symbol _sd_ble_gap_scan_start referenced in function _on_adv_report
Error    LNK2019    unresolved external symbol _sd_ble_gattc_characteristics_discover referenced in function _char_discovery_start
Error    LNK2019    unresolved external symbol _sd_ble_gattc_descriptors_discover referenced in function _descr_discovery_start
Error    LNK2019    unresolved external symbol _sd_ble_gattc_primary_services_discover referenced in function _service_discovery_start
Error    LNK2019    unresolved external symbol _sd_ble_gattc_write referenced in function _hrm_cccd_set
Error    LNK2019    unresolved external symbol _sd_ble_gatts_exchange_mtu_reply referenced in function _on_exchange_mtu_request
Error    LNK2019    unresolved external symbol _sd_rpc_adapter_create referenced in function _adapter_init
Error    LNK2019    unresolved external symbol _sd_rpc_close referenced in function _main
Error    LNK2019    unresolved external symbol _sd_rpc_data_link_layer_create_bt_three_wire referenced in function _adapter_init
Error    LNK2019    unresolved external symbol _sd_rpc_log_handler_severity_filter_set referenced in function _main
Error    LNK2019    unresolved external symbol _sd_rpc_open referenced in function _main
Error    LNK2019    unresolved external symbol _sd_rpc_physical_layer_create_uart referenced in function _adapter_init
Error    LNK2019    unresolved external symbol _sd_rpc_transport_layer_create referenced in function _adapter_init
It seems that the functions aren't being seen by the project, despite adding the .lib to the solution as described in the above answer.
